2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?)
To: Ron Sluiter <[email protected]>, Andrew Johnson <[email protected]>, Tim Mooney <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Wed, 14 Oct 2015 13:22:03 +0200
Hej,
after 2 days trying to make my little problem re-producable at other sites,
here is the result:
#Clone the repository from here:
git clone https://github.com/EuropeanSpallationSource/MCAG_setupMotionDemo.git
cd MCAG_setupMotionDemo
git checkout 151013_setup_demo
./setup.sh
This will get you a working demo... but wait:
When I showed the problem this morning to my collegue and hovered over the
IOC:m1.RBV field, we found that there are 2 fields in CSS:
IOC:m1.RBV and IOC:m1.RBV.SIMM
The .SIMM does not exist somewhere in the DB and so it is showed as "disconnected".
The "disconnected" hides (on the screen) the fact that IOC:m1.RBV is connected.
I don't really know how this came into my life, probably I used CSS wrong,
but I think we can relax a little bit.
There seems still to be an issue if the motor wakes up at exactly position 0.0,
which seems to make the motor record to stay unprocessed in some way.
I will have closer look tomorrow.
Thanks so much for helping me out.
[snip]
Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Michael Davidsaver
Re: Fwd: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Ron Sluiter
Prev: Re: EPICS Base R3.15.3-pre1 available Andrew Johnson
Next: linker search path (why not -L. ?) Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Ron Sluiter
Next: Build failed in Jenkins: epics-base-3.15-win32-test #10 APS Jenkins
