If anybody has time to look into this please do and report back here,
Tim Mooney found a way to segfault a 3.14 IOC when using putNotify. I
have confirmed that this happens and can see the problem as Tim
describes it, but I don't know what the fix should be.
There is a live notify operation still outstanding when the second caput
changes the output link. The naive solution to this (have
dbCaCallbackProcess() do nothing if pdbCommon is NULL) does not result
in a putNotify completion being sent back to the client, which isn't
really acceptable and may leak memory.
I would like a fix for both 3.14 and 3.15 (which may be different since
putNotify was replaced with processNotify), but I can convert a 3.14 fix
into the 3.15 one.
- Andrew
-------- Original Message --------
Subject: crash when clearing link field
Date: Fri, 27 Jun 2014 16:52:26 -0500
To: Johnson, Andrew N. <[email protected]>
Hi Andrew,
I found something I thought you'd be interested in. If a record
executes a put_callback link, and the link field is cleared while the
callback is outstanding, the ioc crashes immediately. This happens both
on Linux and vxWorks, and with base 3.14 and 3.15. When the link field
is cleared, dbCaTask() notices that a callback is outstanding on it, and
issues a complimentary completion callback: "if (callback)
callback(plinkPutCallback);"
According to gdb, the problem occurs when dbCaCallbackProcess() calls
dbScanLock(), and dbScanLock() executes the line "lockRecord
*plockRecord = precord->lset;", because precord==0.
Here's a database and caput commands that demonstrate the problem:
record(ao, "linkCrashAO") {
field(DTYP, "Async Soft Channel")
field(OUT, "linkCrashCO.A CA")
record(calcout, "linkCrashCO") {
field(CALC, "0")
field(ODLY, "10")
caput -c -w20 linkCrashAO.PROC 1
caput linkCrashAO.OUT ""
Tim
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base Andrew Johnson
isfinite() on Linux Ralph Lange
<2014>
2025
2026
Re: Codeathon Projects J. Lewis Muir
<2014>
2025
2026
