2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RFC: Creating st.cmd from snippets
To: <[email protected]>
Date: Thu, 24 Sep 2015 12:20:31 +0200
On 09/23/2015 09:37 PM, Ralph Lange wrote:
>> I'm starting to think that being explicit about which files go into
>> the output file might be a better approach as Torsten suggested.
>> The IOC developer then has the final say as to what gets run, and
>> nobody else can just add a file to the global snippets directory to
>> have their code run on all IOCs — that could be really bad. Of
>> course you can still use wildcards in the list if desired for your
>> site.
> Using directories (or wildcards) is the whole point of my use case.
> If a new version of my global support module needs an additional line
> in the st.cmd, I want its RPM to drop it in the global snippets dir,
> rebuild my ~500 IOCs and be done with it. I do *not* want to update
> 500 Makefiles. I want my configuration database exporter to populate
> a single directory with all generated st.cmd content (from the
> database) for a specific IOC, and have it merged with the developer's
> special snippets (under version control) without having to change the
> version controlled Makefile.
I find this argument pretty convincing.
Here at BESSY we create st.cmd files together with their binaries and
dbd files from a common set of templates (for st.cmd files) and
hierarchical information we keep in data structures in perl modules.
There is one of these per IOC. The scenario Ralph is alluding to we
solve by allowing the perl modules to be based on other perl modules of
the same sort. Thus we have e.g. one MultiCAN.pm which contains every
piece of information that is common to all IOCs that use CAN; the IOC.pm
import them and the generic mechanism takes care to merge the
information from all imported modules before fleshing out the
template(s) and creating the Makefile snippets for the libraries etc.
Our mechanism is quite specifically tailored to the task, and thus not
as general as the one Ralph wants to create. I wonder if it could be
adapted to make use of Ralph's more general solution...
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
RFC: Creating st.cmd from snippets Ralph Lange
Re: RFC: Creating st.cmd from snippets Andrew Johnson
Re: RFC: Creating st.cmd from snippets Torsten Bögershausen
Re: RFC: Creating st.cmd from snippets Ralph Lange
Prev: Re: RFC: Creating st.cmd from snippets Ralph Lange
Next: Base 3.15.3-pre1 is SLIP, new date 07-Oct-2015 Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RFC: Creating st.cmd from snippets Ralph Lange
