Subject: |
[Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base |
Jeff Hill <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 07 Nov 2013 18:25:49 -0000 |
Jeff Hill has proposed merging lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/3.15_libcom_from_cvs_trunk/+merge/194399
This is syncing libCom with my development in an branch deriving from the EPICS cvs trunk. The details are in the first and only, unique from R3.15, revision on the branch
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base.
=== modified file 'src/ca/legacy/pcas/generic/casPVI.cc'
--- src/ca/legacy/pcas/generic/casPVI.cc 2012-10-11 16:28:28 +0000
+++ src/ca/legacy/pcas/generic/casPVI.cc 2013-11-07 18:22:22 +0000
@@ -211,9 +211,10 @@
else {
- errMessage ( S_cas_badType,
+ errPrintf ( S_cas_badType, __FILE__, __LINE__,
"application type \"enums\" string conversion"
- " table for enumerated PV isnt a string type?" );
+ " table for enumerated PV \"%s\" isnt a string type?",
+ getName() );
else if ( resp.dimension() == 1 ) {
=== modified file 'src/libCom/bucketLib/bucketLib.c'
--- src/libCom/bucketLib/bucketLib.c 2009-08-03 17:13:04 +0000
+++ src/libCom/bucketLib/bucketLib.c 2013-11-07 18:22:22 +0000
@@ -144,7 +144,7 @@
static BUCKETID bucketUnsignedHash (BUCKET *pb, const void *pId)
- const unsigned *pUId = pId;
+ const unsigned *pUId = (const unsigned *) pId;
unsigned src;
BUCKETID hashid;
@@ -194,7 +194,7 @@
static BUCKETID bucketStringHash (BUCKET *pb, const void *pId)
- const char *pStr = pId;
+ const char *pStr = (const char *) pId;
BUCKETID hashid;
unsigned i;
=== modified file 'src/libCom/cxxTemplates/README'
--- src/libCom/cxxTemplates/README 2000-09-11 16:15:29 +0000
+++ src/libCom/cxxTemplates/README 2013-11-07 18:22:22 +0000
@@ -30,28 +30,6 @@
from class "ID" (the hash table key type) and also derive from
tsSLNode<T>.
-So far, the only confusion I have run into with templates has been:
-1) strange compiler messages - unrelated to cause of course -
-when I get the class declaration order wrong (so that the
-compiler has trouble instantiating the template).
-2) sun pro/dec/att compilers use a template database and
-gnu/msvc++ compilers use explicit template instantiation.
-Therefore blocks of code of this sort are required:
-#include "resourceLib.h" // template def
-#include "resourceLib.cc" // template functions (that are not inline)
-#if defined (EXPL_TEMPL)
- // From Stroustrups's "The C++ Programming Language"
- // Appendix A: r.14.9
- // This explicitly instantiates the template class's member
- // functions into "templInst.o"
- template class resTable<fred,uintId>;
- template class resTable<jane,stringId>;
-#endif
=== modified file 'src/libCom/fdmgr/fdManager.cpp'
--- src/libCom/fdmgr/fdManager.cpp 2012-07-19 19:59:55 +0000
+++ src/libCom/fdmgr/fdManager.cpp 2013-11-07 18:22:22 +0000
@@ -21,20 +21,17 @@
// 1) This library is not thread safe
-// ANSI C
-#include <errno.h>
-#include <string.h>
+#include <algorithm>
#define instantiateRecourceLib
#define epicsExportSharedSymbols
#include "epicsAssert.h"
#include "epicsThread.h"
-#include "tsMinMax.h"
#include "fdManager.h"
#include "locationException.h"
+using std :: max;
epicsShareDef fdManager fileDescriptorManager;
const unsigned mSecPerSec = 1000u;
@@ -261,9 +258,9 @@
// fdManager::installReg ()
-epicsShareFunc void fdManager::installReg (fdReg ®)
+void fdManager::installReg (fdReg ®)
- this->maxFD = tsMax ( this->maxFD, reg.getFD()+1 );
+ this->maxFD = max ( this->maxFD, reg.getFD()+1 );
// Most applications will find that its important to push here to
// the front of the list so that transient writes get executed
// first allowing incoming read protocol to find that outgoing
=== modified file 'src/libCom/fdmgr/fdManager.h'
--- src/libCom/fdmgr/fdManager.h 2012-07-19 19:59:55 +0000
+++ src/libCom/fdmgr/fdManager.h 2013-11-07 18:22:22 +0000
@@ -104,8 +104,8 @@
fdReg * pCBReg;
void reschedule ();
double quantum ();
- epicsShareFunc void installReg (fdReg ®);
- epicsShareFunc void removeReg (fdReg ®);
+ void installReg (fdReg ®);
+ void removeReg (fdReg ®);
void lazyInitTimerQueue ();
fdManager ( const fdManager & );
fdManager & operator = ( const fdManager & );
=== modified file 'src/libCom/misc/aToIPAddr.c'
--- src/libCom/misc/aToIPAddr.c 2013-06-07 23:08:38 +0000
+++ src/libCom/misc/aToIPAddr.c 2013-11-07 18:22:22 +0000
@@ -1,8 +1,8 @@
+* Copyright (c) 2013 LANS LLC, as Operator of
+* Los Alamos National Laboratory.
* Copyright (c) 2012 UChicago Argonne LLC, as Operator of Argonne
* National Laboratory.
-* Copyright (c) 2002 The Regents of the University of California, as
-* Operator of Los Alamos National Laboratory.
