2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-win64s #117
To: [email protected]
Date: Wed, 10 Dec 2014 14:19:03 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64s/117/>
[...truncated 33 lines...]
make[2]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/tools'
make -C tools/test install
make[2]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/tools/test'
perl -CSD ../../../bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../../../..
make -C O.windows-x64-static -f ../Makefile TOP=../../../.. T_A=windows-x64-static install
make[3]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/tools/test/O.windows-x64-static'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/tools/test/O.windows-x64-static'
make[2]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/tools/test'
make -C template/base install
make[2]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/base'
make[3]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/base/O.windows-x64-static'
make[3]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/base/O.windows-x64-static'
make[2]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/base'
make -C template/ext install
make[2]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/ext'
make[3]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/ext/O.windows-x64-static'
make[3]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/ext/O.windows-x64-static'
make[2]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/template/ext'
make -C ./libCom install
make[2]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/libCom'
perl -CSD ../../bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../../..
make -C O.windows-x64-static -f ../Makefile TOP=../../.. T_A=windows-x64-static install
make[3]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/libCom/O.windows-x64-static'
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m forceBadAllocException.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../!
 ../include        forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/forceBadAllocException.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m setThreadName.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        setThreadName.d ../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsGetopt.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        epicsGetopt.d ../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_parser.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        yajl_parser.d ../../../src/libCom/yajl/yajl_parser.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_lex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     yajl_lex.d ../../../src/libCom/yajl/yajl_lex.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_gen.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     yajl_gen.d ../../../src/libCom/yajl/yajl_gen.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_encode.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        yajl_encode.d ../../../src/libCom/yajl/yajl_encode.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_buf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     yajl_buf.d ../../../src/libCom/yajl/yajl_buf.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl_alloc.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       yajl_alloc.d ../../../src/libCom/yajl/yajl_alloc.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m yajl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        !
 yajl.d ../../../src/libCom/yajl/yajl.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m timerQueuePassive.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../in!
 clude        timerQueuePassive.d ../../../src/libCom/timer/timerQueuePassive.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m timerQueueActiveMgr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../!
 include        timerQueueActiveMgr.d ../../../src/libCom/timer/timerQueueActiveMgr.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m timerQueueActive.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inc!
 lude        timerQueueActive.d ../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m timerQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       timerQueue.d ../../../src/libCom/timer/timerQueue.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m timer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  timer.d ../../../src/libCom/timer/timer.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsTimer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       epicsTimer.d ../../../src/libCom/timer/epicsTimer.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m taskwd.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   taskwd.d ../../../src/libCom/taskwd/taskwd.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsRingBytes.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
 de        epicsRingBytes.d ../../../src/libCom/ring/epicsRingBytes.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsRingPointer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inc!
 lude        epicsRingPointer.d ../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m threadPool.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       threadPool.d ../../../src/libCom/pool/threadPool.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m poolJob.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    poolJob.d ../../../src/libCom/pool/poolJob.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdFindAddr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        osdFindAddr.d ../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdBackTrace.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         osdBackTrace.d ../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsStackTrace.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../incl!
 ude        epicsStackTrace.d ../../../src/libCom/osi/epicsStackTrace.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m devLibVMEOSD.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         devLibVMEOSD.d ../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m devLibVME.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      devLibVME.d ../../../src/libCom/osi/devLibVME.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdMessageQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../incl!
 ude        osdMessageQueue.d ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdNetIntf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       osdNetIntf.d ../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdProcess.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       osdProcess.d ../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    osdTime.d ../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdEvent.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     osdEvent.d ../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdSpin.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    osdSpin.d ../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     osdMutex.d ../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdThreadHooks.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
 de        osdThreadHooks.d ../../../src/libCom/osi/os/default/osdThreadHooks.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdThreadExtra.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
 de        osdThreadExtra.d ../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdThread.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      osdThread.d ../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdStdio.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     osdStdio.d ../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsStdio.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       epicsStdio.d ../../../src/libCom/osi/epicsStdio.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsTempFile.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        epicsTempFile.d ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsReadline.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        epicsReadline.d ../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdEnv.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   osdEnv.d ../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdSignal.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      osdSignal.d ../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdPoolStatus.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        osdPoolStatus.d ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdInterrupt.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         osdInterrupt.d ../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdFindSymbol.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        osdFindSymbol.d ../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdAssert.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      osdAssert.d ../../../src/libCom/osi/os/default/osdAssert.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsSocketConvertErrnoToString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN!
