Subject: |
[Merge] lp:~info-martin-konrad/epics-gateway/putlog into lp:epics-gateway |
Martin Konrad <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 02 Apr 2014 20:00:34 -0000 |
Martin Konrad has proposed merging lp:~info-martin-konrad/epics-gateway/putlog into lp:epics-gateway.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~info-martin-konrad/epics-gateway/putlog/+merge/213921
Add option to compile in and use caPutLog
Your team EPICS Core Developers is requested to review the proposed merge of lp:~info-martin-konrad/epics-gateway/putlog into lp:epics-gateway.
=== modified file 'Makefile'
--- Makefile 2009-09-17 15:45:45 +0000
+++ Makefile 2014-04-02 20:00:01 +0000
@@ -144,6 +144,14 @@
# need access to casCtx.h
USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
+# To compile in caPutLog functionality, define the location of the caPutLog
+# module as 'CAPUTLOG' in the appropriate extensions configure/RELEASE* file
+ifdef CAPUTLOG
+ USR_LIBS_DEFAULT += caPutLog dbIoc
+ USR_CXXFLAGS_DEFAULT += -DALLOW_CAPUTLOG
+ USR_CFLAGS_DEFAULT += -DALLOW_CAPUTLOG
+endif
PROD_HOST = gateway
=== modified file 'gateResources.cc'
--- gateResources.cc 2011-04-05 21:28:22 +0000
+++ gateResources.cc 2014-04-02 20:00:01 +0000
@@ -41,6 +41,12 @@
#include <gddAppTable.h>
#include <dbMapper.h>
+#ifdef ALLOW_CAPUTLOG
+ #include <caPutLog.h>
+ #include <caPutLogTask.h>
+ #include <caPutLogAs.h>
+#endif
// Global variables
gateResources* global_resources;
@@ -108,6 +114,159 @@
return name;
+ We need to define these here, as caPutLog is using dbFldTypes.h defs for
+ DBR_xxx and our code is loading db_access.h defs elsewhere, and thse ARE
+ DIFFERENT.
+ DBR_FLOAT in db_access.h is 6, for example but in dbFldTypes.h that means a
+ DBR_ULONG.
+#define OUR_DBR_STRING 0
+#define OUR_DBR_CHAR 1
+#define OUR_DBR_UCHAR 2
+#define OUR_DBR_SHORT 3
+#define OUR_DBR_USHORT 4
+#define OUR_DBR_LONG 5
+#define OUR_DBR_ULONG 6
+#define OUR_DBR_FLOAT 7
+#define OUR_DBR_DOUBLE 8
+static int gddGetOurType(const gdd *gddVal)
+ switch ( gddVal->primitiveType() ) {
+ case aitEnumInt8 : return(OUR_DBR_CHAR);
+ case aitEnumUint8 : return(OUR_DBR_UCHAR);
+ case aitEnumInt16 : return(OUR_DBR_SHORT);
+ case aitEnumEnum16 : return(OUR_DBR_USHORT);
+ case aitEnumUint16 : return(OUR_DBR_USHORT);
+ case aitEnumInt32 : return(OUR_DBR_LONG);
+ case aitEnumUint32 : return(OUR_DBR_ULONG);
+ case aitEnumFloat32 : return(OUR_DBR_FLOAT);
+ case aitEnumFloat64 : return(OUR_DBR_DOUBLE);
+ case aitEnumFixedString:
+ case aitEnumString:
+ default:
+ return(OUR_DBR_STRING);
+static int gddToVALUE(const gdd *gddVal, short ourdbrtype, VALUE *valueStruct)
+ memset(valueStruct,0,sizeof(VALUE));
+ switch (ourdbrtype) {
+ case OUR_DBR_CHAR: {
+ aitInt8 x;
+ gddVal->get(x);
+ valueStruct->v_char = x;
+ return(0);
+ case OUR_DBR_UCHAR: {
+ aitUint8 x;
+ gddVal->get(x);
+ valueStruct->v_uchar = x;
+ return(0);
+ case OUR_DBR_SHORT: {
+ aitInt16 x;
+ gddVal->get(x);
+ valueStruct->v_short = x;
+ return(0);
+ case OUR_DBR_USHORT: {
+ aitUint16 x;
+ gddVal->get(x);
+ valueStruct->v_ushort = x;
+ return(0);
+ case OUR_DBR_LONG: {
+ aitInt32 x;
+ gddVal->get(x);
+ valueStruct->v_long = x;
+ return(0);
+ case OUR_DBR_ULONG: {
+ aitUint32 x;
