Subject: |
[Merge] lp:~info-martin-konrad/epics-gateway/epics-gateway-putlog into lp:epics-gateway |
Martin Konrad <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 18 Feb 2014 20:49:23 -0000 |
Martin Konrad has proposed merging lp:~info-martin-konrad/epics-gateway/epics-gateway-putlog into lp:epics-gateway.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~info-martin-konrad/epics-gateway/epics-gateway-putlog/+merge/207029
NSCL's put-logging code. Does not only log machine/user but also the value. In production use at NSCL since quite some time.
The attached diff has been truncated due to its size.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~info-martin-konrad/epics-gateway/epics-gateway-putlog into lp:epics-gateway.
=== added file 'GATEWAY.access'
--- GATEWAY.access 1970-01-01 00:00:00 +0000
+++ GATEWAY.access 2014-02-18 20:49:12 +0000
@@ -0,0 +1,36 @@
+UAG(GatewayAdmin) {gateway,smith}
+UAG(jones) {jones,Jones}
+UAG(engineers) {jones,roberts}
+HAG(engineershost) {snoopy}
+ASG(DEFAULT) {
+ RULE(1,READ)
+ASG(GatewayAdmin) {
+ RULE(1,READ)
+ RULE(1,WRITE,TRAPWRITE){
+ UAG(GatewayAdmin)
+ASG(Beam) {
+ INPA(BeamAccess:access)
+ RULE(1,READ)
+ RULE(1,WRITE,TRAPWRITE) {
+ UAG(jones)
+ CALC("A")
+ASG(PowerSupply) {
+ RULE(1,READ)
+ RULE(1,WRITE){
+ UAG(jones)
+ RULE(1,READ)
+ RULE(1,WRITE) {
+ UAG(engineers)
+ HAG(engineershost)
=== renamed file 'GATEWAY.access' => 'GATEWAY.access.moved'
=== added file 'GATEWAY.command'
--- GATEWAY.command 1970-01-01 00:00:00 +0000
+++ GATEWAY.command 2014-02-18 20:49:12 +0000
@@ -0,0 +1,6 @@
+# R1 - generate a complete PV report to log file
+# R2 - generate a PV summary report to log file
+# R3 - generate an access security report to log file
+# AS - reread the access security file
+#R1
+AS
=== renamed file 'GATEWAY.command' => 'GATEWAY.command.moved'
=== added file 'GATEWAY.pvlist'
--- GATEWAY.pvlist 1970-01-01 00:00:00 +0000
+++ GATEWAY.pvlist 2014-02-18 20:49:12 +0000
@@ -0,0 +1,91 @@
+# Valid forms of the lines in this file:
+# 1) EVALUATION ORDER <eval_order>
+# 2) <pv_name_pattern> DENY [FROM] [<host> ...]
+# 3) <pv_name_pattern> ALIAS <real_pv_name> [<asg> [<asl>]]
+# 4) <pv_name_pattern> ALLOW [<asg> [<asl>]]
+# where:
+# <eval_order> = DENY, ALLOW allow rules take precedence
+# ALLOW, DENY deny rules take precedence (default)
+# <pv_name_pattern> = regular expression that matches PV names
+# <host> = unqualified host name
+# <real_pv_name> = substitution pattern that specifies the real PV name
+# (\0 ... \9 are replaced by matched sub-expressions)
+# <asg> = Access Security Group as specified in AS file [DEFAULT]
+# <asl> = Access Security Level (0 or 1) [1]
+# ORDER:
+# This will set the evaluation order that is used when a client requests
+# a PV. Setting this to "DENY, ALLOW" will allow access to a PV name that matches
+# both a DENY and an ALLOW pattern. "ALLOW, DENY" will make a DENY override an ALLOW
+# for the same variable. (This is the default.)
+# NOTE: Matching DENY FROM patterns (with host names) will always override matching
+# ALLOW patterns.
+# DENY / DENY FROM:
+# The gateway will completely ignore requests for any PV that matches the pattern.
+# Can be used to block the gateway from responding to groups of PVs.
+# Naming hosts (DENY FROM) will block the PVs only for the given hosts (useful to
+# prevent loops caused by forwarding to other gateways).
+# ALIAS:
+# Define an alias and allows it as a pattern for names which the Gateway should serve.
