Hello All,
I guess many EPICS users, especially beginners, had problems when using the command "caget" to read large waveform data because they forgot to reconfigure EPICS_CA_MAX_ARRAY_BYTES to a bigger number or they didn't know how to configure this parameter. Now, this problem seems to be fixed. See attached patch or .c file. I tested it on Debian 6 / gcc 4.4.5 / base-3.14.12.2.
I hope no users would use the command "camonitor" for big waveform data. Auto-configuring of EPICS_CA_MAX_ARRAY_BYTES in camonitor seems more complicated.
Two years ago, there were discussions about automatically resizing max_array_bytes: http://www.aps.anl.gov/epics/tech-talk/2012/msg02136.php . I have an idea about how to implement this on the ioc side (RSRV), but no progress has been made yet. We just successfully completed NSLS-II Storage Ring phase-I commissioning and our machine is in maintenance. So, I have some free time to work on this again.
All are welcomed to test the attached caget on Windows, Mac, and other Linux distros. Any idea & suggestion is welcomed!
Yong --- src/catools/caget.c.orig 2014-06-04 11:00:41.760259462 -0400
+++ src/catools/caget.c 2014-06-05 14:29:54.897362881 -0400
@@ -37,6 +37,10 @@
#include "tool_lib.h"
+#include "envDefs.h"
+#include "caProto.h"
+#include <stdlib.h>
#define VALID_DOUBLE_DIGITS 18 /* Max usable precision for a double */
#define PEND_EVENT_SLICES 5 /* No. of pend_event slices for callback requests */
@@ -389,6 +393,13 @@
LINE_BUFFER(stdout); /* Configure stdout buffering */
+ unsigned long nElems = 0;
+ long maxBytesAsALong = 0;
+ unsigned long bytes = 0;
+ unsigned long minBytes = 0;
+ unsigned headerSize;
+ char strMinBytes[17];
while ((opt = getopt(argc, argv, ":taicnhsSe:f:g:l:#:d:0:w:p:F:")) != -1) {
switch (opt) {
case 'h': /* Print usage */
@@ -520,14 +531,15 @@
fprintf(stderr, "No pv name specified. ('caget -h' for help.)\n");
return 1;
- /* Start up Channel Access */
+ /* Start up Channel Access */
result = ca_context_create(ca_disable_preemptive_callback);
if (result != ECA_NORMAL) {
fprintf(stderr, "CA error %s occurred while trying "
"to start channel access.\n", ca_message(result));
return 1;
/* Allocate PV structure array */
pvs = calloc (nPvs, sizeof(pv));
@@ -543,6 +555,53 @@
connect_pvs(pvs, nPvs);
+ /*get the value of EPICS_CA_MAX_ARRAY_BYTES*/
+ if (0 != envGetLongConfigParam ( &EPICS_CA_MAX_ARRAY_BYTES, &maxBytesAsALong )){
+ printf("Odd: can't get the value of EPICS_CA_MAX_ARRAY_BYTES\n");
+ maxBytesAsALong = 1024*16u;
+ /*minimum bytes required for the ca_get: element * sizeof(native-field-type) + ca-header*/
+ for (n = 0; n < nPvs; n++) {
+ nElems = ca_element_count(pvs[n].chid);
+ if (nElems < 1) {/*disconnected PV*/
+ continue;
+ pvs[n].dbfType = ca_field_type(pvs[n].chid);
+ bytes = nElems * dbr_size[pvs[n].dbfType];
+ if (bytes > minBytes) {
+ minBytes = bytes;
+ /*codes stolen from rsrv_init()*/
+ headerSize = sizeof ( caHdr ) + 2 * sizeof ( ca_uint32_t );
+ if ( minBytes < 0xffffffff - headerSize) {
+ minBytes += headerSize;
+ else {
+ minBytes = 0xffffffff;
+ /*big operation: reconfigure EPICS_CA_MAX_ARRAY_BYTES, clear channels, destroy context ...*/
+ if (maxBytesAsALong < minBytes) {
+ sprintf(strMinBytes, "%ld", minBytes);
+ /*epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", strMinBytes);*/
+ if (0 != setenv("EPICS_CA_MAX_ARRAY_BYTES", strMinBytes, 1)){
+ printf("Odd: can't reconfigure EPICS_CA_MAX_ARRAY_BYTES to %d\n", minBytes);
+ /*clearing channel seems not enough, have to start over:
+ clear channels, destroy context and recreate it, then connect pvs again
+ if (ECA_NORMAL != ca_clear_channel(pvs[n].chid)){
+ printf("Odd: can't clear channel\n");
+ ca_context_destroy();
+ ca_context_create(ca_disable_preemptive_callback);
+ connect_pvs(pvs, nPvs);
/* Read and print data */
result = caget(pvs, nPvs, request, format, type, count);
* Copyright (c) 2009 Helmholtz-Zentrum Berlin fuer Materialien und Energie.
