On 07/09/2016 01:31, Michael Davidsaver wrote:
On 09/06/2016 07:04 PM, Andrew Johnson wrote:
While merging the 3.15 changes into 3.16 I discovered these conflicting
changes. Which one is correct, and if it's the 3.16 change, should it be
back-ported to 3.15?
I think yours, though it may not make a difference practically. If
copyInHeader() only fails in allocRawMsg() fails, in which case I think
no new message is ready to be sent. In this case I would think that
commitMsg() is either a no-op, or an error. I haven't look far enough
to tell which is the case.
+1
My fix was only to suppress the "variable set but not used" warning, and
not setting it was the easy fix without behavior change.
Cheers,
~Ralph
- Re: Merge conflict in base-3.16 Andrew Johnson
- Merge conflict in base-3.16 Andrew Johnson
- Re: Merge conflict in base-3.16 Michael Davidsaver
Fix for building 3.15.4 on windows-x64-static Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
