See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32s/116/>
[...truncated 12 lines...]
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86-static ../..
make -C O.win32-x86-static -f ../Makefile TOP=../.. T_A=win32-x86-static install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/configure/O.win32-x86-static'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/configure/O.win32-x86-static'
make[1]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/configure'
make -C ./src install
make[1]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src'
make -C ./tools install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86-static ../../..
make -C O.win32-x86-static -f ../Makefile TOP=../../.. T_A=win32-x86-static install
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/O.win32-x86-static'
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86-static.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
mkdir ../../../bin/win32-x86-static
make[3]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/O.win32-x86-static'
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools'
make -C tools/test install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/test'
perl -CSD ../../../bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../../../..
make -C O.win32-x86-static -f ../Makefile TOP=../../../.. T_A=win32-x86-static install
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/test/O.win32-x86-static'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/test/O.win32-x86-static'
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/tools/test'
make -C template/base install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/base'
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/base/O.win32-x86-static'
make[3]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/base/O.win32-x86-static'
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/base'
make -C template/ext install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/ext'
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/ext/O.win32-x86-static'
make[3]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/ext/O.win32-x86-static'
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/template/ext'
make -C ./libCom install
make[2]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/libCom'
perl -CSD ../../bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../../..
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/libCom/O.win32-x86-static'
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m forceBadAllocException.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../..!
/include forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/forceBadAllocException.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m setThreadName.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
setThreadName.d ../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsGetopt.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsGetopt.d ../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_parser.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_parser.d ../../../src/libCom/yajl/yajl_parser.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_lex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_lex.d ../../../src/libCom/yajl/yajl_lex.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_gen.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_gen.d ../../../src/libCom/yajl/yajl_gen.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_encode.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_encode.d ../../../src/libCom/yajl/yajl_encode.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_buf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_buf.d ../../../src/libCom/yajl/yajl_buf.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl_alloc.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
yajl_alloc.d ../../../src/libCom/yajl/yajl_alloc.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m yajl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include ya!
jl.d ../../../src/libCom/yajl/yajl.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m timerQueuePassive.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../incl!
ude timerQueuePassive.d ../../../src/libCom/timer/timerQueuePassive.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m timerQueueActiveMgr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../in!
clude timerQueueActiveMgr.d ../../../src/libCom/timer/timerQueueActiveMgr.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m timerQueueActive.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
de timerQueueActive.d ../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m timerQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
timerQueue.d ../../../src/libCom/timer/timerQueue.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m timer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include t!
imer.d ../../../src/libCom/timer/timer.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsTimer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsTimer.d ../../../src/libCom/timer/epicsTimer.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m taskwd.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
taskwd.d ../../../src/libCom/taskwd/taskwd.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsRingBytes.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
epicsRingBytes.d ../../../src/libCom/ring/epicsRingBytes.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsRingPointer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
de epicsRingPointer.d ../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m threadPool.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
threadPool.d ../../../src/libCom/pool/threadPool.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m poolJob.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
poolJob.d ../../../src/libCom/pool/poolJob.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdFindAddr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdFindAddr.d ../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdBackTrace.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdBackTrace.d ../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsStackTrace.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
e epicsStackTrace.d ../../../src/libCom/osi/epicsStackTrace.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m devLibVMEOSD.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
devLibVMEOSD.d ../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m devLibVME.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
devLibVME.d ../../../src/libCom/osi/devLibVME.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdMessageQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../includ!
e osdMessageQueue.d ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdNetIntf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdNetIntf.d ../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdProcess.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdProcess.d ../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdTime.d ../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdEvent.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdEvent.d ../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdSpin.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdSpin.d ../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdMutex.d ../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdThreadHooks.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
osdThreadHooks.d ../../../src/libCom/osi/os/default/osdThreadHooks.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdThreadExtra.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
osdThreadExtra.d ../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdThread.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdThread.d ../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdStdio.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdStdio.d ../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsStdio.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsStdio.d ../../../src/libCom/osi/epicsStdio.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsTempFile.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsTempFile.d ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsReadline.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsReadline.d ../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdEnv.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdEnv.d ../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdSignal.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdSignal.d ../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdPoolStatus.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdPoolStatus.d ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdInterrupt.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdInterrupt.d ../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdFindSymbol.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdFindSymbol.d ../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdAssert.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdAssert.d ../../../src/libCom/osi/os/default/osdAssert.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsSocketConvertErrnoToString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32!