* Copyright (c) 2006 Diamond Light Source Ltd.
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* Copyright (c) 2002 Berliner Elektronenspeicherringgesellschaft fuer
* Synchrotronstrahlung.
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
* Author: Ralph Lange (BESSY)
* Modification History
* 2006/01/17 Malcolm Walters (Tessella/Diamond Light Source)
* Fixed problem with "-c -w 0" hanging forever
* 2008/04/16 Ralph Lange (BESSY)
* Updated usage info
* 2009/03/31 Larry Hoff (BNL)
* Added field separators
* 2009/04/01 Ralph Lange (HZB/BESSY)
* Added support for long strings (array of char) and quoting of nonprintable characters
#include <stdio.h>
#include <string.h>
#include <epicsStdlib.h>
#include <epicsString.h>
#include <alarm.h>
#include <cadef.h>
#include <epicsGetopt.h>
#include <stdlib.h>
/* Different output formats */
typedef enum { plain, terse, all, specifiedDbr } OutputT;
/* Different request types */
typedef enum { get, callback } RequestT;
static int nConn = 0; /* Number of connected PVs */
static int nRead = 0; /* Number of channels that were read */
static int floatAsString = 0; /* Flag: fetch floats as string */
static void usage (void)
fprintf (stderr, "\nUsage: caget [options] <PV name> ...\n\n"
" -h: Help: Print this message\n"
"Channel Access options:\n"
" -w <sec>: Wait time, specifies CA timeout, default is %f second(s)\n"
" -c: Asynchronous get (use ca_get_callback and wait for completion)\n"
" -p <prio>: CA priority (0-%u, default 0=lowest)\n"
"Format options:\n"
" Default output format is \"name value\"\n"
" -t: Terse mode - print only value, without name\n"
" -a: Wide mode \"name timestamp value stat sevr\" (read PVs as DBR_TIME_xxx)\n"
" -d <type>: Request specific dbr type; use string (DBR_ prefix may be omitted)\n"
" or number of one of the following types:\n"
" DBR_STRING 0 DBR_STS_FLOAT 9 DBR_TIME_LONG 19 DBR_CTRL_SHORT 29\n"
" DBR_INT 1 DBR_STS_ENUM 10 DBR_TIME_DOUBLE 20 DBR_CTRL_INT 29\n"
" DBR_SHORT 1 DBR_STS_CHAR 11 DBR_GR_STRING 21 DBR_CTRL_FLOAT 30\n"
" DBR_FLOAT 2 DBR_STS_LONG 12 DBR_GR_SHORT 22 DBR_CTRL_ENUM 31\n"
" DBR_ENUM 3 DBR_STS_DOUBLE 13 DBR_GR_INT 22 DBR_CTRL_CHAR 32\n"
" DBR_CHAR 4 DBR_TIME_STRING 14 DBR_GR_FLOAT 23 DBR_CTRL_LONG 33\n"
" DBR_LONG 5 DBR_TIME_INT 15 DBR_GR_ENUM 24 DBR_CTRL_DOUBLE 34\n"
" DBR_DOUBLE 6 DBR_TIME_SHORT 15 DBR_GR_CHAR 25 DBR_STSACK_STRING 37\n"
" DBR_STS_STRING 7 DBR_TIME_FLOAT 16 DBR_GR_LONG 26 DBR_CLASS_NAME 38\n"
" DBR_STS_SHORT 8 DBR_TIME_ENUM 17 DBR_GR_DOUBLE 27\n"
" DBR_STS_INT 8 DBR_TIME_CHAR 18 DBR_CTRL_STRING 28\n"
"Enum format:\n"
" -n: Print DBF_ENUM value as number (default is enum string)\n"
"Arrays: Value format: print number of requested values, then list of values\n"
" Default: Print all values\n"
" -# <count>: Print first <count> elements of an array\n"
" -S: Print array of char as a string (long string)\n"
"Floating point type format:\n"
" Default: Use %%g format\n"