+ gddVal->get(x);
+ valueStruct->v_ulong = x;
+ return(0);
+ case OUR_DBR_FLOAT: {
+ aitFloat32 x;
+ gddVal->get(x);
+ valueStruct->v_float = x;
+ return(0);
+ case OUR_DBR_DOUBLE: {
+ aitFloat64 x;
+ gddVal->get(x);
+ valueStruct->v_double = x;
+ return(0);
+ case OUR_DBR_STRING:
+ default: {
+ aitString x;
+ gddVal->get(x);
+ int len = strlen(x);
+ int siz = sizeof(valueStruct->v_string);
+ if (len >= siz) {
+ strncpy(valueStruct->v_string,x,siz-1);
+ valueStruct->v_string[siz-1] = 0;
+ } else {
+ strcpy(valueStruct->v_string,x);
+ return(0);
+static char *debugVALUEString(VALUE *v, int ourdbrtype, char *buffer)
+ sprintf(buffer,"v_char %d",v->v_char);
+ break;
+ sprintf(buffer,"v_uchar %d",v->v_uchar);
+ break;
+ sprintf(buffer,"v_short %hd",v->v_short);
+ break;
+ sprintf(buffer,"v_ushort %hu",v->v_ushort);
+ break;
+ sprintf(buffer,"v_long %ld",v->v_long);
+ break;
+ sprintf(buffer,"v_ulong %lu",v->v_ulong);
+ break;
+ sprintf(buffer,"v_float %g",v->v_float);
+ break;
+ sprintf(buffer,"v_double %g",v->v_double);
+ break;
+ sprintf(buffer,"v_string '%s'",v->v_string);
+ break;
+ default:
+ sprintf(buffer,"unknown type %d",ourdbrtype);
+ return(buffer);
+#endif // ALLOW_CAPUTLOG
gateResources::gateResources(void)
as = NULL;
@@ -130,6 +289,9 @@
// Miscellaneous initializations
putlog_file=NULL;
+ caputlog_address=NULL;
+#endif
putlogFp=NULL;
report_file=strDup(GATE_REPORT_FILE);
debug_level=0;
@@ -168,6 +330,10 @@
if(command_file) delete [] command_file;
if(putlog_file) delete [] putlog_file;
if(report_file) delete [] report_file;
+ caPutLog_Term();
+ if (caputlog_address) delete [] caputlog_address;
+#endif
int gateResources::appValue=0;
@@ -207,6 +373,62 @@
return 0;
+int gateResources::setCaPutlogAddress(const char* address)
+ if (caputlog_address) {
+ delete [] caputlog_address;
+ caputlog_address = strDup(address);
+ return 0;
+int gateResources::caPutLog_Init(void)
+ return caPutLogInit(caputlog_address,caPutLogAll);
+ return 1;
+void gateResources::caPutLog_Term(void)
+ caPutLogTaskStop();
+void gateResources::caPutLog_Send
+ (const char *user,
+ const char *host,
+ const char *pvname,
+ const gdd *old_value,
+ const gdd *new_value)
+ if ((! new_value) || (new_value->primitiveType() == aitEnumInvalid)) return;
+ // get memory for a LOGDATA item from caPutLog's free list
+ LOGDATA *pdata = caPutLogDataCalloc();
+ if (pdata == NULL) {
+ errlogPrintf("gateResources::caPutLogSend: memory allocation failed\n");
+ return;
+ strcpy(pdata->userid,user);
+ strcpy(pdata->hostid,host);
+ strcpy(pdata->pv_name,pvname);
+ pdata->pfield = (void *) pvname;
+ pdata->type = gddGetOurType(new_value);
+ gddToVALUE(new_value,pdata->type,&pdata->new_value.value);
+ new_value->getTimeStamp(&pdata->new_value.time);
+ if ((old_value) && (old_value->primitiveType() != aitEnumInvalid) && (gddGetOurType(old_value) == pdata->type)) {
+ gddToVALUE(old_value,pdata->type,&pdata->old_value);
+ } else {
+ // if no usable old_value provided, fill in data.old_value with copy of new value
+ // as there's no way to flag a VALUE struct as invalid
+ memcpy(&pdata->old_value,&pdata->new_value.value,sizeof(VALUE));
+ caPutLogTaskSend(pdata);
int gateResources::setReportFile(const char* file)
