2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Wed, 04 Dec 2013 18:06:30 -0000
On 12/04/2013 03:49 AM, Ralph Lange wrote:
>> The documentation branch does not cover all the changes made here,
>> it only talks about the modifications to the callback subsystem.
> If you are talking about the Application Developer's Guide, this
> change is IMHO the only one that is part of an API that Application
> Developers use.
8.6.4 documents asInit(), so should mention asShutdown() nearby.
15.8.1 documents dbCaLinkInit(), so should mention dbCaShutdown(). Mea
culpa that it doesn't cover dbCaRun() or dbCaPause(), although they are
mentioned in section 7.
17.3 documents scanInit(), so should mention scanShutdown() nearby.
10.5 documents errlogInit(), so should mention errlogShutdown() nearby.
> Base development and internal APIs are not supposed to be covered by
> this document, correct?
Maybe, but as demonstrated above the documentation already covers
several internal APIs. If we don't modify those sections when we're
updating the code, the existing docs could start to contain wrong
information, which is a Bad Thing™ and may lead to Broken Window Syndrome.
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown/+merge/190512
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Dec 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
