2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ao record convert overflow
To: <[email protected]>
Date: Fri, 20 Mar 2015 16:34:47 -0500
Hi Bernd,
On 03/20/2015 06:01 AM, Schoeneburg, Bernd wrote:
> Epics R3.14.11 (same as 3.14.12)  vxWorks Pentium
> I have encountered a problem when using the aoRecord. The convert
> routine produces an "overlow" when the double is casted to long. When
> the value is > (double)LONG_MAX the resulting value of RVAL becomes
> LONG_MIN instead LONG_MAX. This jump is not healthy for output devices.
> Possibly this happens only in my environment of compiler or Pentium
> target.
Your Pentium target might be why you're the first person to report this,
the behaviour on PowerPC might be more sensible (I haven't checked
though). Setting DRVH might have prevented the problem, but the existing
code triggers Undefined Behaviour when the converted raw value falls
outside of the epicsInt32 range, so we do have to fix the code even if
that results in some subtle behaviour change to an existing IOC.
I've just committed the attached changes to the 3.14 branch, which
clamps both the +ve and -ve ends of the conversion. Note that a long is
64 bits wide on some target architectures, so I use explicit literal
values for the 32-bit range limits.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
=== modified file 'src/rec/aiRecord.dbd'
--- src/rec/aiRecord.dbd	2005-11-15 23:35:34 +0000
+++ src/rec/aiRecord.dbd	2015-03-20 18:34:35 +0000
@@ -176,8 +176,8 @@
 		pp(TRUE)
 		interest(2)
-	field(ROFF,DBF_LONG) {
-		prompt("Raw Offset, obsolete")
+	field(ROFF,DBF_ULONG) {
+		prompt("Raw Offset")
 		pp(TRUE)
 		interest(2)
=== modified file 'src/rec/aoRecord.c'
--- src/rec/aoRecord.c	2013-11-20 22:21:10 +0000
+++ src/rec/aoRecord.c	2015-03-20 19:10:43 +0000
@@ -469,10 +469,20 @@
     value -= prec->aoff;
     if (prec->aslo != 0) value /= prec->aslo;
-    if (value >= 0.0)
-        prec->rval = (epicsInt32)(value + 0.5) - prec->roff;
-    else
-        prec->rval = (epicsInt32)(value - 0.5) - prec->roff;
+    /* Apply raw offset and limits, round to 32-bit integer */
+    value -= prec->roff;
+    if (value >= 0.0) {
+        if (value >= (0x7fffffff - 0.5))
+            prec->rval = 0x7fffffff;
+        else
+            prec->rval = (epicsInt32)(value + 0.5);
+    } else {
+        if (value > (0.5 - 0x80000000))
+            prec->rval = (epicsInt32)(value - 0.5);
+        else
+            prec->rval = 0x80000000;
=== modified file 'src/rec/aoRecord.dbd'
--- src/rec/aoRecord.dbd	2002-07-12 21:35:43 +0000
+++ src/rec/aoRecord.dbd	2015-03-20 17:58:18 +0000
@@ -82,8 +82,8 @@
 		interest(1)
 		size(16)
 		pp(TRUE)
 		interest(2)
Re: ao record convert overflow Schoeneburg, Bernd
Prev: RE: [Cs-studio-core] EPICS Meeting at FRIB Maxwell, Dylan
Next: Jenkins build is back to stable : epics-base-3.14-mac #41 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ao record convert overflow Schoeneburg, Bernd
Next: Re: ao record convert overflow Schoeneburg, Bernd
