2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: recGblInitConstantLink broken in 3.16
To: Michael Davidsaver <[email protected]>
Date: Tue, 17 Mar 2015 04:36:59 +0000
Hi Michael,
You can avoid Jenkins flagging versions with tests that you know will fail by wrapping them in a testTodoBegin("reason"); testTodoEnd(); pair, see epicsMathTest.c for an example. The tests still get run, but the harness knows they're supposed to fail.
- Andrew
Sent from my iPad
> On Mar 16, 2015, at 6:00 PM, Michael Davidsaver <[email protected]> wrote:
>> On 03/16/2015 04:42 PM, Michael Davidsaver wrote:
>> Test case and fix are forthcoming.
> I've added a test which will catch this failure.  The fix isn't ready
> just yet, so the test will fail.
>> # init_record(rec0)
>> not ok  6 - VAL 0==2 (pass0 value)
Re: recGblInitConstantLink broken in 3.16 Michael Davidsaver
Prev: Build failed in Jenkins: epics-base-3.16-cyg64 #9 APS Jenkins
Next: Jenkins build is back to stable : epics-base-3.16 #10 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: recGblInitConstantLink broken in 3.16 Michael Davidsaver
Next: Re: recGblInitConstantLink broken in 3.16 Michael Davidsaver
