2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win64 #52
To: [email protected]
Date: Tue, 17 Feb 2015 16:21:50 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/52/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> returned 0. Command output: "12527 [email protected]
" stderr: ""
[epics-base-3.14-win64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
bzr: ERROR: [Error 32] The process cannot access the file because it is being used by another process: u'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/libCom/test/O.windows-x64-static'
ERROR: Failed to run bzr clean-tree
[epics-base-3.14-win64] $ bzr pull --overwrite lp:epics-base/3.14/
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
bzr: ERROR: [Error 5] Access is denied: u'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/libCom/test/.epicsCalcTest.cpp.swp'
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
ERROR: Failed to clean the workspace
java.io.IOException: remote file operation failed: <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> at hudson.remoting.Channel@b58a8bb:win64-1
	at hudson.FilePath.act(FilePath.java:910)
	at hudson.FilePath.act(FilePath.java:887)
	at hudson.FilePath.deleteRecursive(FilePath.java:1076)
	at hudson.plugins.bazaar.BazaarSCM.pull(BazaarSCM.java:396)
	at hudson.plugins.bazaar.BazaarSCM.update(BazaarSCM.java:282)
	at hudson.plugins.bazaar.BazaarSCM.checkout(BazaarSCM.java:260)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1411)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:671)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:580)
	at hudson.model.Run.execute(Run.java:1670)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
	at hudson.model.ResourceController.execute(ResourceController.java:88)
	at hudson.model.Executor.run(Executor.java:231)
Caused by: java.io.IOException: Remote call on win64-1 failed
	at hudson.remoting.Channel.call(Channel.java:727)
	at hudson.FilePath.act(FilePath.java:903)
	... 13 more
Caused by: java.lang.ClassNotFoundException: java.nio.file.FileSystemException
	at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
	at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
	at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:274)
	at java.io.ObjectInputStream.resolveClass(ObjectInputStream.java:624)
	at hudson.remoting.MultiClassLoaderSerializer$Input.resolveClass(MultiClassLoaderSerializer.java:116)
	at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1611)
	at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1516)
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1770)
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1349)
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
	at hudson.remoting.UserRequest.deserialize(UserRequest.java:182)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:211)
	at hudson.remoting.Channel.call(Channel.java:723)
	... 14 more
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-win64 #53 APS Jenkins
Jenkins build is still unstable: epics-base-3.14-win64 #51 APS Jenkins
Prev: Jenkins build is still unstable: epics-base-3.14-win64s #47 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64s #48 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is still unstable: epics-base-3.14-win64 #51 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64 #53 APS Jenkins