" -e <nr>: Use %%e format, with a precision of <nr> digits\n"
" -f <nr>: Use %%f format, with a precision of <nr> digits\n"
" -g <nr>: Use %%g format, with a precision of <nr> digits\n"
" -s: Get value as string (honors server-side precision)\n"
" -lx: Round to long integer and print as hex number\n"
" -lo: Round to long integer and print as octal number\n"
" -lb: Round to long integer and print as binary number\n"
"Integer number format:\n"
" Default: Print as decimal number\n"
" -0x: Print as hex number\n"
" -0o: Print as octal number\n"
" -0b: Print as binary number\n"
"Alternate output field separator:\n"
" -F <ofs>: Use <ofs> as an alternate output field separator\n"
"\nExample: caget -a -f8 my_channel another_channel\n"
" (uses wide output format, doubles are printed as %%f with precision of 8)\n\n"
, DEFAULT_TIMEOUT, CA_PRIORITY_MAX);
* Function: event_handler
* Description: CA event_handler for request type callback
* Allocates the dbr structure and copies the data
* Arg(s) In: args - event handler args (see CA manual)
static void event_handler (evargs args)
pv* ppv = args.usr;
ppv->status = args.status;
if (args.status == ECA_NORMAL)
ppv->dbrType = args.type;
ppv->value = calloc(1, dbr_size_n(args.type, args.count));
memcpy(ppv->value, args.dbr, dbr_size_n(args.type, args.count));
ppv->nElems = args.count;
nRead++;
* Function: caget
* Description: Issue read requests, wait for incoming data
* and print the data according to the selected format
* Arg(s) In: pvs - Pointer to an array of pv structures
* nPvs - Number of elements in the pvs array
* request - Request type
* format - Output format
* dbrType - Requested dbr type
* reqElems - Requested number of (array) elements
* Return(s): Error code: 0 = OK, 1 = Error
static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
chtype dbrType, unsigned long reqElems)
unsigned int i;
int n, result;
unsigned long nElems;
/* Set up pvs structure */
/* Get natural type and array count */
pvs[n].dbrType = dbrType;
/* Set up value structures */
if (format != specifiedDbr)
pvs[n].dbrType = dbf_type_to_DBR_TIME(pvs[n].dbfType); /* Use native type */
if (dbr_type_is_ENUM(pvs[n].dbrType)) /* Enums honour -n option */
if (enumAsNr) pvs[n].dbrType = DBR_TIME_INT;
else pvs[n].dbrType = DBR_TIME_STRING;
else if (floatAsString &&
(dbr_type_is_FLOAT(pvs[n].dbrType) || dbr_type_is_DOUBLE(pvs[n].dbrType)))
/* Issue CA request */
if (ca_state(pvs[n].chid) == cs_conn)
nConn++;
pvs[n].onceConnected = 1;
if (request == callback)
/* Event handler will allocate value and set nElems */
pvs[n].reqElems = reqElems > nElems ? nElems : reqElems;
result = ca_array_get_callback(pvs[n].dbrType,
pvs[n].reqElems,
pvs[n].chid,
event_handler,
(void*)&pvs[n]);
} else {
/* We allocate value structure and set nElems */
pvs[n].nElems = reqElems && reqElems < nElems ? reqElems : nElems;
pvs[n].value = calloc(1, dbr_size_n(pvs[n].dbrType, pvs[n].nElems));
if (!pvs[n].value) {
