Hello, I'm testing an IOC that uses autosave-5-6-1 from synApps 5.8 and I'm seeing a large amount of crashes during IOC boot. Spreading debug messages through EPICS code showed that autosave was calling the function epicsMessageQueueSend() with a null message queue object, for example: (...) iocRun: All initialization complete makeAutosaveFileFromDbInfo("/usr/local/epics/apps/config/SOL1/autosave/parker_positions1.req", "autosaveFields_pass0") dbpf SOL1:PARKER1:m1.SSET 1 DBR_SHORT: 1 0x1 create_triggered_set("parker_positions1.req", SOL1:PARKER1:autosave.VAL, "") fdbrestore("parker_positions1.sav") save_restore:fdbrestore:entry ../save_restore.c:request_manual_restore:2678 Called epicsMessageQueueSend with opMsgQueue=NULL pmg=NULL save_restore:806 Falha de segmentação (imagem do núcleo gravada) Core dump backtrace shows the same problem: (gdb) bt #0 0x001e454f in mySend (pmsg=0x0, message=0xbfb95e2c, size=500, timeout=-1) at ../../../src/libCom/osi/os/default/osdMessageQueue.cpp:161 #1 0x00768cd0 in request_manual_restore (filename=0x836ea3b "parker_positions1.sav", file_type=1, macrostring=0x0, callbackFunction=0x7663c0 <defaultCallback>, puserPvt=0x0) at ../save_restore.c:2680 #2 0x00768e5b in fdbrestore (filename=0x836ea3b "parker_positions1.sav") at ../save_restore.c:2639 #3 0x00768e8f in fdbrestore_CallFunc (args=0x83080c0) at ../save_restore.c:3566 #4 0x001cfcb1 in iocshBody (pathname=<value optimized out>, commandLine=0x0, macros=0x0) at ../../../src/libCom/iocsh/iocsh.cpp:813 #5 0x001d0475 in iocsh (pathname=0xbfb96729 "./parker_st1.cmd") at ../../../src/libCom/iocsh/iocsh.cpp:881 #6 0x0804e33d in main (argc=2, argv=0xbfb96264) at ../motorPXIMain.cpp:17 Can anybody confirm this problem ? Here is the relevant st.cmd snippet: set_requestfile_path("${MOTORHYPPIE_AUTOSAVE}", "") set_savefile_path("${MOTORHYPPIE_AUTOSAVE}", "") set_pass0_restoreFile("parker_positions1.sav") save_restoreSet_NumSeqFiles(0) save_restoreSet_DatedBackupFiles(0) pxiCreateSM("motor","COM3PARKER1Motor1") motorHyppieSetup(10, 1) motorHyppieConfig(0,"COM3PARKER1Motor1") dbLoadTemplate ("/usr/local/epics/apps/config/${EPICS_HOSTNAME}/parker_motor1.substitutions") cd ${TOP}/iocBoot/${IOC} iocInit makeAutosaveFileFromDbInfo("${MOTORHYPPIE_AUTOSAVE}/parker_positions1.req", "autosaveFields_pass0") dbpf SOL1:PARKER1:m1.SSET 1 create_triggered_set("parker_positions1.req", SOL1:PARKER1:autosave.VAL, "") fdbrestore("parker_positions1.sav") dbpf SOL1:PARKER1:m1.SUSE 1
| ANJ, 27 Jan 2016 |
Home
News
About
Talk
Base
Modules
Extensions
