On 04/03/2015 09:50 AM, Michael Davidsaver wrote:
> On 04/03/2015 10:29 AM, Ralph Lange wrote:
>> Looking for a minimally invasive fix...
>> Would you think it is possible and a good idea to base the queuing type
>> decision (by value or by reference) on the size instead of the DBF type,
>> so that arrays <= 64 bit total length (or maybe a configurable value)
>> are put in the queue by value?
>> That would solve our issue, and not create too much exceptionalism, right?
> This would be a change to code handling db_field_log* correct? On the
> one hand I think the semantics of using this structure with arrays is
> already complicated.
> On the other hand enabling DB_EVENT_LOG_STRINGS gives sizeof(union
> native_value)==40, which is certainly enough for your case.
> I support an alternative would be a memory pool for small arrays (<128
> bytes?).
I'm guessing that adding a memory pool would need more invasive work,
whereas just using the storage already available in the db_field_log
objects for array data would need no additional memory allocations.
To be honest I'm slightly surprised that we haven't already done that.
I'd be in favour of the change Ralph is suggesting using the size, and I
would even suggest considering allowing the user to adjust how large the
log buffer is at initialization time. This would allow users to turn on
DB_EVENT_LOG_STRINGS (which nobody else really knows about anyway)
without recompiling.
A 3.15 change IMHO, as is Matej's pCAS update.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- Re: Small arrays in rsrv Michael Davidsaver
- Small arrays in rsrv Ralph Lange
mbbi/mbbo default setting Ralph Lange
<2015>
2025
2026
<2015>
2025
2026
