Subject: |
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base |
mdavidsaver <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Thu, 10 Jul 2014 22:14:06 -0000 |
> In dbUnitTest.c shouldn't the Type arguments to OP use the
> epics{Int,UInt,Float}<n> names? If not I suspect there
> should at least be a couple more 'unsigned' keywords in
> there.
Before I can answer this question I think you will need to educate me a bit about argument type promotion in vararg functions. Does va_arg() have knowledge of this? Will va_arg(X,short) actually return an 'int'?
My thinking at the time was that since these rules are a bit obscure, that it would be better to explicitly document a mapping of variable type to DBF_*. You will find such a mapping in a comment in dbUnitTest.h. I'm not too attached to this approach though, the point is that a put operation should be one line.
Just to throw out another idea. I have considered using printf style syntax just to get a compile time check. eg. testdbPutField("pvname", DBF_LONG, "%d", 0) where exactly "%d" must be used for DBF_LONG. As a side effect this would work well for DBF_STRING.
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
- Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base Andrew Johnson
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
<2014>
2025
2026
<2014>
2025
2026