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
@@ -13,22 +13,51 @@
#include <stdio.h>
#include <string.h>
+#include <stdint.h>
#include "osiSock.h"
-#include "epicsStdlib.h"
+#ifndef NELEMENTS
+#define NELEMENTS(A) (sizeof(A)/sizeof(A[0]))
+#endif /*NELEMENTS*/
+ * addrArrayToUL ()
+static int addrArrayToUL ( const unsigned *pAddr,
+ unsigned nElements, struct in_addr *pIpAddr )
+ unsigned i;
+ uint32_t addr = 0ul;
+ for ( i=0u; i < nElements; i++ ) {
+ if ( pAddr[i] > 0xff ) {
+ return -1;
+ addr <<= 8;
+ addr |= ( uint32_t ) pAddr[i];
+ pIpAddr->s_addr = htonl ( addr );
+ return 0;
* initIPAddr()
* !! ipAddr should be passed in in network byte order !!
* !! port is passed in in host byte order !!
-static int initIPAddr (struct in_addr ipAddr, unsigned short port,
- struct sockaddr_in *pIP)
+static int initIPAddr ( struct in_addr ipAddr, unsigned port,
+ struct sockaddr_in *pIP )
- memset(pIP, '\0', sizeof(*pIP));
+ if ( port > 0xffff ) {
+ return -1;
+ uint16_t port_16 = (uint16_t) port;
+ memset (pIP, '\0', sizeof(*pIP));
pIP->sin_family = AF_INET;
- pIP->sin_port = htons(port);
+ pIP->sin_port = htons(port_16);
pIP->sin_addr = ipAddr;
return 0;
@@ -42,47 +71,121 @@
* Sets the port number to "defaultPort" only if
* "pAddrString" does not contain an address of the form
- * "n.n.n.n:p"
+ * "n.n.n.n:p or host:p"
-epicsShareFunc int epicsShareAPI
-aToIPAddr(const char *pAddrString, unsigned short defaultPort,
+epicsShareFunc int epicsShareAPI
+aToIPAddr( const char *pAddrString, unsigned short defaultPort,
int status;
- char hostName[512]; /* !! change n elements here requires change in format below !! */
- unsigned int port;
- unsigned long numaddr;
+ unsigned addr[4];
+ unsigned long rawAddr;
+ * !! change n elements here requires change in format below !!
+ char hostName[512];
+ char dummy[8];
+ unsigned port;
struct in_addr ina;
- * Scan for a port number
- status = sscanf( pAddrString, " %511[^:]:%u", hostName, &port );
- if ( status == 0 ) {
- return -1;
- if ( status == 1 ) {
- port = defaultPort;
- else if (status == 2 && port > 65535) {
- return -1;
- * Look for a valid host name or dotted quad
- status = hostToIPAddr( hostName, &ina );
- return initIPAddr( ina, port, pIP );
- * Try the IP address as a decimal integer
- if ( epicsParseULong( hostName, &numaddr, 10, NULL ) ) {
- return -1;
- ina.s_addr = htonl( numaddr );
+ * dotted ip addresses
+ status = sscanf ( pAddrString, " %u . %u . %u . %u %7s ",
+ addr, addr+1u, addr+2u, addr+3u, dummy );
+ if ( status == 4 ) {
+ if ( addrArrayToUL ( addr, NELEMENTS ( addr ), & ina ) < 0 ) {
+ return -1;
+ port = defaultPort;
+ return initIPAddr ( ina, port, pIP );
+ * dotted ip addresses and port
+ status = sscanf ( pAddrString, " %u . %u . %u . %u : %u %7s",
+ addr, addr+1u, addr+2u, addr+3u, &port, dummy );
+ if ( status >= 5 ) {
+ if ( status > 5 ) {
+ * valid at the start but detritus on the end
+ return -1;
+ if ( addrArrayToUL ( addr, NELEMENTS ( addr ), &ina ) < 0 ) {
+ return -1;
+ * IP address as a raw number
+ status = sscanf ( pAddrString, " %lu %7s ", &rawAddr, dummy );
+ if ( status == 1 ) {
+ if ( rawAddr > 0xffffffff ) {
+ return -1;
+ uint32_t rawAddr_32 = ( uint32_t ) rawAddr;
+ ina.s_addr = htonl ( rawAddr_32 );
+ * IP address as a raw number, and port
+ status = sscanf ( pAddrString, " %lu : %u %7s ", &rawAddr, &port, dummy );
+ if ( status >= 2 ) {
+ if ( status > 2 ) {
+ return -1;
+ return -1;
+ * host name string
+ status = sscanf ( pAddrString, " %511[^:] %s ", hostName, dummy );
+ status = hostToIPAddr ( hostName, &ina );
+ if ( status == 0 ) {
+ * host name string, and port
+ status = sscanf ( pAddrString, " %511[^:] : %u %s ", hostName,
+ &port, dummy );
+ return -1;
+ return -1;
=== modified file 'src/libCom/misc/ipAddrToAsciiAsynchronous.cpp'
--- src/libCom/misc/ipAddrToAsciiAsynchronous.cpp 2012-04-12 16:28:23 +0000
+++ src/libCom/misc/ipAddrToAsciiAsynchronous.cpp 2013-11-07 18:22:22 +0000
@@ -25,7 +25,7 @@
#include <string>
#include <climits>
#include <stdexcept>
-#include <stdio.h>
+#include <cstdio>
#include "ipAddrToAsciiAsynchronous.h"
@@ -206,7 +206,7 @@
this->thread.exitWait ();
-// for now its probably sufficent to allocate one
+// for now its probably sufficient to allocate one
// DNS transaction thread for all codes sharing
// the same process that need DNS services but we
// leave our options open for the future
=== modified file 'src/libCom/osi/epicsThread.h'
--- src/libCom/osi/epicsThread.h 2012-07-06 21:33:10 +0000