+# For process variable names that match <pv-name-pattern>, the Gateway translates the
+# name into a real process variable name and uses the real name as if it had been the
+# one specified. The <real-pv-name> may contain the special escape sequences \1 ... \9
+# which will be replaced by the nth subexpression matched. See a UNIX book on regular
+# expressions for more information. Access security rules to be used for process
+# variables matched by this pattern may be specified. If not specified, the defaults
+# are the DEFAULT group and level 1. Apart from specifying an alias, this rule is
+# functionally the same as ALLOW.
+# ALLOW:
+# Used to declare PV names which the Gateway should serve. Access security rules to
+# be used for process variables matched by this pattern may be specified. If not
+# specified, the defaults are the DEFAULT group and level 1.
+# Notes:
+# 1) Commands are not case sensitive.
+# 2) Pattern use GNU-style regular expressions. (See the documentation included
+# with the regex library for details on regular expressions.)
+# 3) Any PV not included in an ALLOW command is not allowed access. If no PV list
+# file is specified on the command line, a default rule ".* ALLOW" will be created.
+# 4) The patterns are matched in reverse order. I.e. you should always specify general
+# rules before specific rules.
+# 5) See EPICS access security documentation for creating an access security
+# file for the PV gateway.
+# Below:
+# - make DENY rules override ALLOW rules
+# - requests for PVs starting with Beam: will be allowed according to rules for access
+# security group Beam, similarly for PS using PowerSupply and gateway flags using
+# GatewayAdmin
+# - anything starting with test is not allowed
+# - ps0 ... ps9 are translated to PSCurrent0.ai ... PSCurrent9.ai and are allowed for
+# the PowerSupply group at level 1.
+EVALUATION ORDER ALLOW, DENY
+[0-9].* ALLOW
+[a-z].* ALLOW
+[A-Z].* ALLOW
+Beam:.* ALLOW Beam 1
+PS.* ALLOW PowerSupply 1
+gateway:.*Flag ALLOW GatewayAdmin
+test.* DENY
+ps\([0-9]\) ALIAS PSCurrent\1.ai PowerSupply 1
+# Convert old Gateway internal process variable names
+gateway\.\(.*\) ALIAS gateway:\1
+gateway\.\(.*\)Flag ALIAS gateway:\1Flag GatewayAdmin
+gateway\.alive ALIAS gateway:connected
+gateway\.postEventRate ALIAS gateway:clientPostRate
+# Use DENY FROM and negated regular expressions to prevent loops in reverse
+# gateways while allowing access to the internal PVs.
+# This requires USE_NEG_REGEXP=YES and USE_DENY_FROM=YES in Makefile.
+# !gateway:.* DENY FROM <ip address of reverse gateway>
=== renamed file 'GATEWAY.pvlist' => 'GATEWAY.pvlist.moved'
=== added file 'LICENSE'
--- LICENSE 1970-01-01 00:00:00 +0000
+++ LICENSE 2014-02-18 20:49:12 +0000
@@ -0,0 +1,85 @@
+Copyright (c) 2002 University of Chicago.
+Copyright (c) 2002 Berliner Speicherring-Gesellschaft fuer Synchrotron-
+Strahlung mbH (BESSY).
+All rights reserved.
+The gateway is distributed subject to the following license conditions:
+ SOFTWARE LICENSE AGREEMENT
+ Software: gateway
+ 1. The "Software", below, refers to gateway (in either source code,
+ or binary form and accompanying documentation). Each licensee is
+ addressed as "you" or "Licensee."
+ 2. The copyright holders shown above and their third-party licensors
+ hereby grant Licensee a royalty-free nonexclusive license, subject to
+ the limitations stated herein and U.S. Government license rights.
+ 3. You may modify and make a copy or copies of the Software for use
+ within your organization, if you meet the following conditions:
+ a. Copies in source code must include the copyright notice and this
+ Software License Agreement.
+ b. Copies in binary form must include the copyright notice and this
+ Software License Agreement in the documentation and/or other
+ materials provided with the copy.
+ 4. You may modify a copy or copies of the Software or any portion of it,
+ thus forming a work based on the Software, and distribute copies of
+ such work outside your organization, if you meet all of the following
+ conditions:
+ Software License Agreement;
+ materials provided with the copy;
+ c. Modified copies and works based on the Software must carry
+ prominent notices stating that you changed specified portions of
+ the Software.
