2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199
To: <[email protected]>
Date: Fri, 1 May 2015 11:41:25 -0500
On 04/29/2015 05:23 PM, Andrew Johnson wrote:
> Oh, and with this new version of Cygwin:
>> src/libCom/test/O.cygwin-x86_64/blockingSockTest.tap .........
>> Failed 1/13 subtests
> That failure being:
> # This OS behaves like "esscimqi_socketBothShutdownRequired".
> not ok 13 - Declared mechanism works
> # epicsSocketSystemCallInterruptMechanismQuery returned
> "esscimqi_socketCloseRequired"
> So Cygwin has changed its socket shutdown behaviour again...
Wrong, the major version number changed from 1007 to 2000 and the #if
test that we had in libCom/osi/os/cygwin32/systemCallIntMech.cpp to fix
the time when it did change was wrong. In 3.14 we have #if 0 instead,
which is why the test passed. If we're lucky this commit might also fix
the hangup.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Build failed in Jenkins: epics-base-3.15-cyg64 #198 APS Jenkins
Build failed in Jenkins: epics-base-3.15-cyg64 #199 APS Jenkins
Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199 Andrew Johnson
Prev: Re: Cygnus support Michael Davidsaver
Next: Jenkins build is still unstable: epics-base-3.15-win64s #158 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build failed in Jenkins: epics-base-3.15-cyg64 #199 Andrew Johnson
Next: Jenkins build is back to normal : epics-base-3.15-cyg64 #200 APS Jenkins
