2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199
To: <[email protected]>
Date: Wed, 29 Apr 2015 17:23:20 -0500
On 04/29/2015 04:40 PM, APS Jenkins wrote:
> See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/199/changes>
> Changes:
> [Andrew Johnson] Merged Cygwin fix from 3.14 branch, revno 12584
That fix just made it possible to build on the updated Cygwin which I
installed earlier...
> perl -CSD scanIoTest.t -tap > scanIoTest.tap
> Starting iocInit
> iocRun: All initialization complete
> Starting iocInit
The build hangs completely at this point (inside scanIoTest.exe) so the
job never finishes unless stopped manually. I tried connecting to it
with gdb (installation of which was why I had updated Cygwin earlier),
but the backtraces I got were singularly unhelpful as they all ended
like this just where it would show our code:
#2  0x0000000000000000 in ?? ()
Backtrace stopped: previous frame inner to this frame (corrupt stack?)
That might be because Cygwin builds don't default to using -g, so I
tried rebuilding manually with -g and running the test by hand under
gdb, but of course it never hangs when I do that. I'll commit the -g
change and try this again on Friday.
> src/ioc/db/test/O.cygwin-x86_64/scanIoTest.tap ...............
> Failed 7/10 subtests
That does tell me the first 3 tests succeeded.
Oh, and with this new version of Cygwin:
> src/libCom/test/O.cygwin-x86_64/blockingSockTest.tap .........
> Failed 1/13 subtests
That failure being:
# This OS behaves like "esscimqi_socketBothShutdownRequired".
not ok 13 - Declared mechanism works
# epicsSocketSystemCallInterruptMechanismQuery returned
"esscimqi_socketCloseRequired"
So Cygwin has changed its socket shutdown behaviour again...
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199 Andrew Johnson
Build failed in Jenkins: epics-base-3.15-cyg64 #198 APS Jenkins
Build failed in Jenkins: epics-base-3.15-cyg64 #199 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15-cyg64 #199 APS Jenkins
Next: Cygnus support Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199 Andrew Johnson
