2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15 assertion failure from dbLock.c on IOC exit
To: [email protected]
Date: Mon, 28 Jul 2014 15:31:33 -0400
On 07/25/2014 07:01 PM, Andrew Johnson wrote:
> Is this change actually correct? ... No, it's not, it gives me one
> lock-set per record even when there are DB links connecting all my
> records together. This is from a test database with lots of DB links
> in it:
I've added test code to detect this problem if it comes up again.  It
has a test database with 6 records in 3 locksets.  It then checks that
pairs of records are, or are not, in the same lockset.
Before Andrew's fix it fails like:
> ok  1 - dbLockGetLockId("reca")!=dbLockGetLockId("recb")
> ok  2 - dbLockGetLockId("reca")!=dbLockGetLockId("recc")
> ok  3 - dbLockGetLockId("reca")!=dbLockGetLockId("recd")
> ok  4 - dbLockGetLockId("reca")!=dbLockGetLockId("rece")
> ok  5 - dbLockGetLockId("reca")!=dbLockGetLockId("recf")
> not ok  6 - dbLockGetLockId("recb")==dbLockGetLockId("recc")
> ok  7 - dbLockGetLockId("recb")!=dbLockGetLockId("recd")
> ok  8 - dbLockGetLockId("recb")!=dbLockGetLockId("rece")
> ok  9 - dbLockGetLockId("recb")!=dbLockGetLockId("recf")
> ok 10 - dbLockGetLockId("recc")!=dbLockGetLockId("recd")
> ok 11 - dbLockGetLockId("recc")!=dbLockGetLockId("rece")
> ok 12 - dbLockGetLockId("recc")!=dbLockGetLockId("recf")
> not ok 13 - dbLockGetLockId("recd")==dbLockGetLockId("rece")
> not ok 14 - dbLockGetLockId("recd")==dbLockGetLockId("recf")
> not ok 15 - dbLockGetLockId("rece")==dbLockGetLockId("recf")
Attachment: signature.asc
Description: OpenPGP digital signature
3.15 assertion failure from dbLock.c on IOC exit Andrew Johnson
Re: 3.15 assertion failure from dbLock.c on IOC exit Michael Davidsaver
Re: 3.15 assertion failure from dbLock.c on IOC exit Andrew Johnson
Prev: Re: 3.15 assertion failure from dbLock.c on IOC exit Andrew Johnson
Next: running RTEMS test harness in QEMU Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Jul 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
