2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASYN Device Support Issue
Cc: EPICS Core-Talk <[email protected]>
Date: Thu, 1 Oct 2015 15:07:42 +0200
Hi Mark,
The processRrrr() routines of the ASYN Device support for input records always set the VAL (or RVAL) field and return success, even if the call to queueRequest() acquiring the value fails.
In our case, with a non-blocking ASYN driver for a PXIe board, the RVAL field of the mbbi record showing the board status is always set to 0 (= "OK"), even when there is no such board present and the device never connects. We are pre-setting the database with 4 = "no board", but that gets overwritten with 0 ="OK" at every processing.
That doesn't seem right, does it?
Shouldn't the process routine leave the value unchanged and return an error when reading fails?
Thanks a lot,
~Ralph
RE: ASYN Device Support Issue Mark Rivers
Prev: Base 3.15.3-pre1 is SLIP, new date 07-Oct-2015 Ralph Lange
Next: RE: ASYN Device Support Issue Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