fprintf(stderr,"Memory allocation failed\n");
return 1;
result = ca_array_get(pvs[n].dbrType,
pvs[n].nElems,
pvs[n].chid,
pvs[n].value);
pvs[n].status = result;
} else {
pvs[n].status = ECA_DISCONN;
if (!nConn) return 1; /* No connection? We're done. */
/* Wait for completion */
result = ca_pend_io(caTimeout);
if (result == ECA_TIMEOUT)
fprintf(stderr, "Read operation timed out: some PV data was not read.\n");
if (request == callback) /* Also wait for callbacks */
if (caTimeout != 0)
double slice = caTimeout / PEND_EVENT_SLICES;
for (n = 0; n < PEND_EVENT_SLICES; n++)
ca_pend_event(slice);
if (nRead >= nConn) break;
if (nRead < nConn)
} else {
/* For 0 timeout keep waiting until all are done */
while (nRead < nConn) {
ca_pend_event(1.0);
/* Print the data */
switch (format) {
case plain: /* Emulate old caget behaviour */
if (pvs[n].nElems <= 1 && fieldSeparator == ' ') printf("%-30s", pvs[n].name);
else printf("%s", pvs[n].name);
printf("%c", fieldSeparator);
case terse:
if (pvs[n].status == ECA_DISCONN)
printf("*** not connected\n");
else if (pvs[n].status == ECA_NORDACCESS)
printf("*** no read access\n");
else if (pvs[n].status != ECA_NORMAL)
printf("*** CA error %s\n", ca_message(pvs[n].status));
else if (pvs[n].value == 0)
printf("*** no data available (timeout)\n");
else
if (charArrAsStr && dbr_type_is_CHAR(pvs[n].dbrType) && (reqElems || pvs[n].nElems > 1)) {
dbr_char_t *s = (dbr_char_t*) dbr_value_ptr(pvs[n].value, pvs[n].dbrType);
int dlen = epicsStrnEscapedFromRawSize((char*)s, strlen((char*)s));
char *d = calloc(dlen+1, sizeof(char));
if(d) {
epicsStrnEscapedFromRaw(d, dlen+1, (char*)s, strlen((char*)s));
printf("%s", d);
free(d);
} else {
fprintf(stderr,"Failed to allocate space for escaped string\n");
} else {
if (reqElems || pvs[n].nElems > 1) printf("%lu%c", pvs[n].nElems, fieldSeparator);
for (i=0; i<pvs[n].nElems; ++i) {
if (i) printf ("%c", fieldSeparator);
printf("%s", val2str(pvs[n].value, pvs[n].dbrType, i));
printf("\n");
break;
case all:
print_time_val_sts(&pvs[n], reqElems);
break;
case specifiedDbr:
printf("%s\n", pvs[n].name);
printf(" *** not connected\n");
printf(" *** no read access\n");
printf(" *** CA error %s\n", ca_message(pvs[n].status));
else
printf(" Native data type: %s\n",
dbf_type_to_text(pvs[n].dbfType));
printf(" Request type: %s\n",
dbr_type_to_text(pvs[n].dbrType));
if (pvs[n].dbrType == DBR_CLASS_NAME)
printf(" Class Name: %s\n",
*((dbr_string_t*)dbr_value_ptr(pvs[n].value,
pvs[n].dbrType)));
else {
printf(" Element count: %lu\n"
" Value: ",
pvs[n].nElems);
if(d) {
printf("%s", d);
free(d);
} else {
} else {
printf("\n");
if (pvs[n].dbrType > DBR_DOUBLE) /* Extended type extra info */
printf("%s\n", dbr2str(pvs[n].value, pvs[n].dbrType));
break;
default :
break;
return 0;
* Function: main
* Description: caget main()
* Evaluate command line options, set up CA, connect the
* channels, collect and print the data as requested
* Arg(s) In: [options] <pv-name> ...