+ 5. Portions of the Software resulted from work developed under a U.S.
+ Government contract and are subject to the following license: the
+ Government is granted for itself and others acting on its behalf a
+ paid-up, nonexclusive, irrevocable worldwide license in this computer
+ software to reproduce, prepare derivative works, and perform publicly
+ and display publicly.
+ 6. WARRANTY DISCLAIMER. THE SOFTWARE IS SUPPLIED "AS IS" WITHOUT WARRANTY
+ OF ANY KIND. THE COPYRIGHT HOLDERS, THEIR THIRD PARTY LICENSORS, THE
+ UNITED STATES, THE UNITED STATES DEPARTMENT OF ENERGY, AND THEIR
+ EMPLOYEES: (1) DISCLAIM ANY WARRANTIES, EXPRESS OR IMPLIED, INCLUDING
+ BUT NOT LIMITED TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS
+ FOR A PARTICULAR PURPOSE, TITLE OR NON-INFRINGEMENT, (2) DO NOT ASSUME
+ ANY LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS,
+ OR USEFULNESS OF THE SOFTWARE, (3) DO NOT REPRESENT THAT USE OF THE
+ SOFTWARE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS, (4) DO NOT WARRANT
+ THAT THE SOFTWARE WILL FUNCTION UNINTERRUPTED, THAT IT IS ERROR-FREE
+ OR THAT ANY ERRORS WILL BE CORRECTED.
+ 7. LIMITATION OF LIABILITY. IN NO EVENT WILL THE COPYRIGHT HOLDERS, THEIR
+ THIRD PARTY LICENSORS, THE UNITED STATES, THE UNITED STATES DEPARTMENT
+ OF ENERGY, OR THEIR EMPLOYEES: BE LIABLE FOR ANY INDIRECT, INCIDENTAL,
+ CONSEQUENTIAL, SPECIAL OR PUNITIVE DAMAGES OF ANY KIND OR NATURE,
+ INCLUDING BUT NOT LIMITED TO LOSS OF PROFITS OR LOSS OF DATA, FOR ANY
+ REASON WHATSOEVER, WHETHER SUCH LIABILITY IS ASSERTED ON THE BASIS OF
+ CONTRACT, TORT (INCLUDING NEGLIGENCE OR STRICT LIABILITY), OR
+ OTHERWISE, EVEN IF ANY OF SAID PARTIES HAS BEEN WARNED OF THE
+ POSSIBILITY OF SUCH LOSS OR DAMAGES.
+________________________________________________________________________
+This software is in part copyrighted by the BERLINER SPEICHERRING
+GESELLSCHAFT FUER SYNCHROTRONSTRAHLUNG M.B.H. (BESSY), BERLIN, GERMANY.
+In no event shall BESSY be liable to any party for direct, indirect,
+special, incidental, or consequential damages arising out of the use of
+this software, its documentation, or any derivatives thereof, even if
+BESSY has been advised of the possibility of such damage.
+BESSY specifically disclaims any warranties, including, but not limited
+to, the implied warranties of merchantability, fitness for a particular
+purpose, and non-infringement. This software is provided on an "as is"
+basis, and BESSY has no obligation to provide maintenance, support,
+updates, enhancements, or modifications.
=== renamed file 'LICENSE' => 'LICENSE.moved'
=== added file 'Makefile'
--- Makefile 1970-01-01 00:00:00 +0000
+++ Makefile 2014-02-18 20:49:12 +0000
@@ -0,0 +1,186 @@
+# Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+# National Laboratory.
+# Copyright (c) 2002 Berliner Speicherring-Gesellschaft fuer Synchrotron-
+# Strahlung mbH (BESSY).
+# Copyright (c) 2002 The Regents of the University of California, as
+# Operator of Los Alamos National Laboratory.
+# This file is distributed subject to a Software License Agreement found
+# in the file LICENSE that is included with this distribution.
+# 3.14 Makefile for Gateway
+TOP = ../..
