On 09/22/2014 05:10 PM, APS Jenkins wrote:
> See <https://jenkins.aps.anl.gov/job/epics-base-3.15/98/changes>
Only 6253 tests ran, the previous build had 8089.
Since Jenkins' TAP parser isn't showing the actually failures here's
what I get running the tests manually:
epicsSockResolveTest.t ..... Bailout called. Further testing stopped:
hostToIPAddr() is broken, testing not possible
FAILED--Further testing stopped: hostToIPAddr() is broken, testing not
possible
tux% ./epicsSockResolveTest
1..33
Bail out! hostToIPAddr() is broken, testing not possible
Abort
arrayOpTest.t ........ Failed 1/10 subtests
tux% ./arrayOpTest
1..10
# Test dbGet() and dbPut() of an array
## EPICS R3.15.0.1-DEV $$Date$$
## EPICS Base built Jul 23 2014
# Fetch initial value
ok 1 - prec->nord==0
ok 2 - nreq==0
ok 3 - memcmp(&addr, &save, sizeof(save))==0
# Write a new value
ok 4 - dbPut(&addr, DBF_DOUBLE, &data, NELEMENTS(data))==0
ok 5 - prec->nord==4
ok 6 - pbtr[0]==4 && pbtr[1]==5 && pbtr[2]==6 && pbtr[3]==7
not ok 7 - memcmp(&addr, &save, sizeof(save))==0
# reread the value
ok 8 - nreq==NELEMENTS(data)
ok 9 - data[0]==4.0 && data[1]==5.0 && data[2]==6.0 && data[3]==7.0
ok 10 - memcmp(&addr, &save, sizeof(save))==0
dbmfFinish: not all free
Results
Tests: 10
Passed: 9 = 90.00%
Failed: 1 = 10.00%
However on Jenkins there were more tests failing. Both analogMonitorTest
and arrayOpTest bailed out instead, might have missed one or two others
as well:
Bail out! Error reading test database 'analogMonitorTest.db'
Bail out! Failed to load test database
dbReadDatabase(arrayOpTest.db,.:..:../O.Common:O.Common,(null))
Got to go now, if anyone else can contribute to working out what broke
before I get in tomorrow I would be grateful. It's possible that my
commit #12529 had some effect, although I ran the tests and Jenkins
passed run #97 with that included. Jenkins should be starting from
scratch so builds *should* be independent, but I'm not actually doing a
'make distclean' so that might not be what's actually happening.
- Andrew
- Re: Jenkins build became unstable: epics-base-3.15 #98 Andrew Johnson
- Jenkins build became unstable: epics-base-3.15 #98 APS Jenkins
<2014>
2025
2026
<2014>
2025
2026
