2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: posting DBE_PROPERTY
To: <[email protected]>
Date: Wed, 6 Nov 2013 10:03:28 -0600
Hi Michael,
On 11/04/2013 12:52 PM, Michael Davidsaver wrote:
I made a quick attempt to add posting of DBE_PROPERTY events to give
notification of CA meta-data changes.  A new record field attribute is
added to identify meta-data fields.  Monitors are posted from dbPut()
whenever a meta-data field is written, even if the value doesn't change.
https://code.launchpad.net/~epics-core/epics-base/postdbrprop
Great -- I didn't realize there was so little left to do to finally implement this, although I had been thinking about it for some time. I just pushed a change to add the proc attribute value to the output printed by dbDumpField() and dbWriteRecordType().
I also marked the alarm severity fields HHSV, HSV, LSV and LLSV as prop(YES) for all DBF_DOUBLE-valued records, because changing them to/from NO_ALARM changes the alarm limits reported in a DBR_GR_DOUBLE to/from NaN. There may be a few other fields that we need to mark but I can't think of any right now.
This will also need release notes, modifications to the AppDevGuide to document the prop() attribute, and checking with vdct to see if it accepts this attribute in a DBD file.
Thanks!
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: posting DBE_PROPERTY Michael Davidsaver
Prev: Re: db_create_event_log Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: posting DBE_PROPERTY Michael Davidsaver
Next: Re: posting DBE_PROPERTY Michael Davidsaver
