2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-cyg64 #269
To: [email protected]
Date: Fri, 13 May 2016 15:13:56 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/269/>
Started by upstream project "epics-base-3.15" build number 266
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on cyg64-1 (cyg64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/> returned 0. Command output: "12759 [email protected]
" stderr: ""
[epics-base-3.15-cyg64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
FATAL: Invalid object ID 129 iota=130
java.lang.IllegalStateException: Invalid object ID 129 iota=130
	at hudson.remoting.ExportTable.diagnoseInvalidId(ExportTable.java:386)
	at hudson.remoting.ExportTable.get(ExportTable.java:330)
	at hudson.remoting.Channel.getExportedObject(Channel.java:633)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:599)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:583)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:542)
	at hudson.remoting.UserRequest.perform(UserRequest.java:120)
	at hudson.remoting.UserRequest.perform(UserRequest.java:48)
	at hudson.remoting.Request$2.run(Request.java:332)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	at ......remote call to cyg64-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1416)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:220)
	at hudson.remoting.Channel.call(Channel.java:781)
	at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:250)
	at com.sun.proxy.$Proxy58.join(Unknown Source)
	at hudson.Launcher$RemoteLauncher$ProcImpl.join(Launcher.java:991)
	at hudson.Launcher$ProcStarter.join(Launcher.java:388)
	at hudson.plugins.bazaar.BazaarSCM.cleantree(BazaarSCM.java:340)
	at hudson.plugins.bazaar.BazaarSCM.update(BazaarSCM.java:279)
	at hudson.plugins.bazaar.BazaarSCM.checkout(BazaarSCM.java:260)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1269)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:607)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
	at hudson.model.Run.execute(Run.java:1738)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:410)
Caused by: java.lang.Exception: Object was recently deallocated
    #129 (ref.0) : object=null type=hudson.Launcher$RemoteLaunchCallable$1 interfaces=[hudson.Launcher$RemoteProcess]
      Created at Fri May 13 15:13:56 CDT 2016
    	at hudson.remoting.ExportTable$Entry.<init>(ExportTable.java:99)
    	at hudson.remoting.ExportTable.export(ExportTable.java:305)
    	at hudson.remoting.Channel.internalExport(Channel.java:629)
    	at hudson.remoting.Channel.export(Channel.java:620)
    	at hudson.remoting.Channel.export(Channel.java:590)
    	at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1150)
    	at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1113)
      Released at Fri May 13 15:13:56 CDT 2016
    	at hudson.remoting.ExportTable$Entry.release(ExportTable.java:131)
    	at hudson.remoting.ExportTable.unexportByOid(ExportTable.java:414)
    	at hudson.remoting.Channel.unexport(Channel.java:641)
    	at hudson.remoting.UnexportCommand.execute(UnexportCommand.java:43)
    	at hudson.remoting.Channel$1.handle(Channel.java:501)
    	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:60)
    Caused by: Command hudson.remoting.UnexportCommand@e63b33 created at
    	at hudson.remoting.Command.<init>(Command.java:67)
    	at hudson.remoting.Command.<init>(Command.java:50)
    	at hudson.remoting.UnexportCommand.<init>(UnexportCommand.java:33)
    	at hudson.remoting.RemoteInvocationHandler$PhantomReferenceImpl.cleanup(RemoteInvocationHandler.java:360)
    	at hudson.remoting.RemoteInvocationHandler$PhantomReferenceImpl.access$700(RemoteInvocationHandler.java:319)
    	at hudson.remoting.RemoteInvocationHandler$Unexporter.run(RemoteInvocationHandler.java:420)
    	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
    	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
    	at hudson.remoting.AtmostOneThreadExecutor$Worker.run(AtmostOneThreadExecutor.java:110)
    	at java.lang.Thread.run(Thread.java:745)
    Caused by: java.lang.Exception: Proxy hudson.remoting.RemoteInvocationHandler@81 was created for interface hudson.Launcher$RemoteProcess
    	at hudson.remoting.RemoteInvocationHandler.<init>(RemoteInvocationHandler.java:125)
    	at hudson.remoting.RemoteInvocationHandler.wrap(RemoteInvocationHandler.java:137)
    	at hudson.remoting.Channel.export(Channel.java:621)
	at hudson.remoting.ExportTable.diagnoseInvalidId(ExportTable.java:379)
Caused by:   Released at Fri May 13 15:13:56 CDT 2016
Caused by: Command hudson.remoting.UnexportCommand@3d80bf77 created at
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-cyg64 #270 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.15-win32-test #54 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-cyg64 #270 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 13 May 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
