2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-cyg64 #224
To: [email protected]
Date: Fri, 18 Sep 2015 15:31:04 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/224/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on cyg64-1 (cyg64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/> returned 0. Command output: "12702 [email protected]
" stderr: ""
[epics-base-3.15-cyg64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.15-cyg64] $ bzr pull --overwrite lp:epics-base/3.15/
bzr: ERROR: Cannot lock LockDir(file:///C:<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/.bzr/branch/lock)>: Permission denied: "C:<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/.bzr/branch/lock/usw11z8ctb.tmp";>: [Error 5] Access is denied: u'C:<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/.bzr/branch/lock/usw11z8ctb.tmp'>
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-cyg64 #225 APS Jenkins
Build failed in Jenkins: epics-base-3.15-cyg64 #223 APS Jenkins
Prev: Re: Q: Portable way to construct a filename? Andrew Johnson
Next: Jenkins build is back to normal : epics-base-3.15-cyg64 #225 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.15-cyg64 #223 APS Jenkins
