2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base 3.15.0.2
To: "Heesterman, Peter J" <[email protected]>
Cc: EPICS core-talk <[email protected]>, [email protected]
Date: Mon, 3 Nov 2014 14:50:51 -0600
Hi Peter,
On 11/03/2014 06:38 AM, Heesterman, Peter J wrote:
> I deleted D:\EPICS\include, and then used the makefile build normally.
Ok, that's a relief. If you have an environment variable EPICS_BASE
pointing to D:\EPICS (and not to D:\EPICS\base) I think that might
explain the behaviour of our build system.
>>> The 3.15.0.2 version of base.dbd does include menuGlobal.dbd
> No it doesn't!
> I attach your version.
I don't think so:
> tux% wget http://www.aps.anl.gov/epics/download/base/base-3.15.0.2.tar.gz
> --2014-11-03 14:27:30--  http://www.aps.anl.gov/epics/download/base/base-3.15.0.2.tar.gz
> Resolving www.aps.anl.gov... 164.54.22.38
> Connecting to www.aps.anl.gov|164.54.22.38|:80... connected.
> HTTP request sent, awaiting response... 200 OK
> Length: 1585880 (1.5M) [application/x-tar]
> Saving to: “base-3.15.0.2.tar.gz”
> 100%[==========================================================>] 1,585,880   --.-K/s   in 0.02s
> 2014-11-03 14:27:30 (89.3 MB/s) - “base-3.15.0.2.tar.gz” saved [1585880/1585880]
> tux% tar -x -f base-3.15.0.2.tar.gz -z --to-stdout base-3.15.0.2/src/std/softIoc/base.dbd
> # Revision-Id: [email protected]
> # This file defines the standard record types and device support
> # provided by Base and (usually) loaded into all IOCs.
> # Menus
> include "menuGlobal.dbd"
> include "menuConvert.dbd"
> # Record types
> include "stdRecords.dbd"
> # Channel filters & plugins
> include "filters.dbd"
> # "Soft Channel", "Raw Soft Channel", and "Async Soft Channel" device support
> include "devSoft.dbd"
> # Access security subroutines
> include "asSub.dbd"
> # IOC Core variables
> include "dbCore.dbd"
The current version on the 3.15 branch can also be viewed online at
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/softIoc/base.dbd
>>> Win32.bat.
> The only significant difference I can see between your version of this file and mine is that your version sets an explicit path to G:\epics\base\bin\%EPICS_HOST_ARCH%, where G:\ is presumably a network drive that you're using.
> Please have a look at my version (attached).
That looks OK, bar what appear to be typo's pcDataCPP and pcAccessCPP
which might affect your ability to use some V4 modules. The G:\ drive is
Janet's default Windows setup.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
RE: EPICS base 3.15.0.2 Heesterman, Peter J
Re: EPICS base 3.15.0.2 Andrew Johnson
Prev: RE: EPICS base 3.15.0.2 Heesterman, Peter J
Next: Problem building 3.15 latest with -j on linux-x86 and vxWorks Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS base 3.15.0.2 Heesterman, Peter J
ANJ, 04 Nov 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
