2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base
To: [email protected]
Date: Thu, 14 Nov 2013 22:10:55 -0000
The proposal to merge lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base has been updated.
Description changed to:
This is syncing libCom with some easier to merge elements of my development in an branch deriving from the EPICS cvs trunk. Here is a quick summary of the changes.
o fixed compile errors in, and proper diagnostic from, casPVI.cc
o suprressed some compile time warnings in bucketLib.c
o cleaned up cxx templates README
o removed use of tsMinMax from libCom in favor of the standard library
     (calls to tsMinMax still exist in other components in base, but they are being removed)
o removed sharable library export of certain private member functions from class fdManager
o fixed aToIPAddr to correctly lookup all of the different IP address string types on all OS types independent of the OS interfae variations
o removed use of inet_aton from vxWorks implementation of hostToIPAddr
   o this function is for converting a host name to an ip address _only_
   o the aToIPAddr wrapper is supposed to do the dotted ip ascii string to ip address structure conversion independent of OS spoecific interface variations, when it works correctly
o fixed some spelling issues in comments
o added additional optimizations for processors w/o floating point ALU to addNanoSec in epicsTime
o removed tabs and junk comments from win32 osdProcess.c
o moved PLL update in win32 osdTime.c from timer to a dedicated thread
o added missing epicsExportShared symbols define to osiNTPTime.c
o fixed server ctor should not modify arguments of its caller in blockingSockTest
o removed sunpro specific ifdef nolonger needed from epicsTimeTest.cpp
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/3.15_libcom_from_cvs_trunk/+merge/194399
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base.
[Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
Prev: Base 3.14.12.4 Release Timetable Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.15 #28 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