+++ src/libCom/osi/epicsThread.h 2013-11-07 18:22:22 +0000
@@ -10,7 +10,12 @@
#ifndef epicsThreadh
#define epicsThreadh
+#ifdef __cplusplus
+#include <cstddef>
+using std :: size_t;
+#else
#include <stddef.h>
+#endif
#include "shareLib.h"
@@ -38,7 +43,9 @@
/* stack sizes for each stackSizeClass are implementation and CPU dependent */
typedef enum {
- epicsThreadStackSmall, epicsThreadStackMedium, epicsThreadStackBig
+ epicsThreadStackSmall,
+ epicsThreadStackMedium,
+ epicsThreadStackBig
} epicsThreadStackSizeClass;
typedef enum {
=== modified file 'src/libCom/osi/epicsTime.cpp'
--- src/libCom/osi/epicsTime.cpp 2012-11-14 20:10:44 +0000
+++ src/libCom/osi/epicsTime.cpp 2013-11-07 18:22:22 +0000
@@ -1,8 +1,10 @@
+* Copyright (c) 2011 LANS LLC, as Operator of
+* Copyright (c) 2002 The Regents of the University of California, as
+* Operator of Los Alamos National Laboratory.
* Copyright (c) 2007 UChicago Argonne LLC, as Operator of Argonne
@@ -58,8 +60,12 @@
// epicsTime (const unsigned long secIn, const unsigned long nSecIn)
-inline epicsTime::epicsTime (const unsigned long secIn, const unsigned long nSecIn) :
- secPastEpoch ( nSecIn / nSecPerSec + secIn ), nSec ( nSecIn % nSecPerSec ) {}
+inline epicsTime::epicsTime (const unsigned long secIn,
+ const unsigned long nSecIn) :
+ secPastEpoch ( nSecIn / nSecPerSec + secIn ),
+ nSec ( nSecIn % nSecPerSec )
// epicsTimeLoadTimeInit
@@ -109,51 +115,45 @@
// epicsTime::addNanoSec ()
-// many of the UNIX timestamp formats have nano sec stored as a long
+// The nano-second field of several of the the UNIX time stamp formats
+// field is stored in the C type "long".
-void epicsTime::addNanoSec (long nSecAdj)
+void epicsTime :: addNanoSec ( long nSecAdj )
- // After optimizing this function we now have a larger
- // code which uses only unsigned integer arithmetic.
- // This is for the benefit of embedded cpu's lacking
- // a hardware floating point coprocessor at the
- // expense of some additional code to maintain.
- // joh 14-11-2012
+ // After optimizing this function we now have a larger code which
+ // uses only unsigned integer, and not floating point, arithmetic.
+ // This change benefits embedded CPU's lacking a floating point
+ // co-processor at the expense of some additional code to maintain.
+ // We hope that all CPU's we run on provide at least an integer
+ // divide instruction which should enable this implementation
+ // to be more efficient than implementations based on branching;
+ // this is presuming that we will run on pipelined architectures.
+ // Overflow and underflow is expected; in the future we might
+ // operate close to, the modulo of, the EPICS epic.
+ // We are depending on the normalize operation in the private
+ // constructor used below.
+ // joh 11-04-2012
if ( nSecAdj >= 0 ) {
- unsigned long nSecOffsetLong =
- static_cast < unsigned long > ( nSecAdj );
- while ( nSecOffsetLong >= nSecPerSec ) {
- this->secPastEpoch++; // overflow expected
- nSecOffsetLong -= nSecPerSec;
- const epicsUInt32 nSecOffset =
- static_cast < epicsUInt32 > ( nSecOffsetLong );
- epicsUInt32 nSecPerSecRemaining = nSecPerSec - nSecOffset;
- if ( this->nSec >= nSecPerSecRemaining ) {
- this->nSec -= nSecPerSecRemaining;
- else {
- this->nSec += nSecOffset;
+ const unsigned long nSecPlus =
+ static_cast <unsigned long> ( nSecAdj );
+ const unsigned long nSecPlusAdj = nSecPlus % nSecPerSec;
+ const unsigned long secPlusAdj = nSecPlus / nSecPerSec;
+ *this = epicsTime ( this->secPastEpoch+secPlusAdj,
+ this->nSec+nSecPlusAdj );
else {
- static_cast <unsigned long> ( -nSecAdj );
- this->secPastEpoch--; // underflow expected
- if ( this->nSec >= nSecOffset ) {
- this->nSec -= nSecOffset;
- else {
- // borrow
- this->nSec += nSecPerSec - nSecOffset;
+ const unsigned long nSecMinus =
+ static_cast <unsigned long> ( -nSecAdj );
+ const unsigned long nSecMinusAdj = nSecMinus % nSecPerSec;
+ const unsigned long secMinusAdj = nSecMinus / nSecPerSec;
+ *this = epicsTime ( this->secPastEpoch - secMinusAdj - 1u,
+ this->nSec + nSecPerSec - nSecMinusAdj );
@@ -368,8 +368,8 @@
time_t_wrapper ansiTimeTicks;
ansiTimeTicks = *this;
- // On Posix systems timeval :: tv_sec is a time_t so this can be
- // a direct assignement. On other systems I dont know that we can
+ // On Posix systems timeval :: tv_sec is a time_t so this can be
+ // a direct assignment. On other systems I dont know that we can
// guarantee that time_t and timeval :: tv_sec will have the
// same epoch or have the same scaling factor to discrete seconds.
