On 11/18/2014 05:48 PM, Andrew Johnson wrote:
> If a test needs a specific thread priority, please start a thread that
> meets those requirements and run it in that. The VxWorks shell by
> default runs at the highest priority.
Ok, I'll change this.
> Also I am a little nervous about future compilers noticing that you're
> creating pointers out of random integer offsets from a NULL pointer,
I thought you might be. My goal is to catch corrupt reads/writes.
Simply reading through a bunch of sequential addresses means that it is
likely that only one byte is different. This could mask corruption in
the other 3/7 bytes.
So the test does i|i<<16 so that I'm sure at least 2 bytes are changing
in every read/write. So if I write 0x000a000a followed by 0x000b000b
but find that I read 0x000a000b, then I know there is a problem.
http://docs.cray.com/books/004-2179-001/html-004-2179-001/rvc5mrwh.html#ZFIXEDAWYU1A7W
> Could this program not just malloc() a large buffer (1MB say) and make
> up its pointers from offsets into that array?
This could be done. I would want 16MB (i|i<<12 for i<4000).
- ringPointerTest Andrew Johnson
- Re: ringPointerTest Michael Davidsaver
- Re: ringPointerTest Andrew Johnson
Shutdown issues Ralph Lange
<2014>
2025
2026
Assertion failure in dbLock.c Andrew Johnson
<2014>
2025
2026