* Arg(s) Out: none
* Return(s): Standard return code (0=success, 1=error)
static void complainIfNotPlainAndSet (OutputT *current, const OutputT requested)
if (*current != plain)
fprintf(stderr,
"Options t,d,a are mutually exclusive. "
"('caget -h' for help.)\n");
*current = requested;
int main (int argc, char *argv[])
int n;
int result; /* CA result */
OutputT format = plain; /* User specified format */
RequestT request = get; /* User specified request type */
IntFormatT outType; /* Output type */
int count = 0; /* 0 = not specified by -# option */
int opt; /* getopt() current option */
int type = -1; /* getopt() data type argument */
int digits = 0; /* getopt() no. of float digits */
int nPvs; /* Number of PVs */
pv* pvs; /* Array of PV structures */
switch (opt) {
usage();
return 0;
case 't': /* Terse output mode */
complainIfNotPlainAndSet(&format, terse);
break;
case 'a': /* Wide output mode */
complainIfNotPlainAndSet(&format, all);
break;
case 'c': /* Callback mode */
request = callback;
break;
case 'd': /* Data type specification */
complainIfNotPlainAndSet(&format, specifiedDbr);
/* Argument (type) may be text or number */
if (sscanf(optarg, "%d", &type) != 1)
dbr_text_to_type(optarg, type);
if (type == -1) /* Invalid? Try prefix DBR_ */
char str[30] = "DBR_";
strncat(str, optarg, 25);
dbr_text_to_type(str, type);
if (type < DBR_STRING || type > DBR_CLASS_NAME
|| type == DBR_PUT_ACKT || type == DBR_PUT_ACKS)
fprintf(stderr, "Requested dbr type out of range "
"or invalid - ignored. ('caget -h' for help.)\n");
format = plain;
break;
case 'n': /* Print ENUM as index numbers */
enumAsNr = 1;
break;
case 'w': /* Set CA timeout value */
if(epicsScanDouble(optarg, &caTimeout) != 1)
fprintf(stderr, "'%s' is not a valid timeout value "
"- ignored. ('caget -h' for help.)\n", optarg);
caTimeout = DEFAULT_TIMEOUT;
break;
case '#': /* Array count */
if (sscanf(optarg,"%d", &count) != 1)
fprintf(stderr, "'%s' is not a valid array element count "
count = 0;
break;
case 'p': /* CA priority */
if (sscanf(optarg,"%u", &caPriority) != 1)
fprintf(stderr, "'%s' is not a valid CA priority "
caPriority = DEFAULT_CA_PRIORITY;
if (caPriority > CA_PRIORITY_MAX) caPriority = CA_PRIORITY_MAX;
break;
case 's': /* Select string dbr for floating type data */
floatAsString = 1;
break;
case 'S': /* Treat char array as (long) string */
charArrAsStr = 1;
break;
case 'e': /* Select %e/%f/%g format, using <arg> digits */
case 'f':
case 'g':
if (sscanf(optarg, "%d", &digits) != 1)
fprintf(stderr,
"Invalid precision argument '%s' "
"for option '-%c' - ignored.\n", optarg, opt);
else
if (digits>=0 && digits<=VALID_DOUBLE_DIGITS)
sprintf(dblFormatStr, "%%-.%d%c", digits, opt);
else
fprintf(stderr, "Precision %d for option '-%c' "
"out of range - ignored.\n", digits, opt);
break;
case 'l': /* Convert to long and use integer format */
case '0': /* Select integer format */
switch ((char) *optarg) {
case 'x': outType = hex; break; /* x print Hex */
case 'b': outType = bin; break; /* b print Binary */
case 'o': outType = oct; break; /* o print Octal */
default :
outType = dec;
fprintf(stderr, "Invalid argument '%s' "
if (outType != dec) {
if (opt == '0') {
type = DBR_LONG;
outTypeI = outType;
} else {
outTypeF = outType;
break;
case 'F': /* Store this for output and tool_lib formatting */
fieldSeparator = (char) *optarg;
break;
case '?':
fprintf(stderr,
"Unrecognized option: '-%c'. ('caget -h' for help.)\n",
optopt);
return 1;
case ':':
fprintf(stderr,
"Option '-%c' requires an argument. ('caget -h' for help.)\n",
optopt);
return 1;
default :
usage();
return 1;
nPvs = argc - optind; /* Remaining arg list are PV names */
if (nPvs < 1)
return 1;
return 1;
if (!pvs)
fprintf(stderr, "Memory allocation for channel structures failed.\n");
return 1;
/* Connect channels */
for (n = 0; optind < argc; n++, optind++)
pvs[n].name = argv[optind] ; /* Copy PV names from command line */
continue;
minBytes = bytes;
else {
/* Shut down Channel Access */
return result;
- Re: auto-configure EPICS_CA_MAX_ARRAY_BYTES in catools/caget Eric Norum
Jenkins build is back to stable : epics-base-3.15 #54 APS Jenkins
<2014>
2025
2026
<2014>
2025
2026