// For example, on windows time_t changed recently to a 64 bit
@@ -387,8 +387,8 @@
epicsTime::epicsTime (const struct timeval &ts)
@@ -438,11 +438,11 @@
epicsTimeStamp ts;
- // trucation by design
+ // truncation by design
- // epicsTime::secPastEpoch is based on ulong and has much greater range
- // on 64 bit hosts than the orginal epicsTimeStamp::secPastEpoch. The
- // epicsTimeStamp::secPastEpoch is based on epicsUInt32 so that it will
+ // epicsTime::secPastEpoch is based on ulong and has much greater range
+ // on 64 bit hosts than the original epicsTimeStamp::secPastEpoch. The
+ // epicsTimeStamp::secPastEpoch is based on epicsUInt32 so that it will
// match the original network protocol. Of course one can anticipate
// that eventually, a epicsUInt64 based network time stamp will be
// introduced when 64 bit architectures are more ubiquitous.
@@ -653,7 +653,7 @@
if ( level > 1 ) {
- // this also supresses the "defined, but not used"
+ // this also suppresses the "defined, but not used"
// warning message
printf ( "epicsTime: revision \"%s\"\n",
pEpicsTimeVersion );
=== modified file 'src/libCom/osi/epicsTime.h'
--- src/libCom/osi/epicsTime.h 2009-01-28 20:01:41 +0000
+++ src/libCom/osi/epicsTime.h 2013-11-07 18:22:22 +0000
@@ -12,7 +12,11 @@
#ifndef epicsTimehInclude
#define epicsTimehInclude
-#include <time.h>
+#ifdef __cplusplus
+# include <ctime>
+#else
+# include <time.h>
+#endif
#include "epicsTypes.h"
@@ -42,7 +46,7 @@
* and a struct tm that is adjusted for the local timezone
struct local_tm_nano_sec {
- struct tm ansi_tm; /* ANSI C time details */
+ std :: tm ansi_tm; /* ANSI C time details */
unsigned long nSec; /* nano seconds extension */
@@ -51,7 +55,7 @@
* and a struct tm that is adjusted for GMT (UTC)
struct gm_tm_nano_sec {
@@ -61,7 +65,7 @@
* conversions to occur
struct time_t_wrapper {
- time_t ts;
+ std :: time_t ts;
class epicsShareClass epicsTimeEvent
@@ -244,8 +248,10 @@
/* OS dependent reentrant versions of the ANSI C interface because */
/* vxWorks gmtime_r interface does not match POSIX standards */
-epicsShareFunc int epicsShareAPI epicsTime_localtime ( const time_t * clock, struct tm * result );
-epicsShareFunc int epicsShareAPI epicsTime_gmtime ( const time_t * clock, struct tm * result );
+ epicsTime_localtime ( const time_t * clock, struct tm * result );
+ epicsTime_gmtime ( const time_t * clock, struct tm * result );
#ifdef __cplusplus
=== modified file 'src/libCom/osi/os/WIN32/osdProcess.c'
--- src/libCom/osi/os/WIN32/osdProcess.c 2010-10-05 19:27:37 +0000
+++ src/libCom/osi/os/WIN32/osdProcess.c 2013-11-07 18:22:22 +0000
@@ -64,90 +64,76 @@
startupInfo.wShowWindow = SW_SHOWMINNOACTIVE;
status = CreateProcess (
- NULL, /* pointer to name of executable module (not required if command line is specified) */
- (char *) pBaseExecutableName, /* pointer to command line string */
- NULL, /* pointer to process security attributes */
- NULL, /* pointer to thread security attributes */
- FALSE, /* handle inheritance flag */
- CREATE_NEW_PROCESS_GROUP | DETACHED_PROCESS, /* creation flags */
- NULL, /* pointer to new environment block (defaults to caller's environement) */
- NULL, /* pointer to current directory name (defaults to caller's current directory) */
- &startupInfo, /* pointer to STARTUPINFO */
- &processInfo /* pointer to PROCESS_INFORMATION */
- DWORD W32status;
- LPVOID errStrMsgBuf;
- LPVOID complteMsgBuf;
- W32status = FormatMessage (
- FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
- NULL,
- GetLastError (),
- MAKELANGID (LANG_NEUTRAL, SUBLANG_DEFAULT), /* Default language */
- (LPTSTR) &errStrMsgBuf,
- 0,
- NULL
- if ( W32status ) {
- char *pFmtArgs[6];
+ NULL, /* pointer to name of executable module (not required if command line is specified) */
+ (char *) pBaseExecutableName, /* pointer to command line string */
+ NULL, /* pointer to process security attributes */
+ NULL, /* pointer to thread security attributes */
+ FALSE, /* handle inheritance flag */
+ CREATE_NEW_PROCESS_GROUP | DETACHED_PROCESS, /* creation flags */
+ NULL, /* pointer to new environment block (defaults to caller's environement) */
+ NULL, /* pointer to current directory name (defaults to caller's current directory) */
+ &startupInfo, /* pointer to STARTUPINFO */
+ &processInfo /* pointer to PROCESS_INFORMATION */
+ DWORD W32status;
+ LPVOID errStrMsgBuf;
+ LPVOID complteMsgBuf;
+ W32status = FormatMessage (
+ FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
+ NULL,
+ GetLastError (),
+ MAKELANGID (LANG_NEUTRAL, SUBLANG_DEFAULT), /* Default language */
+ (LPTSTR) &errStrMsgBuf,
+ 0,
+ NULL
+ if ( W32status ) {
+ char *pFmtArgs[6];
pFmtArgs[0] = "Failed to start executable -";
