2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Q: Portable way to construct a filename?
To: <[email protected]>
Date: Fri, 18 Sep 2015 15:20:49 -0500
On 09/18/2015 10:01 AM, Ralph Lange wrote:
> For use inside EPICS Base V3:
> What is a portable way to concatenate a directory name (received as
> iocShell command argument) and a filename (from a readdir() entry) into
> a path string that can be used in a fopen() call?
There are no calls to readdir() from C/C++ code in Base yet, do you know
that is portable? Some of the VxWorks and/or RTEMS file-systems might
not support it although I believe the API itself is present.
What is this for?
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Q: Portable way to construct a filename? Ralph Lange
Prev: Re: Q: Portable way to construct a filename? Ralph Lange
Next: Build failed in Jenkins: epics-base-3.15-cyg64 #224 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Portable way to construct a filename? nick.rees
Next: Re: Q: Portable way to construct a filename? Ralph Lange
