2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: linker search path (why not -L. ?)
Date: Tue, 20 Oct 2015 12:27:37 -0400
I've occasionally run into weirdness when I have a PROD linking against a LIBRARY built in the same directory.  Is there some reason that the build directory isn't included in the linker search path?  That is "-L." in addition to "-L$(TOP)/lib/$(T_A)".
In this case I discovered that the mingw cross compiler now includes libevr.a, as does mrfioc2...  At least in this case the order of the rules tries to link the executable before the locally built library is installed $(TOP)/lib, so the linker finds the system library.  I'd imagine that in other situations this could result in linking against an older version of a library.
Re: linker search path (why not -L. ?) Johnson, Andrew N.
Prev: Re: Fwd: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Torsten Bögershausen
Next: Re: linker search path (why not -L. ?) Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win32-test #13 APS Jenkins
