2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.16-win32 #56
To: [email protected]
Date: Tue, 9 Feb 2016 16:09:05 -0500
Thanks Andrew!
On 02/09/2016 03:11 PM, Andrew Johnson wrote:
> On 02/08/2016 07:01 PM, APS Jenkins wrote:
>> cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../..!
>>  /src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include         -c ../../../src/libCom/freeList/freeListLib.c
>> freeListLib.c
>> ../../../src/libCom/freeList/freeListLib.c(110) : error C2036: 'void *' : unknown size
> Line 110 of freeListLib.c is
>         ptemp += REDZONE; /* skip first REDZONE */
> Since ptemp is a void *, standard C doesn't let you do math on its value.
> After fixing that too the build now completes for both 32 and 64-bit
> targets, so I'm committing those changes.
> - Andrew
Build failed in Jenkins: epics-base-3.16-win32 #56 APS Jenkins
Re: Build failed in Jenkins: epics-base-3.16-win32 #56 Andrew Johnson
Prev: Jenkins build is back to normal : epics-base-3.16-win64s #53 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-win32s #57 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build failed in Jenkins: epics-base-3.16-win32 #56 Andrew Johnson
Next: Jenkins build is back to normal : epics-base-3.16-win32 #57 APS Jenkins
ANJ, 09 Feb 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