+include $(TOP)/configure/CONFIG
+# Use of GNU regex library (version 0.12) for patterns and aliasing
+# (These should be defined in extensions/config/CONFIG_SITE.Host.xxx)
+# GNU_REGEX_INC = ../../../../regex-0.12
+# GNU_REGEX_LIB = ../../../../regex-0.12
+# use Perl compatible regular expressions
+#USE_PCRE=YES
+# Negative regexp matching: !pattern matches when pattern does not match
+#USE_NEG_REGEXP=YES
+# Enable DENY FROM
+USE_DENY_FROM=YES
+# Optimization
+#HOST_OPT = NO
+# Compiler options
+#USR_CXXFLAGS += -xsb
+# Patches for HPUX / aCC
+# NORMAL to suppress "future errors", needs immediate binding as using shared libs produces core dumps
+ifeq ($(OS_CLASS),hp700)
+ CXXCMPLR=NORMAL
+ USR_LDFLAGS += -Wl,-Bimmediate
+endif
+# Purify
+#PURIFY=YES
+ifeq ($(PURIFY),YES)
+ifeq ($(OS_CLASS),solaris)
+PURIFY_FLAGS = -first-only -chain-length=26 -max_threads=256
+# Put the cache files in the appropriate bin directory
+PURIFY_FLAGS += -always-use-cache-dir -cache-dir=$(shell $(PERL) $(TOOLS)/fullPathName.pl .)
+DEBUGCMD = purify $(PURIFY_FLAGS)
+endif
+endif
+# Quantify
+#QUANTIFY=YES
+ifeq ($(QUANTIFY),YES)
+#QUANTIFY_FLAGS += -measure-timed-calls=user+system
+QUANTIFY_FLAGS += -collection-granularity=function
+QUANTIFY_FLAGS += -use-machine=UltraSparcIII:1002MHz
+QUANTIFY_FLAGS += -max_threads=160
+# QUANTIFY_FLAGS += -record-system-calls=no
+# -measure-timed-calls=elapsed-time (default) gives wall clock time
+# for system calls
+# -measure-timed-calls=user+system gives user+system time
+# -record-system-calls=no gives 0 time for system calls
+# -collection-granularity=function runs faster than default=line
+# -use-machine=UltraSparc:168MHz timing for Nike
+# -use-machine=UltraSparcIII:1002MHz timing for Ctlapps1
+DEBUGCMD = quantify $(QUANTIFY_FLAGS)
+endif
+endif
+# Turn on debug mode
+# USR_CXXFLAGS += -DDEBUG_MODE
+# Turn off Gateway debug calls:
+# USR_CXXFLAGS += -DNODEBUG
+# Use stat PV's
+USR_CXXFLAGS += -DSTAT_PVS
+# Use rate statistics
+USR_CXXFLAGS += -DRATE_STATS
+# Use control PV's
+USR_CXXFLAGS += -DCONTROL_PVS
+# Use heartbeat PV
+#USR_CXXFLAGS += -DHEARTBEAT_PV
+# Use CAS diagnostics statistics
+USR_CXXFLAGS += -DCAS_DIAGNOSTICS
+# Install exception handler and print exceptions to log file
+USR_CXXFLAGS += -DHANDLE_EXCEPTIONS
+ifeq ($(USE_DENY_FROM),YES)
+# Use deny from
+USR_CXXFLAGS += -DUSE_DENYFROM
+endif
+ifeq ($(USE_NEG_REGEXP),YES)
+# Use deny from
+USR_CXXFLAGS += -DUSE_NEG_REGEXP
+endif
+# Reserve file descriptor for fopen to avoid fd limit of 256 on Solaris
+USR_CXXFLAGS_solaris += -DRESERVE_FOPEN_FD
+# USR_INCLUDES += -I$(GNU_REGEX_INC)
+WIN32_RUNTIME=MD
+USR_CXXFLAGS_WIN32 += /DWIN32 /D_WINDOWS
+USR_LDFLAGS_WIN32 += /SUBSYSTEM:CONSOLE
+ifeq ($(USE_PCRE),YES)
+ USR_CXXFLAGS += -DUSE_PCRE
+ USR_SYS_LIBS_DEFAULT += pcre
+else
+ifeq ($(OS_CLASS),WIN32)
+# Use Obj for object libraries and no Obj for import libraries
+ PROD_LIBS = regexObj
+ regexObj_DIR = $(EPICS_EXTENSIONS_LIB)
+else
+ifneq ($(OS_CLASS),Linux)
+ PROD_LIBS = regex
