2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fix for building 3.15.4 on windows-x64-static
To: "'Andrew Johnson'" <[email protected]>, EPICS core-talk <[email protected]>
Date: Wed, 7 Sep 2016 03:37:01 +0000
Folks,
3.15.4 configure/os/CONFIG_SITE.windows-x64 contains these lines:
# 64-bit Visual Studio 2010 builds fail when built optimized.
# If you are using a newer version you can try removing this:
HOST_OPT = NO
These lines are present because src/ioc/rsrv/online_notify.c crashes the linker when it is compiled with optimization. The problem with setting HOST_OPT=NO is that programs will then be compiled with the /MTd switch, which causes them to be linked by default with the LIBCMTD library. LIBCMTD is incompatible with the LIBCMT library that the hdf5 library and other “vendor libraries” may use. HOST_OPT=NO also disables optimization when compiling all files, which is not necessary.
I have fixed the problem by doing the following:
- Comment out the line HOST_OPT = NO in configure/os/CONFIG_SITE.windows-x64
- Make the following patch to src/ioc/rsrv/online_notify.c.
corvette:src/ioc/rsrv>diff -U3 online_notify.c.orig online_notify.c
--- online_notify.c.orig        2016-09-06 17:26:02.828605405 -0500
+++ online_notify.c     2016-09-06 18:16:52.955345453 -0500
@@ -35,6 +35,11 @@
#define epicsExportSharedSymbols
#include "server.h"
+/* Turn off global optimization for 64-bit MSVC builds on Visual Studio 2010 */
+#if defined(_WIN32) && defined(_M_X64) && _MSC_VER==1600 && !defined(_MINGW)
+#  pragma optimize("g", off)
+#endif
  *  RSRV_ONLINE_NOTIFY_TASK
Note that this patch is very similar to the code already present in src/libCom/calc/calcPerform.c, except that calcPerform.c does not restrict the optimization suppression to Visual Studio 2010.  I am not certain what versions of Visual Studio cause problems with calcPerform.c.
/* Turn off global optimization for 64-bit MSVC builds */
#if defined(_WIN32) && defined(_M_X64) && !defined(_MINGW)
#endif
Both of these workarounds could probably be further improved by only disabling optimization for static builds, not for dynamic builds.
These changes allow building base 3.15.4, and all of the required code for ADCore and ADExample for windows-x64-static with no errors.
RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Prev: Re: Merge conflict in base-3.16 Michael Davidsaver
Next: Re: Merge conflict in base-3.16 Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Merge conflict in base-3.16 Andrew Johnson
Next: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
ANJ, 07 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