pFmtArgs[1] = (char *) pBaseExecutableName;
pFmtArgs[2] = errStrMsgBuf;
pFmtArgs[3] = "Changes may be required in your \"path\" environment variable.";
pFmtArgs[4] = "PATH = ";
pFmtArgs[5] = getenv ("path");
- if ( pFmtArgs[5] == NULL ) {
- pFmtArgs[5] = "<empty string>";
- W32status = FormatMessage(
- FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_STRING |
- FORMAT_MESSAGE_ARGUMENT_ARRAY | 80,
- "%1 \"%2\". %3 %4 %5 \"%6\"",
- 0,
- (LPTSTR) &complteMsgBuf,
- 0,
- pFmtArgs
- if (W32status) {
- /* Display the string. */
- MessageBox (NULL, complteMsgBuf, "Configuration Problem",
- MB_OK | MB_ICONINFORMATION);
- LocalFree (complteMsgBuf);
- else {
- MessageBox (NULL, errStrMsgBuf, "Failed to start executable",
- /* Free the buffer. */
- LocalFree (errStrMsgBuf);
- else {
- errlogPrintf ("!!WARNING!!\n");
- errlogPrintf ("Unable to locate executable \"%s\".\n", pBaseExecutableName);
- errlogPrintf ("You may need to modify your environment.\n");
+ if ( pFmtArgs[5] == NULL ) {
+ pFmtArgs[5] = "<empty string>";
+ W32status = FormatMessage(
+ FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_STRING |
+ FORMAT_MESSAGE_ARGUMENT_ARRAY | 80,
+ "%1 \"%2\". %3 %4 %5 \"%6\"",
+ 0,
+ (LPTSTR) &complteMsgBuf,
+ 0,
+ pFmtArgs
+ if (W32status) {
+ /* Display the string. */
+ MessageBox (NULL, complteMsgBuf, "Configuration Problem",
+ MB_OK | MB_ICONINFORMATION);
+ LocalFree (complteMsgBuf);
+ else {
+ MessageBox (NULL, errStrMsgBuf, "Failed to start executable",
+ /* Free the buffer. */
+ LocalFree (errStrMsgBuf);
+ else {
+ errlogPrintf ("!!WARNING!!\n");
+ errlogPrintf ("Unable to locate executable \"%s\".\n", pBaseExecutableName);
+ errlogPrintf ("You may need to modify your \"path\"venvironment variable.\n");
return osiSpawnDetachedProcessFail;
return osiSpawnDetachedProcessSuccess;
- use of spawn here causes problems when the ca repeater
- inherits open files (and sockets) from the spawning
- process
- status = _spawnlp (_P_DETACH, pBaseExecutableName, pBaseExecutableName, NULL);
- if (status<0) {
- errlogPrintf ("Unable to locate the EPICS executable \"%s\".\n",
- pBaseExecutableName);
=== modified file 'src/libCom/osi/os/WIN32/osdTime.cpp'
--- src/libCom/osi/os/WIN32/osdTime.cpp 2012-07-20 23:11:15 +0000
+++ src/libCom/osi/os/WIN32/osdTime.cpp 2013-11-07 18:22:22 +0000
@@ -17,10 +17,10 @@
// ANSI C
-#include <math.h>
-#include <time.h>
-#include <limits.h>
-#include <stdio.h>
+#include <cmath>
+#include <ctime>
+#include <climits>
+#include <cstdio>
// WIN32
@@ -28,6 +28,7 @@
#define VC_EXTRALEAN
#define STRICT
#include <windows.h>
+#include <process.h>
// EPICS
@@ -46,19 +47,26 @@
# define debugPrintf(argsInParen)
#endif
+extern "C" void setThreadName ( DWORD dwThreadID, LPCSTR szThreadName );
static int osdTimeGetCurrent ( epicsTimeStamp *pDest );
// for mingw
#if !defined ( MAXLONGLONG )
-#define MAXLONGLONG 0x7fffffffffffffffLL
+# define MAXLONGLONG 0x7fffffffffffffffLL
#endif
#if !defined ( MINLONGLONG )
-#define MINLONGLONG (~0x7fffffffffffffffLL)
+# define MINLONGLONG ~0x7fffffffffffffffLL
+#endif
+#ifndef STACK_SIZE_PARAM_IS_A_RESERVATION
+# define STACK_SIZE_PARAM_IS_A_RESERVATION 0x00010000
#endif
static const LONGLONG epicsEpochInFileTime = 0x01b41e2a18d64000LL;
-class currentTime : public epicsTimerNotify {
+static unsigned __stdcall _pllThreadEntry ( void * pCurrentTimeIn );
+class currentTime {
public:
currentTime ();
~currentTime ();
@@ -72,20 +80,24 @@
LONGLONG perfCounterFreqPLL;
LONGLONG lastPerfCounterPLL;
LONGLONG lastFileTimePLL;
- epicsTimerQueueActive * pTimerQueue;
- epicsTimer * pTimer;
+ HANDLE threadHandle;
+ unsigned threadId;
bool perfCtrPresent;
+ bool threadShutdownCmd;
+ bool threadHasExited;
+ void updatePLL ();
static const int pllDelay; /* integer seconds */
- epicsTimerNotify::expireStatus expire ( const epicsTime & );
+ // cant be static because of diff btw __stdcall and __cdecl
+ friend unsigned __stdcall _pllThreadEntry ( void * pCurrentTimeIn );
+const int currentTime :: pllDelay = 5;
static currentTime * pCurrentTime = 0;
static const LONGLONG FILE_TIME_TICKS_PER_SEC = 10000000;
static const LONGLONG EPICS_TIME_TICKS_PER_SEC = 1000000000;
static const LONGLONG ET_TICKS_PER_FT_TICK =
EPICS_TIME_TICKS_PER_SEC / FILE_TIME_TICKS_PER_SEC;
-const int currentTime :: pllDelay = 5;
// Start and register time provider
@@ -185,8 +197,8 @@
- // There are remarkable weaknessess in the FileTimeToLocalFileTime
- // interface so we dont use it here. Unfortunately, there is no
+ // There are remarkable weaknesses in the FileTimeToLocalFileTime
+ // interface so we don't use it here. Unfortunately, there is no
// corresponding function that works on file time.