+ regex_DIR = $(EPICS_EXTENSIONS_LIB)
+endif
+endif
+endif
+USR_LIBS_DEFAULT += ca cas asHost gdd Com
+ca_DIR = $(EPICS_BASE_LIB)
+cas_DIR = $(EPICS_BASE_LIB)
+asHost_DIR = $(EPICS_BASE_LIB)
+Com_DIR = $(EPICS_BASE_LIB)
+gdd_DIR = $(EPICS_BASE_LIB)
+gateway_SRCS += gateway.cc
+gateway_SRCS += gatePv.cc
+gateway_SRCS += gateResources.cc
+gateway_SRCS += gateServer.cc
+gateway_SRCS += gateAs.cc
+gateway_SRCS += gateVc.cc
+gateway_SRCS += gateAsyncIO.cc
+gateway_SRCS += gateAsCa.cc
+gateway_SRCS += gateStat.cc
+# need access to casCtx.h
+USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
+PROD_HOST = gateway
+include $(TOP)/configure/RULES
+xxxx:
+ @echo HOST_OPT: $(HOST_OPT)
+ @echo PURIFY: $(PURIFY)
+ @echo PURIFY_FLAGS: $(PURIFY_FLAGS)
+ @echo PURIFYCMD: $(PURIFYCMD)
+ @echo QUANTIFY: $(QUANTIFY)
+ @echo QUANTIFYCMD: $(QUANTIFYCMD)
+ @echo CXX $(CXX)
+ @echo CXXFLAGS $(CXXFLAGS)
+ @echo LINK.cc: $(LINK.cc)
+ @echo LINK.c: $(LINK.c)
+ @echo TARGET_OBJS: $(TARGET_OBJS)
+ @echo PRODNAME_OBJS: $(PRODNAME_OBJS)
+ @echo PROD_LD_OBJS: $(PROD_LD_OBJS)
+ @echo PRODUCT_OBJS: $(PRODUCT_OBJS)
+ @echo PROD_OBJS: $(PROD_OBJS)
+ @echo EPICS_BASE: $(EPICS_BASE)
+ @echo HOST_ARCH: $(HOST_ARCH)
+ @echo ARCH_DEP_LDFLAGS_ML_NO: $(ARCH_DEP_LDFLAGS_ML_NO)
+ @echo ARCH_DEP_LDFLAGS_ML_YES: $(ARCH_DEP_LDFLAGS_ML_YES)
+ @echo ARCH_DEP_LDFLAGS_ML: $(ARCH_DEP_LDFLAGS_ML)
+ @echo ARCH_DEP_LDFLAGS_MD_NO: $(ARCH_DEP_LDFLAGS_MD_NO)
+ @echo ARCH_DEP_LDFLAGS_MD_YES: $(ARCH_DEP_LDFLAGS_MD_YES)
+ @echo ARCH_DEP_LDFLAGS_MD: $(ARCH_DEP_LDFLAGS_MD)
+ @echo ACC_SFLAGS_YES: $(ACC_SFLAGS_YES)
+ @echo ACC_SFLAGS_NO: $(ACC_SFLAGS_NO)
+ @echo SHARED_LIBRARIES: $(SHARED_LIBRARIES)
+ @echo DEBUGCMD: $(DEBUGCMD)
+# **************************** Emacs Editing Sequences *****************
+# Local Variables:
+# mode: makefile
+# End:
=== renamed file 'Makefile' => 'Makefile.moved'
=== added file 'README.1st'
--- README.1st 1970-01-01 00:00:00 +0000
+++ README.1st 2014-02-18 20:49:12 +0000
@@ -0,0 +1,2 @@
+The extension distribution file should be unziped and untared
+in the extensions/src directory.
=== renamed file 'README.1st' => 'README.1st.moved'
=== added file 'S99gateway'
--- S99gateway 1970-01-01 00:00:00 +0000
+++ S99gateway 2014-02-18 20:49:12 +0000
@@ -0,0 +1,21 @@
+#!/bin/sh
+# Solaris rc3 script for EPICS CA gateway
+GATEWAY=/home/helios/GATEWAY/gateway/gateway
+HOME_DIR=/home/helios/GATEWAY/gateway/`/usr/bin/uname -n`
+if [ $1 = "start" ]; then
+ if [ -f $GATEWAY ]; then
+ echo "Starting EPICS CA gateway "
+ /usr/bin/mkdir -p $HOME_DIR
+ $GATEWAY -log gateway.log -cip 164.54.3.255 -sip 164.54.188.65 -home $HOME_DIR -uid 265 -server
+ fi
+else
+ if [ $1 = "stop" ]; then
+ echo "Stopping EPICS CA gateway "
+ $HOME_DIR/gateway.killer
+ fi
+fi
=== renamed file 'S99gateway' => 'S99gateway.moved'
=== added file 'START.server'
--- START.server 1970-01-01 00:00:00 +0000
+++ START.server 2014-02-18 20:49:12 +0000
@@ -0,0 +1,36 @@
+# Clients using gateway as CA concentrator with local loopback driver.
