On 04/08/2015 08:13 AM, Michael Davidsaver wrote:
> On 04/08/2015 08:02 AM, Ralph Lange wrote:
>> So - what to do with 3.15?
>> (I'm afraid waiting for 3.16 is not short-term enough.)
>> I would opt for the simple version: make the buffer statically length 256.
> Or malloc() for a temporary buffer when the static buffer is too short?
Answered my own question, and remembered why I wanted to replace this
code. Too many return paths.
The attached patch works, but probably leaks the buffer on some code paths.
diff --git a/src/ioc/dbStatic/dbStaticLib.c b/src/ioc/dbStatic/dbStaticLib.c
index dfbf3ab..ffb01ff 100644
--- a/src/ioc/dbStatic/dbStaticLib.c
+++ b/src/ioc/dbStatic/dbStaticLib.c
@@ -2088,7 +2088,7 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case DBF_FWDLINK: {
DBLINK *plink;
char string[80];
- char *pstr = string;
+ char *palloc = NULL, *pstr = string;
if (!pfield)
return S_dbLib_fieldNotFound;
@@ -2114,12 +2114,17 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
strcpy(plink->text, pstring);
if (strlen(pstring) >= sizeof(string)) {
- status = S_dbLib_badField;
- errMessage(status,
- "dbPutString received a string that is too long");
- return status;
+ palloc = malloc(strlen(pstring)+1);
+ if(!palloc) {
+ status = S_dbLib_badField;
+ errMessage(status,
+ "dbPutString received a string that is too long");
+ return status;
- strcpy(pstr, pstring);
+ strcpy(palloc, pstring);
+ pstr = palloc;
+ } else
+ strcpy(pstr, pstring);
/* Strip leading blanks and tabs */
while (*pstr && (*pstr == ' ' || *pstr == '\t')) pstr++;
/* Strip trailing blanks and tabs */
@@ -2133,10 +2138,10 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
if (!pstr || !*pstr) {
if (plink->type == PV_LINK) dbCvtLinkToConstant(pdbentry);
- if (plink->type != CONSTANT) return S_dbLib_badField;
+ if (plink->type != CONSTANT) {status = S_dbLib_badField; goto linkcleanup;}
free((void *)plink->value.constantStr);
plink->value.constantStr = NULL;
- goto done;
+ goto linkcleanup;
switch (plink->type) {
case CONSTANT:
@@ -2162,7 +2167,7 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
dbCalloc(strlen(pstr) + 1, sizeof(char));
strcpy(plink->value.constantStr, pstr);
- goto done;
+ break;
if (plink->type==CONSTANT) dbCvtLinkToPvlink(pdbentry);
@@ -2213,18 +2218,18 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
status = putPvLink(pdbentry,ppOpt|msOpt,pstr);
- goto done;
+ break;
/*break; is unnecessary*/
case VME_IO: {
char *end;
- if (!(end = strchr(pstr,'#'))) return S_dbLib_badField;
+ if (!(end = strchr(pstr,'#'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
- if (!(end = strchr(pstr,'C'))) return S_dbLib_badField;
+ if (!(end = strchr(pstr,'C'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.vmeio.card);
- if (!(end = strchr(pstr,'S'))) return S_dbLib_badField;
+ if (!(end = strchr(pstr,'S'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr, &plink->value.vmeio.signal);
status = putParmString(&plink->value.vmeio.parm, pstr);
@@ -2234,15 +2239,15 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case CAMAC_IO: {
char *end;
- if (!(end = strchr(pstr,'#'))) return (S_dbLib_badField);
pstr = end + 1;
- if (!(end = strchr(pstr,'B'))) return (S_dbLib_badField);
+ if (!(end = strchr(pstr,'B'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.camacio.b);
- if (!(end = strchr(pstr,'C'))) return (S_dbLib_badField);
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.camacio.c);
- if (!(end = strchr(pstr,'N'))) return (S_dbLib_badField);
+ if (!(end = strchr(pstr,'N'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.camacio.n);
if (!(end = strchr(pstr,'A'))) {
@@ -2264,18 +2269,18 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case RF_IO: {
char *end;
- if(!(end = strchr(pstr,'#'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'#'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
- if(!(end = strchr(pstr,'R'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'R'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.rfio.cryo);
- if(!(end = strchr(pstr,'M'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'M'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.rfio.micro);
- if(!(end = strchr(pstr,'D'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'D'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.rfio.dataset);
- if(!(end = strchr(pstr,'E'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'E'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.rfio.element);
@@ -2283,18 +2288,18 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case AB_IO: {
char *end;
pstr = end + 1;
- if(!(end = strchr(pstr,'L'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'L'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.abio.link);
- if(!(end = strchr(pstr,'A'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'A'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.abio.adapter);
- if(!(end = strchr(pstr,'C'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'C'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.abio.card);
- if(!(end = strchr(pstr,'S'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'S'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.abio.signal);
status = putParmString(&plink->value.abio.parm,pstr);
@@ -2303,12 +2308,12 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case GPIB_IO: {
char *end;
pstr = end + 1;
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.gpibio.link);
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.gpibio.addr);
status = putParmString(&plink->value.gpibio.parm,pstr);
@@ -2321,21 +2326,21 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
char *end;
short tmp_val;
pstr = end + 1;
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&tmp_val);
plink->value.bitbusio.link=(unsigned char)tmp_val;
- if(!(end = strchr(pstr,'N'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'N'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
plink->value.bitbusio.node=(unsigned char)tmp_val;
- if(!(end = strchr(pstr,'P'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'P'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
plink->value.bitbusio.port=(unsigned char)tmp_val;
pstr = end + 1;
plink->value.bitbusio.signal=(unsigned char)tmp_val;
@@ -2349,17 +2354,17 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
char *end;
short tmp_val;
pstr = end + 1;
pstr = end + 1;
plink->value.bbgpibio.link=(unsigned char)tmp_val;
- if(!(end = strchr(pstr,'B'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'B'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
plink->value.bbgpibio.bbaddr=(unsigned char)tmp_val;
- if(!(end = strchr(pstr,'G'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'G'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
plink->value.bbgpibio.gpibaddr=(unsigned char)tmp_val;
@@ -2369,21 +2374,21 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
case VXI_IO: {
char *end;
pstr = end + 1;
memset((char *)&plink->value.vxiio,0,sizeof(struct vxiio));
plink->value.vxiio.parm = pNullString;
if(!((end = strchr(pstr,'C'))&&(end < strchr(pstr,'@')) )) {
plink->value.vxiio.flag = VXISTATIC;
- if(!(end = strchr(pstr,'V'))) return (S_dbLib_badField);
+ if(!(end = strchr(pstr,'V'))) {status = S_dbLib_badField; break;}
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.vxiio.la);
} else {
plink->value.vxiio.flag = VXIDYNAMIC;
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.vxiio.frame);
pstr = end + 1;
cvtDecimalOrHexToShort(pstr,&plink->value.vxiio.slot);
@@ -2401,10 +2406,13 @@ long dbPutString(DBENTRY *pdbentry,const char *pstring)
break;
+linkcleanup:
+ free(palloc);
break;
default:
- return S_dbLib_badField;
+ break;
done:
if (!status && strcmp(pflddes->name, "VAL") == 0) {
- Raising the 80 char limit on INP/OUT strings? Ralph Lange
- Re: Raising the 80 char limit on INP/OUT strings? Ralph Lange
- Re: Raising the 80 char limit on INP/OUT strings? Michael Davidsaver
<2015>
2025
2026
<2015>
2025
2026