SYSTEMTIME st;
@@ -263,9 +275,11 @@
perfCounterFreqPLL ( 0 ),
lastPerfCounterPLL ( 0 ),
lastFileTimePLL ( 0 ),
- pTimerQueue ( 0 ),
- pTimer ( 0 ),
- perfCtrPresent ( false )
+ threadHandle ( 0 ),
+ threadId ( 0 ),
+ perfCtrPresent ( false ),
+ threadShutdownCmd ( false ),
+ threadHasExited ( false )
InitializeCriticalSection ( & this->mutex );
@@ -308,15 +322,34 @@
this->lastFileTimePLL = liFileTime.QuadPart;
+void currentTime :: startPLL ()
+ // create frequency estimation thread when needed
+ if ( this->perfCtrPresent && ! this->threadHandle ) {
+ this->threadHandle = (HANDLE)
+ _beginthreadex ( 0, 4096, _pllThreadEntry, this,
+ CREATE_SUSPENDED | STACK_SIZE_PARAM_IS_A_RESERVATION,
+ & this->threadId );
+ assert ( this->threadHandle );
+ BOOL bstat = SetThreadPriority (
+ this->threadHandle, THREAD_PRIORITY_HIGHEST );
+ assert ( bstat );
+ DWORD wstat = ResumeThread ( this->threadHandle );
+ assert ( wstat != 0xFFFFFFFF );
currentTime::~currentTime ()
+ EnterCriticalSection ( & this->mutex );
+ this->threadShutdownCmd = true;
+ while ( ! this->threadHasExited ) {
+ LeaveCriticalSection ( & this->mutex );
+ Sleep ( 250 /* mS */ );
DeleteCriticalSection ( & this->mutex );
- if ( this->pTimer ) {
- this->pTimer->destroy ();
- if ( this->pTimerQueue ) {
- this->pTimerQueue->release ();
void currentTime::getCurrentTime ( epicsTimeStamp & dest )
@@ -386,7 +419,7 @@
// Maintain corrected version of the performance counter's frequency using
// a phase locked loop. This approach is similar to NTP's.
-epicsTimerNotify::expireStatus currentTime::expire ( const epicsTime & )
+void currentTime :: updatePLL ()
@@ -431,7 +464,7 @@
if ( fileTimeDiff <= 0 ) {
LeaveCriticalSection( & this->mutex );
debugPrintf ( ( "currentTime: file time difference in PLL was less than zero\n" ) );
- return expireStatus ( restart, pllDelay /* sec */ );
+ return;
LONGLONG freq = ( FILE_TIME_TICKS_PER_SEC * perfCounterDiff ) / fileTimeDiff;
@@ -445,7 +478,7 @@
static_cast < int > ( -bound ),
static_cast < int > ( delta ),
static_cast < int > ( bound ) ) );
+ return;
// update feedback loop estimating the performance counter's frequency
@@ -482,7 +515,7 @@
debugPrintf ( ( "perf ctr measured delay out of bounds m=%d max=%d\n",
static_cast < int > ( perfCounterDiffSinceLastFetch ),
static_cast < int > ( expectedDly + bnd ) ) );
+ return;
@@ -521,9 +554,9 @@
delta = epicsTimeFromCurrentFileTime - this->epicsTimeLast;
if ( delta > EPICS_TIME_TICKS_PER_SEC || delta < -EPICS_TIME_TICKS_PER_SEC ) {
- // When there is an abrupt shift in the current computed time vs
- // the time derived from the current file time then someone has
- // probabably adjusted the real time clock and the best reaction
+ // When there is an abrupt shift in the current computed time vs
+ // the time derived from the current file time then someone has
+ // probably adjusted the real time clock and the best reaction
// is to just assume the new time base
this->epicsTimeLast = epicsTimeFromCurrentFileTime;
this->perfCounterFreq = this->perfCounterFreqPLL;
@@ -563,24 +596,31 @@
( this->perfCounterFreqPLL - sysFreq.QuadPart );
freqEstDiff /= sysFreq.QuadPart;
freqEstDiff *= 100.0;
- debugPrintf ( ( "currentTime: freq delta %f %% freq est delta %f %% time delta %f sec\n",
- freqDiff, freqEstDiff, static_cast < double > ( delta ) / EPICS_TIME_TICKS_PER_SEC ) );
+ debugPrintf ( ( "currentTime: freq delta %f %% freq est "
+ "delta %f %% time delta %f sec\n",
+ freqDiff,
+ freqEstDiff,
+ static_cast < double > ( delta ) /
+ EPICS_TIME_TICKS_PER_SEC ) );
# endif
-void currentTime::startPLL ()
- // create frequency estimation timer when needed
- if ( this->perfCtrPresent && ! this->pTimerQueue ) {
- this->pTimerQueue = & epicsTimerQueueActive::allocate ( true );