../../../include epicsSocketConvertErrnoToString.d ../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m systemCallIntMech.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../incl!
ude systemCallIntMech.d ../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osiSock.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osiSock.d ../../../src/libCom/osi/osiSock.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdSockAddrReuse.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
de osdSockAddrReuse.d ../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osdSock.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osdSock.d ../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m osiClockTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
osiClockTime.d ../../../src/libCom/osi/osiClockTime.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsGeneralTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../inclu!
de epicsGeneralTime.d ../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsAtomicOSD.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
epicsAtomicOSD.d ../../../src/libCom/osi/os/WIN32/epicsAtomicOSD.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsMath.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsMath.d ../../../src/libCom/osi/epicsMath.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsMessageQueue.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../incl!
ude epicsMessageQueue.d ../../../src/libCom/osi/epicsMessageQueue.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsTime.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsTime.d ../../../src/libCom/osi/epicsTime.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsEvent.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsEvent.d ../../../src/libCom/osi/epicsEvent.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsMutex.d ../../../src/libCom/osi/epicsMutex.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsThread.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsThread.d ../../../src/libCom/osi/epicsThread.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsUnitTest.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m ipAddrToAsciiAsynchronous.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../..!
/../include ipAddrToAsciiAsynchronous.d ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m truncateFile.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
truncateFile.d ../../../src/libCom/misc/truncateFile.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsString.d ../../../src/libCom/misc/epicsString.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsStdlib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsStdlib.d ../../../src/libCom/misc/epicsStdlib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsExit.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsExit.d ../../../src/libCom/misc/epicsExit.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsConvert.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsConvert.d ../../../src/libCom/misc/epicsConvert.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m cantProceed.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
cantProceed.d ../../../src/libCom/misc/cantProceed.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m adjustment.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
adjustment.d ../../../src/libCom/misc/adjustment.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m aToIPAddr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
aToIPAddr.d ../../../src/libCom/misc/aToIPAddr.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m alarmString.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
alarmString.d ../../../src/libCom/misc/alarmString.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m macUtil.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
macUtil.d ../../../src/libCom/macLib/macUtil.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m macEnv.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
macEnv.d ../../../src/libCom/macLib/macEnv.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m macCore.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
macCore.d ../../../src/libCom/macLib/macCore.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m logClient.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
logClient.d ../../../src/libCom/log/logClient.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m iocLog.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
iocLog.d ../../../src/libCom/log/iocLog.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m libComRegister.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include!
libComRegister.d ../../../src/libCom/iocsh/libComRegister.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m registry.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
registry.d ../../../src/libCom/iocsh/registry.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m iocsh.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include i!
ocsh.d ../../../src/libCom/iocsh/iocsh.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m gpHashLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
gpHashLib.d ../../../src/libCom/gpHash/gpHashLib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m freeListLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
freeListLib.d ../../../src/libCom/freeList/freeListLib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m fdManager.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
fdManager.d ../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m fdmgr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include f!
dmgr.d ../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h ../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThreadPool.h ../../../src/ioc/db/dbAccessDefs.h ../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h ../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/ca/legacy/pcas/generic/casdef.h ../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m errSymTbl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
errSymTbl.d errSymTbl.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m errSymLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
errSymLib.d ../../../src/libCom/error/errSymLib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m errlog.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
errlog.d ../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m envData.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
envData.d envData.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m envSubr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
envSubr.d ../../../src/libCom/env/envSubr.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m ellLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
ellLib.d ../../../src/libCom/ellLib/ellLib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m dbmf.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include db!
mf.d ../../../src/libCom/dbmf/dbmf.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsSingletonMutex.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../in!
clude epicsSingletonMutex.d ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m epicsOnce.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
epicsOnce.d ../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m resourceLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m cvtFast.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
cvtFast.d ../../../src/libCom/cvtFast/cvtFast.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m calcPerform.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
calcPerform.d ../../../src/libCom/calc/calcPerform.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m postfix.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
postfix.d ../../../src/libCom/calc/postfix.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m bucketLib.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
bucketLib.d ../../../src/libCom/bucketLib/bucketLib.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m asTrapWrite.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
asTrapWrite.d ../../../src/libCom/as/asTrapWrite.c
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -TP -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../!
../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
epicsTempFile.cpp
cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/lib!
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/ccl.c
ccl.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/dfa.c
dfa.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/ecs.c
ecs.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/gen.c
gen.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/misc.c
misc.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/nfa.c
nfa.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/sym.c
sym.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/flex/tblcmp.c
tblcmp.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/closure.c
closure.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/error.c
error.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/lalr.c
lalr.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/lr0.c
lr0.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/antelope.c
antelope.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/mkpar.c
mkpar.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/output.c
output.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/reader.c
reader.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/skeleton.c
skeleton.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/symtab.c
symtab.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/verbose.c
verbose.c
Com/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/yacc/warshall.c
warshall.c
link -nologo -LTCG -incremental:no -opt:ref -release -version:3.15 -out:antelope.exe epicsTempFile.obj closure.obj error.obj lalr.obj lr0.obj antelope.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj verbose.obj warshall.obj ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
Finished generating code
../../../bin/win32-x86-static/antelope.exe -bparse -l -d ../../../src/libCom/flex/parse.y
perl -CSD -MExtUtils::Command -e mv parse.tab.c parse.c
perl -CSD -MExtUtils::Command -e mv parse.tab.h parse.h
cl -DDEFAULT_SKELETON_FILE=flex.skel.static -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MT -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../.!
