2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: Wrong beacon source IP address
To: [email protected]
Date: Fri, 18 Dec 2015 08:43:29 -0500
On 12/18/2015 03:13 AM, Ralph Lange wrote:
> Dear colleagues,
> I think Anze's got a point here.
Agreed.  Beacons should appear to come from the appropriate source address.  I should note that RSRV tries to put the correct interface address in the message body (and succeeds in at least some cases).
http://bazaar.launchpad.net/~epics-core/epics-base/3.16/view/head:/src/ioc/rsrv/online_notify.c#L263
> What are the consequences? Are there any?
I doubt there are any real consequences either to the present behavior, or to fixing it.
> Cheers,
> ~Ralph
> -------- Forwarded Message --------
> Subject: 	Wrong beacon source IP address
> From: 	Anze Zagar <[email protected]>
> I was playing around with CA beacons a little bit, and observed some
> surprising behaviour.
> On my system I have three network interfaces:
> eth0
>   inet addr:10.5.4.190  Bcast:10.5.7.255  Mask:255.255.248.0
> vmnet1
>   inet addr:192.168.103.1  Bcast:192.168.103.255  Mask:255.255.255.0
> vmnet8
>   inet addr:172.16.209.1  Bcast:172.16.209.255  Mask:255.255.255.0
> Now if I run EPICS IOC, it will send beacons to all three broadcast
> addresses, however the source address (in the IP frame of the beacon UDP
> packet) will in all three cases correspond to the IP address of the
> first interface. Thus with EPICS_CA_AUTO_ADDR_LIST=yes, source IP is
> always 10.5.4.190.
> And if I configure, e.g.:
> export EPICS_CA_AUTO_ADDR_LIST=no
> export EPICS_CA_ADDR_LIST="192.168.103.255 172.16.209.255 10.5.7.255"
> source IP is 192.168.103.1 for all three subnets (see also the attached
> wireshark screenshot).
> I noticed that this may impact some CA client implementations, because
> they expect beacon to have the source address corresponding to existing
> CA connections (which will obviously not be the case for second and
> third subnet). Effectively, it will ignore all beacons and check for the
> IOC availability by pinging them instead. Additionally, it will also not
> reuse CA connections for multiple PVs hosted on the same server.
> I observed this on EPICS 3.14.12.5. Do you know, if this is something
> known or expected?
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Fwd: Wrong beacon source IP address Andrew Johnson
Fwd: Wrong beacon source IP address Ralph Lange
Prev: caget delays Benjamin Franksen
Next: Re: caget delays Hartman, Steven M.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Wrong beacon source IP address Ralph Lange
Next: Re: Fwd: Wrong beacon source IP address Andrew Johnson
ANJ, 18 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