- this->pTimer = & this->pTimerQueue->createTimer ();
- this->pTimer->start ( *this, pllDelay );
+ currentTime * pCT =
+ reinterpret_cast < currentTime * > ( pCurrentTimeIn );
+ setThreadName ( pCT->threadId, "EPICS Time PLL" );
+ while ( ! pCT->threadShutdownCmd ) {
+ Sleep ( currentTime :: pllDelay * 1000 /* mS */ );
+ pCT->updatePLL ();
+ EnterCriticalSection ( & pCT->mutex );
+ pCT->threadHasExited = true;
+ LeaveCriticalSection ( & pCT->mutex );
+ return 1;
epicsTime::operator FILETIME () const
=== modified file 'src/libCom/osi/os/vxWorks/osdSock.c'
--- src/libCom/osi/os/vxWorks/osdSock.c 2013-06-07 23:08:38 +0000
+++ src/libCom/osi/os/vxWorks/osdSock.c 2013-11-07 18:22:22 +0000
@@ -115,18 +115,11 @@
hostToIPAddr(const char *pHostName, struct in_addr *pIPA)
- int addr;
- addr = hostGetByName((char *)pHostName);
- if (addr != ERROR) {
- pIPA->s_addr = (unsigned long) addr;
- else if (inet_aton((char *)pHostName, pIPA) == ERROR) {
- * return indicating an error
+ int addr = hostGetByName ( (char *) pHostName );
+ if ( addr == ERROR ) {
return -1;
+ pIPA->s_addr = (unsigned long) addr;
* success
=== modified file 'src/libCom/osi/osiNTPTime.c'
--- src/libCom/osi/osiNTPTime.c 2010-10-22 22:34:13 +0000
+++ src/libCom/osi/osiNTPTime.c 2013-11-07 18:22:22 +0000
@@ -18,6 +18,7 @@
#include <time.h>
#include <errno.h>
+#define epicsExportSharedSymbos
#include "epicsEvent.h"
#include "epicsExit.h"
=== modified file 'src/libCom/test/blockingSockTest.cpp'
--- src/libCom/test/blockingSockTest.cpp 2012-12-06 20:31:50 +0000
+++ src/libCom/test/blockingSockTest.cpp 2013-11-07 18:22:22 +0000
@@ -22,8 +22,8 @@
epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
union address {
- struct sockaddr_in ia;
- struct sockaddr sa;
+ struct sockaddr_in m_ia;
+ struct sockaddr m_sa;
class circuit {
@@ -37,10 +37,10 @@
bool sendWakeupDetected () const;
virtual const char * pName () = 0;
protected:
- SOCKET sock;
- epicsThreadId id;
- bool recvWakeup;
- bool sendWakeup;
+ SOCKET m_sock;
+ epicsThreadId m_id;
+ bool m_recvWakeup;
+ bool m_sendWakeup;
protected:
virtual ~circuit() {}
@@ -61,48 +61,50 @@
class server {
public:
- server ( address & );
+ server ( const address & );
void start ();
void daemon ();
+ address addr () const;
protected:
- SOCKET sock;
- epicsThreadId id;
- bool exit;
+ address m_addr;
+ SOCKET m_sock;
+ bool m_exit;
circuit::circuit ( SOCKET sockIn ) :
- sock ( sockIn ),
- id ( 0 ),
- recvWakeup ( false ),
- sendWakeup ( false )
+ m_sock ( sockIn ),
+ m_id ( 0 ),
+ m_recvWakeup ( false ),
+ m_sendWakeup ( false )
- verify ( this->sock != INVALID_SOCKET );
+ verify ( m_sock != INVALID_SOCKET );
bool circuit::recvWakeupDetected () const
- return this->recvWakeup;
+ return m_recvWakeup;
bool circuit::sendWakeupDetected () const
- return this->sendWakeup;
+ return m_sendWakeup;
void circuit::shutdown ()
- int status = ::shutdown ( this->sock, SHUT_RDWR );
+ int status = ::shutdown ( m_sock, SHUT_RDWR );
verify ( status == 0 );
void circuit::signal ()
- epicsSignalRaiseSigAlarm ( this->id );
+ epicsSignalRaiseSigAlarm ( m_id );
void circuit::close ()
- epicsSocketDestroy ( this->sock );
+ epicsSocketDestroy ( m_sock );
void circuit::recvTest ()
@@ -110,11 +112,11 @@
epicsSignalInstallSigAlarmIgnore ();
char buf [1];
while ( true ) {
- int status = recv ( this->sock,
+ int status = recv ( m_sock,
buf, (int) sizeof ( buf ), 0 );
testDiag ( "%s was disconnected", this->pName () );
- this->recvWakeup = true;
+ m_recvWakeup = true;
break;
else if ( status > 0 ) {
@@ -126,7 +128,7 @@
sockErrBuf, sizeof ( sockErrBuf ) );
testDiag ( "%s socket recv() error was \"%s\"\n",
this->pName (), sockErrBuf );
break;
@@ -143,15 +145,15 @@
