2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Jenkins build became unstable: epics-base-3.15 #98
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 23 Sep 2014 15:41:42 -0500
On 9/23/14, 3:32 PM, Andrew Johnson wrote:
> Oops! There is now a gTLD 'host'. I changed the above code to look up
> "obviously-invalid-host" instead.
Hi, Andrew.
Perhaps better would be to look up "obviously.invalid" since this would
use the ".invalid" TLD which is documented in RFC 2606 [1] as "intended
for use in online construction of domain names that are sure to be
invalid and which it is obvious at a glance are invalid."
Lewis
[1] http://tools.ietf.org/html/rfc2606
Re: Jenkins build became unstable: epics-base-3.15 #98 Andrew Johnson
Jenkins build became unstable: epics-base-3.15 #98 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.15 #99 APS Jenkins
Next: Re: Jenkins build became unstable: epics-base-3.15 #98 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Jenkins build became unstable: epics-base-3.15 #98 Andrew Johnson
ANJ, 23 Sep 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
