2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN Device Support Issue
Cc: "'EPICS Core-Talk'" <[email protected]>
Date: Thu, 1 Oct 2015 11:50:15 -0500
Hi Mark,
On 10/01/2015 09:53 AM, Mark Rivers wrote:
> I have another question.  What does EPICS base do when the process()
> routine for an input record returns an error?  Is there a specific
> error code it should return, or is any non-zero value OK?
The return value should be a status code which gets passed back to
whatever triggered the processing. Unfortunately it is not uniformly
handled inside the IOC at the moment; in some places it gets ignored
completely (callback.c), but in others it gets turned into a message
string and printed (e.g. by the iocsh dbtr command) and may even be
passed back to the CA client that triggered the processing as a CA
exception.
The status codes are the S_* macros defined in various header files such
as devSup.h drvSup.h and recSup.h. The message string is the comment
that immediately follows the macro definition which gets extracted from
the header file at IOC build-time. Support modules can add their own
status codes but the interface for doing that has not been revised for
many years and might not work too well (I have looked at it a little but
haven't done much work to improve it yet).
HTH,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
ASYN Device Support Issue Ralph Lange
RE: ASYN Device Support Issue Mark Rivers
Prev: RE: ASYN Device Support Issue Mark Rivers
Next: RE: ASYN Device Support Issue Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