./../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c parse.c
parse.c
link -nologo -LTCG -incremental:no -opt:ref -release -version:3.15 -out:e_flex.exe epicsTempFile.obj ccl.obj dfa.obj ecs.obj gen.obj misc.obj nfa.obj sym.obj tblcmp.obj parse.obj ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
../../../bin/win32-x86-static/e_flex.exe -S../../../include/flex.skel.static -8 -I -t ../../../src/libCom/as/asLib_lex.l > asLib_lex.yy.c
'..' is not recognized as an internal or external command,
operable program or batch file.
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m warshall.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
warshall.d ../../../src/libCom/yacc/warshall.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m verbose.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
verbose.d ../../../src/libCom/yacc/verbose.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m symtab.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
symtab.d ../../../src/libCom/yacc/symtab.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m skeleton.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
skeleton.d ../../../src/libCom/yacc/skeleton.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m reader.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
reader.d ../../../src/libCom/yacc/reader.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m output.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
output.d ../../../src/libCom/yacc/output.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m mkpar.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include m!
kpar.d ../../../src/libCom/yacc/mkpar.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m antelope.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
antelope.d ../../../src/libCom/yacc/antelope.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m lr0.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include lr0!
.d ../../../src/libCom/yacc/lr0.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m lalr.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include la!
lr.d ../../../src/libCom/yacc/lalr.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m error.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include e!
rror.d ../../../src/libCom/yacc/error.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m closure.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
closure.d ../../../src/libCom/yacc/closure.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m iocLogServer.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
iocLogServer.d ../../../src/libCom/log/iocLogServer.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m parse.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include p!
arse.d parse.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m tblcmp.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include !
tblcmp.d ../../../src/libCom/flex/tblcmp.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m sym.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include sym!
.d ../../../src/libCom/flex/sym.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m nfa.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include nfa!
.d ../../../src/libCom/flex/nfa.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m misc.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include mi!
sc.d ../../../src/libCom/flex/misc.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m gen.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include gen!
.d ../../../src/libCom/flex/gen.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m ecs.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include ecs!
.d ../../../src/libCom/flex/ecs.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m dfa.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include dfa!
.d ../../../src/libCom/flex/dfa.c
perl -CSD ../../../bin/win32-x86-static/mkmf.pl -m ccl.d . ../O.Common . ../../../src/libCom/osi/compiler/msvc ../../../src/libCom/osi/compiler/default . ../../../src/libCom/osi/os/WIN32 ../../../src/libCom/osi/os/default .. ../../../src/libCom/as ../../../src/libCom/bucketLib ../../../src/libCom/calc ../../../src/libCom/cvtFast ../../../src/libCom/cppStd ../../../src/libCom/cxxTemplates ../../../src/libCom/dbmf ../../../src/libCom/ellLib ../../../src/libCom/env ../../../src/libCom/error ../../../src/libCom/fdmgr ../../../src/libCom/flex ../../../src/libCom/freeList ../../../src/libCom/gpHash ../../../src/libCom/iocsh ../../../src/libCom/log ../../../src/libCom/macLib ../../../src/libCom/misc ../../../src/libCom/osi ../../../src/libCom/pool ../../../src/libCom/ring ../../../src/libCom/taskwd ../../../src/libCom/timer ../../../src/libCom/yacc ../../../src/libCom/yacc ../../../src/libCom/yajl ../../../include/compiler/msvc ../../../include/os/WIN32 ../../../include ccl!
.d ../../../src/libCom/flex/ccl.c
make[3]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/libCom/O.win32-x86-static'
make[3]: Entering directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/libCom/O.win32-x86-static'
make[2]: *** [install.win32-x86-static] Error 2
make[2]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `C:/jenkins/win32-1/workspace/epics-base-3.15-win32/src'
make: *** [src.install] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.15-win32s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.15-win32s #117 APS Jenkins
Build failed in Jenkins: epics-base-3.15-win64s #117 APS Jenkins
Jenkins build is back to normal : epics-base-3.15-win32 #126 APS Jenkins
<2014>
2025
2026
Jenkins build is back to normal : epics-base-3.15-win64s #118 APS Jenkins
<2014>
2025
2026