=== modified file 'gateResources.h'
--- gateResources.h 2007-07-10 20:08:21 +0000
+++ gateResources.h 2014-04-02 20:00:01 +0000
@@ -49,6 +49,7 @@
#endif
#include "cadef.h"
+#include "gdd.h"
#include "gateVersion.h"
@@ -132,6 +133,19 @@
gateAs* getAs(void);
bool isAsSetUp(void) const { return as?true:false; }
+ int setCaPutlogAddress(const char* address);
+ const char* caputlogAddress(void) const { return caputlog_address?caputlog_address:"NULL"; }
+ int hasCaPutlogAddress(void) const { return caputlog_address?1:0; }
+ int caPutLog_Init(void);
+ void caPutLog_Send(const char *user,
+ const char *host,
+ const gdd *new_value);
+ void caPutLog_Term(void);
+#endif
// here for convenience
static int appValue;
static int appEnum;
@@ -144,6 +158,9 @@
private:
char *access_file, *pvlist_file, *command_file, *putlog_file, *report_file;
+ char *caputlog_address;
+#endif
int debug_level, ro;
bool serverMode;
bool cacheMode;
=== modified file 'gateStat.cc'
--- gateStat.cc 2005-02-11 22:55:10 +0000
+++ gateStat.cc 2014-04-02 20:00:01 +0000
@@ -92,6 +92,15 @@
pStat && pStat->getName()?pStat->getName():"Unknown");
fflush(fp);
+ if (global_resources->hasCaPutlogAddress()) {
+ global_resources->caPutLog_Send(asclient->user() ? asclient->user() : "Unknown",
+ asclient->host() ? asclient->host() : "Unknown",
+ (pStat && pStat->getName()) ? pStat->getName() : "Unknown",
+ (pStat) ? pStat->pvData() : NULL,
+ &value);
+#endif
// Call the non-virtual-function write() in the gateStat
=== modified file 'gateStat.h'
--- gateStat.h 2004-06-11 15:29:57 +0000
+++ gateStat.h 2014-04-02 20:00:01 +0000
@@ -78,6 +78,8 @@
void report(FILE *fp);
+ gdd* pvData(void) const { return value; }
protected:
gdd *value;
gdd *attr;
=== modified file 'gateVc.cc'
--- gateVc.cc 2009-08-31 19:57:25 +0000
+++ gateVc.cc 2014-04-02 20:00:01 +0000
@@ -244,6 +244,15 @@
vc && vc->getName()?vc->getName():"Unknown");
fflush(fp);
+ global_resources->caPutLog_Send(user ? user : "Unknown",
+ host ? host : "Unknown",
+ (vc && vc->getName()) ? vc->getName() : "Unknown",
+ (vc) ? vc->eventData() : NULL,
+ &value);
+#endif
// Call the non-virtual-function write() in the gateVcData
@@ -271,6 +280,15 @@
fflush(fp);
+ &value);
+#endif
=== modified file 'gateway.cc'
--- gateway.cc 2007-07-10 20:08:21 +0000
+++ gateway.cc 2014-04-02 20:00:01 +0000
@@ -102,6 +102,7 @@
// -access file_name = access security file
// -command file_name = USR1 command list file
// -putlog file_name = putlog file
+// -caputlog = address (IP:port) for caPutLog server
// -report file_name = report file
// -home directory = the program's home directory
// -connect_timeout number = clear PV connect requests every number seconds
@@ -123,6 +124,7 @@
// process variable list file = gateway.pvlist
// USR1 command list file = gateway.command
// putlog file = gateway.putlog
+// caputlog address = none, not used
// report file = gateway.report
// log file = gateway.log
// debug level = 0 (none)
@@ -166,7 +168,9 @@
#define PARM_SERVER_IGNORE_IP 25
#define PARM_CACHE 26
#define PARM_ARCHIVE 27
+ #define PARM_CAPUTLOG 28
+#endif
#define HOME_DIR_SIZE 300
@@ -184,6 +188,9 @@
static const char *log_file=NULL;
static const char *putlog_file=NULL;
static const char *report_file=NULL;
