2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Proposed change to asyn drvAsynIPPort for UDP sockets
To: "'Eric Norum'" <[email protected]>
Cc: EPICS Core-Talk <[email protected]>, Henrique Almeida <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 9 Dec 2015 16:14:23 +0000
Ø  Yes, you need a separate address structure and length to hold the sender address.
Done and committed to github, tag R4-28beta3.
Sent: Wednesday, December 09, 2015 9:55 AM
To: Mark Rivers
Cc: Torsten bögershaus; EPICS Core-Talk; Henrique Almeida; EPICS Tech Talk
Subject: Re: Proposed change to asyn drvAsynIPPort for UDP sockets
.I missed that.
On Dec 9, 2015, at 7:33 AM, Mark Rivers <[email protected]> wrote:
The problem is that when recvfrom() is called in readIt() and flushIt(), the IP address and port of the remote sender will replace the values in tty->farAddr.oa.sa.  This means that the next time octetWrite() is called, it will call sendto() using the address of the last responder, not the address that was originally specified when creating the port.  I don’t think this is the correct behavior.  The solution is to use a local  osiSockAddr variable to receive the sender’s address information in readIt() and flushIt(), not tty->farAddr.oa.sa.
Eric Norum
[email protected]
Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
Re: Proposed change to asyn drvAsynIPPort for UDP sockets Henrique Almeida
RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
Re: Proposed change to asyn drvAsynIPPort for UDP sockets Torsten bögershaus
Re: Proposed change to asyn drvAsynIPPort for UDP sockets Eric Norum
Prev: Re: Proposed change to asyn drvAsynIPPort for UDP sockets Torsten bögershaus
Next: RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposed change to asyn drvAsynIPPort for UDP sockets Eric Norum
Next: Re: Proposed change to asyn drvAsynIPPort for UDP sockets Torsten bögershaus