address tmpAddr = addrIn;
int status = ::connect (
- this->sock, & tmpAddr.sa, sizeof ( tmpAddr ) );
+ m_sock, & tmpAddr.m_sa, sizeof ( tmpAddr ) );
circuit * pCir = this;
- this->id = epicsThreadCreate (
+ m_id = epicsThreadCreate (
"client circuit", epicsThreadPriorityMedium,
epicsThreadGetStackSize(epicsThreadStackMedium),
socketRecvTest, pCir );
- verify ( this->id );
+ verify ( m_id );
@@ -165,56 +167,62 @@
pSrv->daemon ();
-server::server ( address & addrIn ) :
- sock ( epicsSocketCreate ( AF_INET, SOCK_STREAM, IPPROTO_TCP ) ),
- id ( 0 ), exit ( false )
+server::server ( const address & addrIn ) :
+ m_addr ( addrIn ),
+ m_sock ( epicsSocketCreate ( AF_INET, SOCK_STREAM, IPPROTO_TCP ) ),
+ m_id ( 0 ), m_exit ( false )
// setup server side
- int status = bind ( this->sock,
- & addrIn.sa, sizeof ( addrIn ) );
+ int status = bind ( m_sock,
+ & m_addr.m_sa, sizeof ( m_addr ) );
if ( status ) {
testDiag ( "bind to server socket failed, status = %d", status );
- osiSocklen_t slen = sizeof ( addrIn );
- if ( getsockname(this->sock, &addrIn.sa, &slen) != 0 ) {
+ osiSocklen_t slen = sizeof ( m_addr );
+ if ( getsockname(m_sock, &m_addr.m_sa, &slen) != 0 ) {
testAbort ( "Failed to read socket address" );
- status = listen ( this->sock, 10 );
+ status = listen ( m_sock, 10 );
void server::start ()
- "server daemon", epicsThreadPriorityMedium,
- epicsThreadGetStackSize(epicsThreadStackMedium),
+ "server daemon", epicsThreadPriorityMedium,
+ epicsThreadGetStackSize(epicsThreadStackMedium),
serverDaemon, this );
+ verify ( m_id );
-void server::daemon ()
+void server::daemon ()
- while ( ! this->exit ) {
+ while ( ! m_exit ) {
// accept client side
address addr;
osiSocklen_t addressSize = sizeof ( addr );
- SOCKET ns = accept ( this->sock,
- & addr.sa, & addressSize );
+ SOCKET ns = accept ( m_sock,
+ & m_addr.m_sa, & addressSize );
verify ( ns != INVALID_SOCKET );
circuit * pCir = new serverCircuit ( ns );
verify ( pCir );
+address server::addr () const
+ return m_addr;
serverCircuit::serverCircuit ( SOCKET sockIn ) :
circuit ( sockIn )
- epicsThreadId threadId = epicsThreadCreate (
- "server circuit", epicsThreadPriorityMedium,
+ epicsThreadId threadId = epicsThreadCreate (
+ "server circuit", epicsThreadPriorityMedium,
verify ( threadId );
@@ -235,7 +243,7 @@
{esscimqi_socketBothShutdownRequired, "esscimqi_socketBothShutdownRequired" },
{esscimqi_socketSigAlarmRequired, "esscimqi_socketSigAlarmRequired" }
for (unsigned i=0; i < (sizeof(mechs) / sizeof(mechs[0])); ++i) {
if (mech == mechs[i].mech)
return mechs[i].name;
@@ -249,12 +257,13 @@
address addr;
memset ( (char *) & addr, 0, sizeof ( addr ) );
- addr.ia.sin_family = AF_INET;
- addr.ia.sin_addr.s_addr = htonl ( INADDR_LOOPBACK );
- addr.ia.sin_port = 0;
+ addr.m_ia.sin_family = AF_INET;
+ addr.m_ia.sin_addr.s_addr = htonl ( INADDR_LOOPBACK );
+ addr.m_ia.sin_port = 0;
server srv ( addr );
srv.start ();
+ addr = srv.addr ();
clientCircuit client ( addr );
epicsThreadSleep ( 1.0 );
=== modified file 'src/libCom/test/epicsTimeTest.cpp'
--- src/libCom/test/epicsTimeTest.cpp 2013-06-07 19:35:45 +0000
+++ src/libCom/test/epicsTimeTest.cpp 2013-11-07 18:22:22 +0000
@@ -9,11 +9,6 @@
* Authors: Jeff Hill, Marty Kraimer and Andrew Johnson
-#ifdef __SUNPRO_CC
-using namespace std;
-#endif
#include <cstddef>
#include <cstdio>
#include <ctime>
@@ -45,7 +40,7 @@
MAIN(epicsTimeTest)
- const int wasteTime = 100000;
+ const int wasteTime = 100000u;
const int nTimes = 10;
testPlan(12 + nTimes * 18);
- [Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
Re: posting DBE_PROPERTY Andrew Johnson
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
<2013>
2025
2026
Re: posting DBE_PROPERTY Michael Davidsaver
<2013>
2025
2026
