2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13
To: <[email protected]>
Date: Fri, 12 Feb 2016 11:33:58 -0600
Hi Michael,
On 02/12/2016 11:06 AM, APS Jenkins wrote:
> src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
> src/std/rec/test/O.linux-x86/asTest.tap .................. ok
> Bailout called.  Further testing stopped:  testMonitorWait() exceeds timeout
> FAILED--Further testing stopped: testMonitorWait() exceeds timeout
My fix was just to re-run the tests; given that this failure has
happened before on a different architecture, I think the 10 second
timeout delay in testMonitorWait() is just too short for a busy build
slave. Since the effect of failure is to kill all further testing I have
bumped it all the way up to 60 seconds.
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
Build failed in Jenkins: epics-base-3.16-linux32-test #13 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.16-linux32-test #14 APS Jenkins
Next: Bug in dbGet() with server-side plugins Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
ANJ, 15 Feb 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
