2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 3.15.0.2: Shutdown issues
To: EPICS Core-Talk <[email protected]>
Date: Fri, 14 Nov 2014 10:16:07 +0100
We sometimes see:
Dear Ralph,
         I observe  some errors on   IOC  while exit from the IOC shell with exit command.
A call to 'assert(status == epicsMutexLockOK)'
    by thread 'CAS-client' failed in ../../../src/ioc/db/dbEvent.c line 490.
[      0x3817ee8b5d]: /lib64/libc.so.6(clone+0x6d)
EPICS Release EPICS R3.15.0.2 $$Date$$.
    by thread 'errlog' failed in ../../../src/libCom/log/logClient.c line 241.
[    0x7f14388c8363]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libCom.so.3.15(epicsStackTrace+0x73)
[    0x7f14388c24ed]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libCom.so.3.15(epicsAssert+0x4d)
[    0x7f1438d87c8a]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libdbCore.so.3.15(db_event_disable+0x7a)
[    0x7f1438d87ca6]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libdbCore.so.3.15(db_cancel_event+0x16)
[    0x7f1438da9c37]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libdbCore.so.3.15(casAttachThreadToClient+0xc7)
[    0x7f1438daa326]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libdbCore.so.3.15(destroy_tcp_client+0x56)
[    0x7f1438dab53a]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libdbCore.so.3.15(camsgtask+0x7a)
[    0x7f14388c3b24]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libCom.so.3.15(epicsThreadSuspendSelf+0x174)
[      0x38186079d1]: /lib64/libpthread.so.0(<no symbol information>)
Dumping a stack trace of thread 'errlog':
Local time is 2014-11-12 09:55:17.723540409 UTC
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
[    0x7f14388b6a1a]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libCom.so.3.15(logClientSend+0x9a)
[    0x7f14388ae3da]: /opt/codac-5.0/epics/base/lib/linux-x86_64/libCom.so.3.15(errlogGetSevEnumString+0x24a)
Local time is 2014-11-12 09:55:17.723897076 UTC
^C
[screen is terminating]
My current interpretation is:
  • rsrv is shutting down one of its CAS client threads (TCP handler). While removing all subscriptions of that client, being inside db_event_disable() it finds the lockset mutex went away (line 490 of dbEvent.c).
  • The log client tries to send a message to the log server, and finds the client mutex went away (line 241 of logClient.c).
    errlogGetSevEnumString+0x24a is errlogThread(), the call to logSendClient() is via *plistenerNod->listener (line 577 of errlog.c).
I think the two are unrelated. Could it be that the errlog issue is caused by the rsrv issue being logged?
Looking at the interaction between iocLog and the errlog facility, I find that iocLog registers a listener with errlog (line 94 of iocLog.c), but never unregisters. Called as an exit hook, logClientDestroy() destroys the client mutex (line 157 of logClient.c), while the client is still registered as a listener with errlog. That's obviously a bug I will add to the tracker and fix.
Any ideas on what to do about rsrv shutdown?
Thanks a lot,
~Ralph
Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Prev: Jenkins build is back to normal : epics-base-3.15-cyg64 #171 APS Jenkins
Next: Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Nov 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
