2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: Wrong beacon source IP address
To: <[email protected]>
Date: Fri, 18 Dec 2015 16:39:30 -0600
I mis-read Anze's original description, and it now sounds to me like
there may be a bug in his network stack. Is it really possible to send
out a broadcast UDP message that has a different IP source address than
the address of the network interface you're sending it out from? I would
expect something like that to only be possible if you're running as root.
Could this me something to do with the configuration of his virtual
network ports, or with his Wireshark setup? I would like to see this
experiment repeated on a machine that has multiple real interfaces,
because it doesn't make sense to me.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Fwd: Wrong beacon source IP address Ralph Lange
Re: Fwd: Wrong beacon source IP address Michael Davidsaver
Re: Fwd: Wrong beacon source IP address Andrew Johnson
Prev: Re: Fwd: Wrong beacon source IP address Michael Davidsaver
Next: Re: Fwd: Wrong beacon source IP address Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
