2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Wed, 04 Dec 2013 18:39:03 -0000
So, where to go with this from here?
My preference would be to look further at the epicsExitCallAtExits() solution, instead of adding all the public Shutdown routines (which also reduces the documentation changes needed). Maybe we could add a global flag to epicsExit.c which the registered routines can check to decide whether they need to do a full clean-up ready for a restart, or just a quick shutdown (I want to avoid them all wasting time freeing memory if the process is about to exit or VxWorks is about to reboot).
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown/+merge/190512
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
[Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~epics-core/epics-base/postdbrprop into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
ANJ, 04 Dec 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
