2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbbi/mbbo default setting
To: EPICS Core-Talk <[email protected]>
Date: Fri, 03 Apr 2015 17:29:19 +0200
As I am already asking stupid questions....
The mbbi/mbbo records implement enums.
Is there a way to set the default value in the database using a choice string?
DOL does not work for the obvious reasons, VAL is an epicsEnum16 that the parser does not accept strings for.
Sure, an additional stringout that has the choice string in its VAL and points to the mbbi/o with PINI=YES. Does not work well with autoSaveRestore, when you want a specific default in case the aSR data does not exist.
Any other ideas?
Cheers,
~Ralph
Re: mbbi/mbbo default setting Andrew Johnson
Prev: Re: Small arrays in rsrv Michael Davidsaver
Next: Re: Small arrays in rsrv Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Small arrays in rsrv Andrew Johnson
Next: Re: mbbi/mbbo default setting Andrew Johnson
