Hi Andrew,
I have no EPICS_BASE variable defined (I checked).
As a test, I copied D:\EPICS\base\include to d:\EPICS\include, then reproduced the build error.
I think you should be able to reproduce this anomaly in a similar manner.
>> I don't think so:
My mistake. I'm not quite sure how this happened.
I re-unpacked the raw downloaded file, and found that you are correct.
Cheers,
Peter.
-----Original Message-----
Sent: 03 November 2014 20:51
To: Heesterman, Peter
Cc: [email protected]; EPICS core-talk
Subject: Re: EPICS base 3.15.0.2
Hi Peter,
On 11/03/2014 06:38 AM, Heesterman, Peter J wrote:
> I deleted D:\EPICS\include, and then used the makefile build normally.
Ok, that's a relief. If you have an environment variable EPICS_BASE pointing to D:\EPICS (and not to D:\EPICS\base) I think that might explain the behaviour of our build system.
>>> The 3.15.0.2 version of base.dbd does include menuGlobal.dbd
> No it doesn't!
> I attach your version.
I don't think so:
> tux% wget
> http://www.aps.anl.gov/epics/download/base/base-3.15.0.2.tar.gz
> --2014-11-03 14:27:30--
> Resolving www.aps.anl.gov... 164.54.22.38 Connecting to
> www.aps.anl.gov|164.54.22.38|:80... connected.
> HTTP request sent, awaiting response... 200 OK
> Length: 1585880 (1.5M) [application/x-tar] Saving to:
> “base-3.15.0.2.tar.gz”
> 100%[==========================================================>] 1,585,880 --.-K/s in 0.02s
> 2014-11-03 14:27:30 (89.3 MB/s) - “base-3.15.0.2.tar.gz” saved
> [1585880/1585880]
> tux% tar -x -f base-3.15.0.2.tar.gz -z --to-stdout
> base-3.15.0.2/src/std/softIoc/base.dbd
> # Revision-Id: [email protected]
> # This file defines the standard record types and device support #
> provided by Base and (usually) loaded into all IOCs.
> # Menus
> include "menuGlobal.dbd"
> include "menuConvert.dbd"
> # Record types
> include "stdRecords.dbd"
> # Channel filters & plugins
> include "filters.dbd"
> # "Soft Channel", "Raw Soft Channel", and "Async Soft Channel" device
> support include "devSoft.dbd"
> # Access security subroutines
> include "asSub.dbd"
> # IOC Core variables
> include "dbCore.dbd"
The current version on the 3.15 branch can also be viewed online at http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/softIoc/base.dbd
>>> Win32.bat.
> The only significant difference I can see between your version of this file and mine is that your version sets an explicit path to G:\epics\base\bin\%EPICS_HOST_ARCH%, where G:\ is presumably a network drive that you're using.
> Please have a look at my version (attached).
That looks OK, bar what appear to be typo's pcDataCPP and pcAccessCPP which might affect your ability to use some V4 modules. The G:\ drive is Janet's default Windows setup.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- Re: EPICS base 3.15.0.2 Andrew Johnson
- RE: EPICS base 3.15.0.2 Heesterman, Peter J
Problem building 3.15 latest with -j on linux-x86 and vxWorks Mark Rivers
Jenkins build became unstable: epics-base-3.15 #132 APS Jenkins
<2014>
2025
2026
<2014>
2025
2026
