Subject: |
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Wed, 02 Jul 2014 19:14:57 -0000 |
Review: Needs Fixing
Hi Michael,
This looks much better. There are still a few minor things to clean up and we will eventually need appDevGuide text for the new dbUnitTest API, but I will accept this approach. Some comments:
A patch for the following fixes exists, or I can commit the
changes if you prefer. I tested the result on Linux & VxWorks,
builds Ok for RTEMS:
Build errors: Include guard missing from epicsUnitTest.h;
dbShutdownTest.c was calling the non-universal strcasecmp()
instead of epicsStrCaseCmp().
I would prefer that ioc/db/test not depend on std. I modified
xRecord to make it a working record type, and simplified the
other test programs so they all use the same new expanded
dbd file rather than each making their own. I also added
dbShutdownTest() to epicsRunDbTests().
I would like to see these issues addressed:
I don't like the public name iocBuildNoCA(), if anything the
iocBuild routine should have "WithCA" in its name instead,
as eventually merging pvAccess will invalidate a ...NoCA
name, but that may be going a little too far. How about
using iocBuildIsolated() instead of ...NoCA (or see
http://thesaurus.com/browse/isolated for some alternative
adjectives, Sequestered would also be good but it's even
longer).
In dbUnitTest.c shouldn't the Type arguments to OP use the
epics{Int,UInt,Float}<n> names? If not I suspect there
should at least be a couple more 'unsigned' keywords in
there.
The dbUnitTest.h API can extend the epicsUnitTest.h one and add
its own Ok() routines. I'd suggest testIocInitOk() and
testIocShutdownOk() [note capitalization and name change]
which should call testOk() directly (with a suitable
description string) instead of making the user remember to
invert the return values.
The name testVdbPutField() should probably be testdbVPutField()
since most of the other routine names start 'testdb'.
The name testGetRecord() doesn't match the other names (use
testdbRecordPtr() maybe?), and should say "record" in its
abort message instead of "PV" (usually records are PVs, but
not all PVs are records...).
The testdbPrepare() routine could call eltc(0) to turn off
errlog warning messages which otherwise get sent to stderr
and appear in the test output.
These are minor details which don't have to be fixed now but
should be eventually:
The variable(atExitDebug,int) declaration should not appear in
dbCore.dbd, but libCom doesn't currently have its own .dbd
file where it should really belong.
src/ioc/misc/iocInit.c routine names (static):
* Change the iocBuild_<n>() names to be more descriptive?
dbShutdownTest does not have a checkNoCommonThreads() test, so
it's not testing the full operation of iocShutdown().
These ioc/db/test programs need converting to use dbUnitTest.h:
dbChannelTest.c chfPluginTest.c and arrShorthandTest.c
- Andrew
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
- Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
- [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Re: epicsThreadShowAll Benjamin Franksen
How to build an IOC and run it on another machine without base ZHENG Xiangyu
<2014>
2025
2026
<2014>
2025
2026
