2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win64 #53
To: [email protected]
Date: Tue, 17 Feb 2015 16:24:01 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/53/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
Cleaning workspace...
$ bzr branch lp:epics-base/3.14/ <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
bzr: ERROR: Permission denied: "C:/jenkins64-1/workspace/epics-base-3.14-win64": [Error 5] Access is denied: u'C:/jenkins64-1/workspace/epics-base-3.14-win64'
ERROR: Failed to branch lp:epics-base/3.14/
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
ERROR: Publisher org.tap4j.plugin.TapPublisher aborted due to exception
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> does not exist.
	at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
	at hudson.FilePath.glob(FilePath.java:1621)
	at hudson.FilePath.access$700(FilePath.java:172)
	at hudson.FilePath$30.invoke(FilePath.java:1599)
	at hudson.FilePath$30.invoke(FilePath.java:1596)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2461)
	at hudson.remoting.UserRequest.perform(UserRequest.java:118)
	at hudson.remoting.UserRequest.perform(UserRequest.java:48)
	at hudson.remoting.Request$2.run(Request.java:326)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at hudson.remoting.Engine$1$1.run(Engine.java:58)
	at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is unstable: epics-base-3.14-win64 #54 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win64 #52 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win64s #48 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64s #49 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.14-win64 #52 APS Jenkins
Next: Jenkins build is unstable: epics-base-3.14-win64 #54 APS Jenkins
