2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: posting DBE_PROPERTY
To: [email protected]
Date: Thu, 07 Nov 2013 16:55:15 -0500
Andrew,
On 11/06/2013 11:03 AM, Andrew Johnson wrote:
This will also need release notes, modifications to the AppDevGuide to
document the prop() attribute,
It is no problem to write a blurb for the release notes. However, I'm not that familiar with the AppDevGuide (it has never guided me). Do any sections other than 6.7.2 (Field Definitions Rules) need to be changed?
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node7.html#SECTION00770000000000000000
  and checking with vdct to see if it
accepts this attribute in a DBD file.
vdct 2.6.1278 seems to have no problems.
On this subject. Your perl DBD parser errors out when given unknown field attributes while dbStatic ignores them. Can the perl parser be made to do the same (or at least change this to a warning)?
Michael
posting DBE_PROPERTY Michael Davidsaver
Re: posting DBE_PROPERTY Andrew Johnson
Prev: Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: posting DBE_PROPERTY Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
