-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07/25/2014 12:43 PM, Michael Davidsaver wrote:
> The small change to the startup order allows the hello.db example
> to shutdown.
>> diff --git a/src/ioc/misc/iocInit.c b/src/ioc/misc/iocInit.c
>> index 5f3d505..5e950af 100644 --- a/src/ioc/misc/iocInit.c +++
>> b/src/ioc/misc/iocInit.c @@ -135,8 +135,8 @@ static int
>> iocBuild_2(void) initDevSup();
>> initHookAnnounce(initHookAfterInitDevSup);
>> - initDatabase(); dbLockInitRecords(pdbbase); +
>> initDatabase(); dbBkptInit();
>> initHookAnnounce(initHookAfterInitDatabase);
Is this change actually correct? ... No, it's not, it gives me one
lock-set per record even when there are DB links connecting all my
records together. This is from a test database with lots of DB links
in it:
> epics> dblsr * 1 globalLock 0x24c7ac0 lockSetModifyLock 0x24c7b30
> Lock Set 1 1 members epicsMutexId 0x24c7c50 Not Locked
> anj:seq-compat Lock Set 2 1 members epicsMutexId 0x24c7c80 Not
> Locked anj:seq-new Lock Set 3 1 members epicsMutexId 0x24da5a0 Not
> Locked anj:so0 Lock Set 4 1 members epicsMutexId 0x24da680 Not
> Locked anj:so1 Lock Set 5 1 members epicsMutexId 0x24da760 Not
> Locked anj:so2 Lock Set 6 1 members epicsMutexId 0x24da840 Not
> Locked anj:so3 Lock Set 7 1 members epicsMutexId 0x24da920 Not
> Locked anj:so4 Lock Set 8 1 members epicsMutexId 0x24daa00 Not
> Locked anj:so5 Lock Set 9 1 members epicsMutexId 0x24daae0 Not
> Locked anj:so6 Lock Set 10 1 members epicsMutexId 0x24dabc0 Not
> Locked anj:so7 Lock Set 11 1 members epicsMutexId 0x24daca0 Not
> Locked anj:so8 Lock Set 12 1 members epicsMutexId 0x24dad80 Not
> Locked anj:so9 Lock Set 13 1 members epicsMutexId 0x24dae60 Not
> Locked anj:soA Lock Set 14 1 members epicsMutexId 0x24daf40 Not
> Locked anj:soB Lock Set 15 1 members epicsMutexId 0x24db020 Not
> Locked anj:soC Lock Set 16 1 members epicsMutexId 0x24db100 Not
> Locked anj:soD Lock Set 17 1 members epicsMutexId 0x24db1e0 Not
> Locked anj:soE Lock Set 18 1 members epicsMutexId 0x24db2c0 Not
> Locked anj:soF Lock Set 19 1 members epicsMutexId 0x24db3a0 Not
> Locked anj:select epics> dbpr anj:seq-new 1 ASG:
> BKPT: 00 DESC: DISA: 0 DISP: 0
> DISS: NO_ALARM DISV: 1 DLY0: 0.2 DLY1: 0.2
> DLY2: 0.2 DLY3: 0.2 DLY4: 0.2 DLY5: 0.2
> DLY6: 0.2 DLY7: 0.2 DLY8: 0.2 DLY9: 0.2
> DLYA: 0.2 DLYB: 0.2 DLYC: 0.2 DLYD: 0.2
> DLYE: 0.2 DLYF: 0.2 DO0: 0 DO1: 0
> DO2: 0 DO3: 0 DO4: 0 DO5: 0
> DO6: 0 DO7: 0 DO8: 0 DO9: 0
> DOA: 0 DOB: 0 DOC: 0 DOD: 0
> DOE: 0 DOF: 0 DOL0:CONSTANT DOL1:CONSTANT
> DOL2:CONSTANT DOL3:CONSTANT DOL4:CONSTANT DOL5:CONSTANT