+# Set these variable where clients are run:
+# export EPICS_CA_ADDR_LIST=127.0.0.1
+# export EPICS_CA_AUTO_ADDR_LIST=NO
+# iocpvgateway: -cip 164.54.2.108 - test with PV pvgateway:memuse
+# Clients esing the gateway that is running at the APS (on the 188 network):
+# export EPICS_CA_ADDR_LIST=164.54.189.255
+# Other important variables to remember (gateway sets these)
+# export EPICS_CAS_INTF_ADDR= - IP address where server listens
+# export EPICS_CAS_SERVER_PORT= - port that the CA server uses
+# export EPICS_CA_SERVER_PORT= - port that the CA client library uses
+# Start using a pv list and alias file
+# ./gateway -pv ../PV_LIST -alias ../PV_ALIAS $*
+# Start on chiron using the 2 network as client, the 188 as server
+# ./gateway -sip 164.54.188.29 -cip 164.54.3.255
+# Start as a CA concentrator
+# ./gateway -sip 127.0.0.1 -cip 164.54.3.255
+# Start on an alternate port
+# ./gateway -cport 9990 -sport 9990 $*
+./gateway $*
+# test the gateway in here:
+# cd /home/helios2/srsys/op/adl <--- major adl file directory.
+# medm -x sMain.adl <--- main APS adl file
+# test PV for waveform = SRI:S35DCCT:currentCP
=== renamed file 'START.server' => 'START.server.moved'
=== added directory 'docs'
=== renamed directory 'docs' => 'docs.moved'
=== added file 'docs/AliasGateway.gif'
Binary files docs/AliasGateway.gif 1970-01-01 00:00:00 +0000 and docs/AliasGateway.gif 2014-02-18 20:49:12 +0000 differ
=== added file 'docs/FPAT064.pdf'
--- docs/FPAT064.pdf 1970-01-01 00:00:00 +0000
+++ docs/FPAT064.pdf 2014-02-18 20:49:12 +0000
@@ -0,0 +1,1203 @@
+%PDF-1.4
+%��+100 0 obj <</Linearized 1/L 114625/O 103/E 58060/N 3/T 112577/H [ 995 279]>>
+endobj
+xref
+100 34
+0000000016 00000 n
+0000001445 00000 n
+0000000995 00000 n
+0000001697 00000 n
+0000002137 00000 n
+0000002529 00000 n
+0000002853 00000 n
+0000003392 00000 n
+0000003439 00000 n
+0000003486 00000 n
+0000003533 00000 n
+0000003580 00000 n
+0000003826 00000 n
+0000004066 00000 n
+0000004322 00000 n
+0000004399 00000 n
+0000006717 00000 n
+0000008780 00000 n
+0000010966 00000 n
+0000012999 00000 n
+0000015209 00000 n
+0000017388 00000 n
+0000017424 00000 n
+0000019449 00000 n
+0000021655 00000 n
+0000024325 00000 n
+0000025178 00000 n
+0000026031 00000 n
+0000026884 00000 n
+0000027734 00000 n
+0000037170 00000 n
+0000045858 00000 n
+0000050382 00000 n
+0000001274 00000 n
+trailer
+<</Size 134/Prev 112565/XRefStm 1274/Root 101 0 R/Info 25 0 R/ID[<840dd7da2e0c2f0688bf724042c3b200><c95ad66b1655064f8ad09ec47444d1cb>]>>
+startxref
+0
+%%EOF
+102 0 obj<</Length 186/Filter/FlateDecode/C 201/L 185/O 169/S 86>>stream
+x�```b``�e`r``@ �(ǃ���'�*�I�djj���00�x40CT;�@Z���<�3�`:���ASyE����?Z?0�U|�d�gC�#F/�)�� |
