2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Q: Portable way to construct a filename?
To: EPICS Core-Talk <[email protected]>
Date: Mon, 21 Sep 2015 12:28:14 +0200
On 18/09/2015 22:20, Andrew Johnson wrote:
On 09/18/2015 10:01 AM, Ralph Lange wrote:
For use inside EPICS Base V3:
What is a portable way to concatenate a directory name (received as
iocShell command argument) and a filename (from a readdir() entry) into
a path string that can be used in a fopen() call?
There are no calls to readdir() from C/C++ code in Base yet, do you know
that is portable? Some of the VxWorks and/or RTEMS file-systems might
not support it although I believe the API itself is present.
What is this for?
I am very carefully reading man pages and try to only rely on the very minimum common denominator / POSIX2001 parts.
Application: a new iocsh command.
iocshLoadDir <pathname> <macros>
Source files inside a directory.
iocshLoadDir creates a list of all files in the specified directory that are not directories themselves and whose file names
  •  start with a number,
  •  do not contain a dot ('. '), and
  •  do not end with a tilde ('~').
It then sources (via the iocshLoad command) all matching files in alphabetical order, supplying the specified macro substitutions.
This will allow to get rid of all the ugliness linked to sets of '< stcmd-snippet' lines with fixed names and orders inside a st.cmd file, replacing it with a standard mechanism that allows easy non-conflicting installation of st.cmd snippets by different apps, different system packages etc.
The actual names, phases and related numbers are completely left to the users' conventions - base just provides the mechanism.
Implementation is one additional C++ source file and its entry in the Makefile - doesn't change any existing code or functionality - no compatibility issues.
(Could even be applied to 3.14 as an easy addition/patch.)
I was also considering to add a test on the first argument to an IOC binary an the command line (the name of the command file to run), and call iocshLoadDir() instead of iocshLoad() if the argument is a directory.
But that's less important than the command itself, and does add changes to an existing file, so ... well, maybe. What do you think?
This and the rsrv-binds-to-specified-interface issue are the two things I intend to get into 3.15.3 (in addition to all fixes).
Cheers,
~Ralph
Re: Q: Portable way to construct a filename? Ralph Lange
Re: Q: Portable way to construct a filename? Andrew Johnson
Prev: Jenkins build is back to normal : epics-base-3.16-win32-test #11 APS Jenkins
Next: Re: Q: Portable way to construct a filename? Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Q: Portable way to construct a filename? Andrew Johnson