> DOL6:CONSTANT DOL7:CONSTANT DOL8:CONSTANT DOL9:CONSTANT
> DOLA:CONSTANT DOLB:CONSTANT DOLC:CONSTANT DOLD:CONSTANT
> DOLE:CONSTANT DOLF:CONSTANT DTYP: <nil> EVNT:
> FLNK:CONSTANT 0 LNK0:DB_LINK anj:so0.PROC NPP NMS LNK1:DB_LINK
> anj:so1.PROC NPP NMS LNK2:DB_LINK anj:so2.PROC NPP NMS
> LNK3:DB_LINK anj:so3.PROC NPP NMS LNK4:DB_LINK anj:so4.PROC
> NPP NMS LNK5:DB_LINK anj:so5.PROC NPP NMS LNK6:DB_LINK
> anj:so6.PROC NPP NMS LNK7:DB_LINK anj:so7.PROC NPP NMS
> LNK8:DB_LINK anj:so8.PROC NPP NMS LNK9:DB_LINK anj:so9.PROC NPP NMS
> LNKA:DB_LINK anj:soA.PROC NPP NMS LNKB:DB_LINK anj:soB.PROC NPP NMS
> LNKC:DB_LINK anj:soC.PROC NPP NMS LNKD:DB_LINK anj:soD.PROC NPP NMS
> LNKE:DB_LINK anj:soE.PROC NPP NMS LNKF:DB_LINK anj:soF.PROC NPP NMS
> NAME: anj:seq-new OFFS: 0 PACT: 0 PHAS: 0
> PINI: NO PREC: 0 PRIO: LOW PUTF: 0
> RPRO: 0 SCAN: Passive SDIS:CONSTANT SELL:DB_LINK
> anj:select NPP NMS SELM: Specified SELN: 1
> SEVR: INVALID SHFT: 0 STAT: UDF TPRO: 0
> TSE: 0 TSEL:CONSTANT UDF: 1 UDFS: INVALID
> VAL: 0 epics>
The dbLockInitRecords() routine looks at all the links in each record
that have plink->type == DB_LINK and calls dbLockSetMerge() as it
finds them. However the plink->type gets converted from PV_LINK to
DB_LINK in initDatabase() by doResolveLinks() -> dbInitLink() ->
dbDbInitLink().
Maybe we should move the dbLockSetMerge() call from
dbLockInitRecords() into dbDbInitLink()? We already adjust lock-sets
in the dbDbAddLink() and dbDbRemoveLink() routines, so it makes a lot
of sense to put it there. Have to be careful to adjust dbDbAddLink()
which was calling dbDbInitLink() but now I get the right result:
> epics> dblsr * 1 globalLock 0x1be5a20 lockSetModifyLock 0x1be5a90
> Lock Set 2 19 members epicsMutexId 0x1be5be0 Not Locked
> anj:seq-new anj:seq-compat anj:select anj:so1 anj:so2 anj:so3
> anj:so4 anj:so5 anj:so6 anj:so7 anj:so8 anj:so9 anj:soA anj:so0
> anj:soB anj:soC anj:soD anj:soE anj:soF
Fix committed.
- - Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJT0uHZAAoJENMGEg7qy0V2Fm4IAII8d6nJ5HQOv9BmmvKAOlSA
o8+LFGARne5GOFOaY5SUBH4EZJvkQelyANDPgJG6p1pP/iNojLQpYuz+vnVd4eTo
N26WykTv/4FYGxiVy8JiKqZVpAM5fx9lR0bx8n9gs858/8/y+jzQ6Lb2tHU2Z6kD
VafjUlcg9PFlZU+kXMW2wKBQ48R6bBalNalXhYy0nnRqCn+VyTZmYYYLuzcnpy1n
l7WT83qD49wVUSvbw6kynkTjKRsmZESboOxrbVqc0gBihRDFgAS2H+pUJyyERUJ4
6eH0itd8lSWgjq9fwfhdeh1x44M0zT826/Rdx5ZBgOmPVdUEC2f2f1CNOaH21Iw=
=dQfE
-----END PGP SIGNATURE-----
- Re: 3.15 assertion failure from dbLock.c on IOC exit Michael Davidsaver
- 3.15 assertion failure from dbLock.c on IOC exit Andrew Johnson
<2014>
2025
2026
<2014>
2025
2026