 32 ../../../include        epicsSocketConvertErrnoToString.d ../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m systemCallIntMech.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../in!
 clude        systemCallIntMech.d ../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osiSock.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    osiSock.d ../../../src/libCom/osi/osiSock.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdSockAddrReuse.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inc!
 lude        osdSockAddrReuse.d ../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osdSock.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    osdSock.d ../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m osiClockTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         osiClockTime.d ../../../src/libCom/osi/osiClockTime.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsGeneralTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inc!
 lude        epicsGeneralTime.d ../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsAtomicOSD.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
 de        epicsAtomicOSD.d ../../../src/libCom/osi/os/WIN32/epicsAtomicOSD.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsMath.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      epicsMath.d ../../../src/libCom/osi/epicsMath.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsMessageQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../in!
 clude        epicsMessageQueue.d ../../../src/libCom/osi/epicsMessageQueue.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      epicsTime.d ../../../src/libCom/osi/epicsTime.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsEvent.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       epicsEvent.d ../../../src/libCom/osi/epicsEvent.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       epicsMutex.d ../../../src/libCom/osi/epicsMutex.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsThread.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        epicsThread.d ../../../src/libCom/osi/epicsThread.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsUnitTest.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
 e        epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m ipAddrToAsciiAsynchronous.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../!
 ../../include        ipAddrToAsciiAsynchronous.d ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m truncateFile.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         truncateFile.d ../../../src/libCom/misc/truncateFile.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        epicsString.d ../../../src/libCom/misc/epicsString.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsStdlib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        epicsStdlib.d ../../../src/libCom/misc/epicsStdlib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsExit.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      epicsExit.d ../../../src/libCom/misc/epicsExit.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsConvert.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         epicsConvert.d ../../../src/libCom/misc/epicsConvert.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m cantProceed.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        cantProceed.d ../../../src/libCom/misc/cantProceed.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m adjustment.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include  !
       adjustment.d ../../../src/libCom/misc/adjustment.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m aToIPAddr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      aToIPAddr.d ../../../src/libCom/misc/aToIPAddr.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m alarmString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        alarmString.d ../../../src/libCom/misc/alarmString.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m macUtil.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    macUtil.d ../../../src/libCom/macLib/macUtil.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m macEnv.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   macEnv.d ../../../src/libCom/macLib/macEnv.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m macCore.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    macCore.d ../../../src/libCom/macLib/macCore.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m logClient.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      logClient.d ../../../src/libCom/log/logClient.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m iocLog.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   iocLog.d ../../../src/libCom/log/iocLog.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m libComRegister.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
 de        libComRegister.d ../../../src/libCom/iocsh/libComRegister.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m registry.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     registry.d ../../../src/libCom/iocsh/registry.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m iocsh.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  iocsh.d ../../../src/libCom/iocsh/iocsh.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m gpHashLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      gpHashLib.d ../../../src/libCom/gpHash/gpHashLib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m freeListLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        freeListLib.d ../../../src/libCom/freeList/freeListLib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m fdManager.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      fdManager.d ../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m fdmgr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  fdmgr.d ../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h ../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThreadPool.h ../../../src/ioc/db/dbAccessDefs.h ../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h ../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/ca/legacy/pcas/generic/casdef.h ../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m errSymTbl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      errSymTbl.d errSymTbl.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m errSymLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      errSymLib.d ../../../src/libCom/error/errSymLib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m errlog.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   errlog.d ../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl  ../../../configure
Generating envData.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m envData.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    envData.d envData.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m envSubr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    envSubr.d ../../../src/libCom/env/envSubr.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m ellLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   ellLib.d ../../../src/libCom/ellLib/ellLib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m dbmf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        !
 dbmf.d ../../../src/libCom/dbmf/dbmf.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsSingletonMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../!
 include        epicsSingletonMutex.d ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m epicsOnce.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      epicsOnce.d ../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m resourceLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m cvtFast.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    cvtFast.d ../../../src/libCom/cvtFast/cvtFast.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m calcPerform.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        calcPerform.d ../../../src/libCom/calc/calcPerform.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m postfix.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    postfix.d ../../../src/libCom/calc/postfix.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m bucketLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include   !
      bucketLib.d ../../../src/libCom/bucketLib/bucketLib.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m asTrapWrite.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
        asTrapWrite.d ../../../src/libCom/as/asTrapWrite.c
cl -EHsc -GR               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -RTCsu -Zi   -W3 -w44355       -MTd  -TP  -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../.!
 ./../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
epicsTempFile.cpp
cl               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Zi -RTCsu   -W3 -w44355       -MTd    -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libC!
