2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base R3.15.3-rc1 available
To: Ralph Lange <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Tue, 3 Nov 2015 15:30:54 +0100
There is one small problem in the build system (probably in all 3.15
versions) and it concerns dependency generation when a generated header
file is included. This can cause error messages from gcc when using
parallel make, such as
> ../builtin.c:11:17: fatal error: snl.h: No such file or directory
> #include "snl.h"
> compilation terminated.
The solution is to add -MG to the compiler flags when generating
dependencies (see the attached patch). According to the gcc man page,
"-MG assumes missing header files are generated files and adds them to
the dependency list without raising an error."
Cheers
Ben
On 10/28/2015 09:36 AM, Ralph Lange wrote:
> Dear all,
> The first release-candidate of the upcoming 3.15.3 version of Base can
> now be downloaded from the usual places:
> http://www.aps.anl.gov/epics/base/R3-15/3.php
> https://launchpad.net/epics-base/3.15/3.15.3
> If you have time to help, please try building and using this release
> candidate, then report any problems you had with it as soon as possible
> on the Launchpad bug tracker or on core-talk.
> This help is especially valuable if you use less common target
> architectures or if you are maintaining important Base modules.
> *If there are no objections, the final 3.15.3 release will be bundled in
> about a week.**
> 3.15.3 features mainly bugfixes taken from the 3.14 series, some
> cleanup, configurable NTP synchronization on vxWorks, and a way to
> assemble configuration files from numbered snippets.
> Please refer to the release notes (in the documentation folder or on the
> APS web page) for more details.
> Thanks a lot to everyone who has contributed to this version.
> Cheers,
> ~Ralph
"Make it so they have to reboot after every typo." ― Scott Adams
diff -rN -u old-base-3.15.3-rc1/configure/CONFIG.gnuCommon new-base-3.15.3-rc1/configure/CONFIG.gnuCommon
--- old-base-3.15.3-rc1/configure/CONFIG.gnuCommon	2015-11-03 13:26:53.108398367 +0100
+++ new-base-3.15.3-rc1/configure/CONFIG.gnuCommon	2015-11-03 13:26:53.108398367 +0100
@@ -57,5 +57,5 @@
 # Use compiler flags to generate header dependancies files
 HDEPENDS_METHOD = COMP
-HDEPENDS_COMPFLAGS = -MM -MF $@
+HDEPENDS_COMPFLAGS = -MM -MG -MF $@
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS Base R3.15.3-rc1 available Benjamin Franksen
Re: EPICS Base R3.15.3-rc1 available Andrew Johnson
EPICS Base R3.15.3-rc1 available Ralph Lange
Prev: EPICS Base R3.15.3-rc1 available Ralph Lange
Next: Re: EPICS Base R3.15.3-rc1 available Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
