On 7/10/14, 12:29 PM, Andrew Johnson wrote:
> Please look through the list of projects suggested for the Codeathon on
> the Wiki page and suggest any additional suitable projects that should
> get done before the 3.15.0.2 release.
Hi, Andrew.
Here's my wish list:
* Add dbpf option or new command (e.g. dbcaPutWait) that uses CA to wait
for completion.
* Add routine to wait for a CA link field or list of fields
to connect (e.g. dbcaWaitConnected). See Tech-Talk thread
<http://www.aps.anl.gov/epics/tech-talk/2012/msg02082.php>.
* Make dbpf able to write data to a waveform. Takes beginIndex argument
for where in waveform to start writing.
* Add new dbpf routine that writes data read from a file to a waveform.
The routine accepts the normal recordNameDotFieldName string
identifying the field to write to. However, it also takes srcFile,
srcBeginIndex, destBeginIndex, and length arguments. These correspond
to the path to the source file containing the values to be written,
the index of where in the array of values read from the source file to
start reading, the index of where in the destination waveform to start
writing, and the number of values to write, respectively.
* Embed Lua <http://www.lua.org/> in IOC. This was originally a wish
for conditional statements in iocsh. Andrew does not agree with doing
that, but he is open to embedding Lua into the IOC and adding the
ability to execute registered iocsh commands from Lua.
Thanks!
Lewis
- Codeathon Projects Andrew Johnson
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
<2014>
2025
2026
Fwd: crash when clearing link field Andrew Johnson
<2014>
2025
2026