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/ccl.c
ccl.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/dfa.c
dfa.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/ecs.c
ecs.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/gen.c
gen.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/misc.c
misc.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/nfa.c
nfa.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/sym.c
sym.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/flex/tblcmp.c
tblcmp.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/closure.c
closure.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/error.c
error.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/lalr.c
lalr.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/lr0.c
lr0.c
../../../src/libCom/yacc/lr0.c(186) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
../../../src/libCom/yacc/lr0.c(314) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/antelope.c
antelope.c
../../../src/libCom/yacc/antelope.c(238) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/mkpar.c
mkpar.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/output.c
output.c
../../../src/libCom/yacc/output.c(1019) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/reader.c
reader.c
../../../src/libCom/yacc/reader.c(1531) : warning C4267: '+=' : conversion from 'size_t' to 'int', possible loss of data
../../../src/libCom/yacc/reader.c(1769) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
c:\jenkins64-1\workspace\epics-base-3.15-win64\src\libcom\yacc\reader.c(282) : warning C4715: 'keyword' : not all control paths return a value
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/skeleton.c
skeleton.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/symtab.c
symtab.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/verbose.c
verbose.c
 om/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c ../../../src/libCom/yacc/warshall.c
warshall.c
link -nologo  -debug -incremental:no -fixed:no /MACHINE:X64             -out:antelope.exe       epicsTempFile.obj closure.obj error.obj lalr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj verbose.obj warshall.obj       ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
../../../bin/windows-x64-static/antelope.exe -bparse -l -d ../../../src/libCom/flex/parse.y
perl -CSD -MExtUtils::Command -e mv parse.tab.c parse.c
perl -CSD -MExtUtils::Command -e mv parse.tab.h parse.h
cl          -DDEFAULT_SKELETON_FILE=flex.skel.static     -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Zi -RTCsu   -W3 -w44355       -MTd    -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../..!
 /../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include        -c parse.c
parse.c
scan.l(935) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(180) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(240) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(269) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(271) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(326) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(347) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
scan.l(363) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(379) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(382) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(385) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(513) : warning C4244: 'initializing' : conversion from '__int64' to 'int', possible loss of data
scan.l(649) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
scan.l(805) : warning C4244: '=' : conversion from '__int64' to 'int', possible loss of data
link -nologo  -debug -incremental:no -fixed:no /MACHINE:X64             -out:e_flex.exe       epicsTempFile.obj ccl.obj dfa.obj ecs.obj gen.obj misc.obj nfa.obj sym.obj tblcmp.obj parse.obj       ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
../../../bin/windows-x64-static/e_flex.exe -S../../../include/flex.skel.static -8 -I -t ../../../src/libCom/as/asLib_lex.l > asLib_lex.yy.c
'..' is not recognized as an internal or external command,
operable program or batch file.
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m warshall.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     warshall.d ../../../src/libCom/yacc/warshall.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m verbose.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    verbose.d ../../../src/libCom/yacc/verbose.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m symtab.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   symtab.d ../../../src/libCom/yacc/symtab.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m skeleton.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     skeleton.d ../../../src/libCom/yacc/skeleton.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m reader.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   reader.d ../../../src/libCom/yacc/reader.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m output.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   output.d ../../../src/libCom/yacc/output.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m mkpar.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  mkpar.d ../../../src/libCom/yacc/mkpar.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m antelope.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include    !
     antelope.d ../../../src/libCom/yacc/antelope.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m lr0.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        l!
 r0.d ../../../src/libCom/yacc/lr0.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m lalr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        !
 lalr.d ../../../src/libCom/yacc/lalr.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m error.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  error.d ../../../src/libCom/yacc/error.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m closure.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include     !
    closure.d ../../../src/libCom/yacc/closure.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m iocLogServer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
         iocLogServer.d ../../../src/libCom/log/iocLogServer.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m parse.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include       !
  parse.d parse.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m tblcmp.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include      !
   tblcmp.d ../../../src/libCom/flex/tblcmp.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m sym.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        s!
 ym.d ../../../src/libCom/flex/sym.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m nfa.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        n!
 fa.d ../../../src/libCom/flex/nfa.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m misc.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        !
 misc.d ../../../src/libCom/flex/misc.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m gen.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        g!
 en.d ../../../src/libCom/flex/gen.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m ecs.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        e!
 cs.d ../../../src/libCom/flex/ecs.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m dfa.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        d!
 fa.d ../../../src/libCom/flex/dfa.c
perl -CSD ../../../bin/windows-x64-static/mkmf.pl  -m ccl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include        c!
 cl.d ../../../src/libCom/flex/ccl.c
make[3]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/libCom/O.windows-x64-static'
make[3]: Entering directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/libCom/O.windows-x64-static'
make[2]: *** [install.windows-x64-static] Error 2
make[2]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `C:/jenkins64-1/workspace/epics-base-3.15-win64/src'
make: *** [src.install] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.15-win64s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-win64s #118 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15-win64 #137 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win32s #116 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win64 #138 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-win64s #118 APS Jenkins
ANJ, 10 Dec 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