+static const char *caputlog_address=NULL;
+#endif
#ifndef WIN32
static pid_t parent_pid;
#endif
@@ -205,6 +212,9 @@
{ "-access", 7, PARM_ACCESS, "file_name" },
{ "-command", 8, PARM_COMMAND, "file_name" },
{ "-putlog", 7, PARM_PUTLOG, "file_name" },
+ { "-caputlog", 9, PARM_CAPUTLOG, "address (ip:port)" },
+#endif
{ "-report", 7, PARM_REPORT, "file_name" },
{ "-home", 5, PARM_HOME, "directory" },
{ "-sip", 4, PARM_SERVER_IP, "IP_address" },
@@ -423,6 +433,9 @@
fprintf(fp,"# pvlist file=<%s>\n",global_resources->listFile());
fprintf(fp,"# command file=<%s>\n",global_resources->commandFile());
fprintf(fp,"# putlog file=<%s>\n",global_resources->putlogFile());
+ fprintf(fp,"# caputlog address=<%s>\n",global_resources->caputlogAddress());
+#endif
fprintf(fp,"# report file=<%s>\n",global_resources->reportFile());
fprintf(fp,"# debug level=%d\n",global_resources->debugLevel());
fprintf(fp,"# dead timeout=%ld\n",global_resources->deadTimeout());
@@ -622,6 +635,22 @@
system("printenv | grep EPICS");
fflush(stdout); fflush(stderr);
#endif
+ // start caPutLog in global_resources, if user defined a caPutLog ip:port address
+ int caputlog_status = global_resources->caPutLog_Init();
+ if (caputlog_status != 0) {
+ fprintf(stderr,"%s global_resources caPutLogInit failed, aborting\n",timeStamp());
+ fflush(stdout);
+ fflush(stderr);
+ if (server) {
+ delete server;
+ server = NULL;
+ return 1;
+#endif
// Start the gateServer
try {
@@ -834,6 +863,18 @@
break;
+ case PARM_CAPUTLOG:
+ if(++i>=argc) no_error=0;
+ else {
+ if(argv[i][0]=='-') no_error=0;
+ else {
+ caputlog_address=argv[i];
+ not_done=0;
+ break;
+#endif
case PARM_REPORT:
else {
@@ -1062,6 +1103,9 @@
fprintf(stderr,"\tpvlist=%s\n",gr->listFile());
fprintf(stderr,"\tcommand=%s\n",gr->commandFile());
fprintf(stderr,"\tputlog=%s\n",gr->putlogFile());
+ fprintf(stderr,"\tcaputlog=%s\n",gr->caputlogAddress());
+#endif
fprintf(stderr,"\treport=%s\n",gr->reportFile());
fprintf(stderr,"\tdead=%ld\n",gr->deadTimeout());
fprintf(stderr,"\tconnect=%ld\n",gr->connectTimeout());
@@ -1113,6 +1157,9 @@
if(pvlist_file) gr->setListFile(pvlist_file);
if(command_file) gr->setCommandFile(command_file);
if(putlog_file) gr->setPutlogFile(putlog_file);
+ if(caputlog_address) gr->setCaPutlogAddress(caputlog_address);
+#endif
if(report_file) gr->setReportFile(report_file);
//set caching and archive mode
@@ -1263,6 +1310,9 @@
fprintf(stderr," list file = <%s>\n",gr->listFile());
fprintf(stderr," command file = <%s>\n",gr->commandFile());
fprintf(stderr," putlog file = <%s>\n",gr->putlogFile());
+ fprintf(stderr," caputlog address = <%s>\n",gr->caputlogAddress());
+#endif
fprintf(stderr," report file = <%s>\n",gr->reportFile());
fprintf(stderr," debug level = %d\n",gr->debugLevel());
fprintf(stderr," connect timeout = %ld\n",gr->connectTimeout());
- Re: [Merge] lp:~info-martin-konrad/epics-gateway/putlog into lp:epics-gateway Ralph Lange
- Re: [Merge] lp:~info-martin-konrad/epics-gateway/putlog into lp:epics-gateway Martin Konrad
Re: caPutLog support for gateway Andrew Johnson
Build failed in Jenkins: epics-base-3.14-rtems #10 APS Jenkins
<2014>
2025
2026
Jenkins build is back to normal : epics-base-3.15-win32s #4 APS Jenkins
<2014>
2025
2026
